Drivetrain D1 Spec Throttle Boost REVIEW!!!!!!!! FINALLY!!!!
Old Dec 15, 2011 | 09:56 AM
PierreLeona's Avatar
PierreLeona
Well, before I purchased this device there really wasn't much news about it. But I thought I would pull the trigger and try it out anyways. I got it from here:
http://www.aj-racing.com/shop/bmy_se...and=Mini&type=
Basically I would say, this was an AMAZING MOD. I paid about 120 overall with shipping and it was completely 100% worth it. There is a guy there named Jason Tam and he was EXTREMELY helpful when he was helping me trouble shoot the issue. My first D1 Spec that I received from him was actually a bad one, but he issued me a complete return label and ordered me a brand new one from the supplier. After I received that, I plugged it in and BAM! You could instantly feel the power! I purchased the D1 with 7 sport settings, 5 eco settings and 1 normal setting. But the one I received had NINE sport settings!!!! So I obviously tried the ninth setting first lol.
Granted the device does not add any HP or TQ whatsoever, it does exactly what it is suppose to, making the throttle opening more sensitive and in turn opening up the throttle more from idle. I believe the stock MINI throttle body is electronic and doesn't allow full throttle opening at low speeds. But this fixes that issue. Stepping on the gas each time really makes you "feel" like the bottom end power is right there. So if you feel like your MINI lags a little bit from idle and such or even after shifting gears, this is the device for you!!! It is extremely cheap and it does really give that feeling of power!!!!!!!
BTW, if you use a Scangauge II or some other device that plugs into the OBDII port you can get this from amazon:
http://www.amazon.com/OBDII-Splitter.../dp/B000TMCX72
and they work perfectly together !!!!
So roughly if you had to get it it would be an overall of 150 spent maybe. AND IT IS WORTH IT!!! Any other questions please address them here and I would love to finally provide some insight for this device!!!!!!
Old Dec 15, 2011 | 01:12 PM
R53MAO's Avatar
R53MAO
Sounds like a good alternative to the sprint booster, and at less than half the price!
Old Dec 15, 2011 | 02:22 PM
PierreLeona
Definitely
It is an EXCELLENT alternative to the SprintBooster. Lots more settings and like you said MUCH MUCH cheaper!!
Old Dec 15, 2011 | 04:14 PM
TimL's Avatar
TimL
Good to know; lack of SGII compatibility was the major sticking point for me.
Did you have to modify the connection @ the throttle at all -- I seem to recall one post or another on here suggesting that was at least once the case -- or is the D1 100% plug-and-play?
Old Dec 15, 2011 | 05:09 PM
PierreLeona
100% PnP!!!
Those issues did exist before, but they have fixed it now!! Mine was plug and play completely!!! Just make sure you plug the throttle cable from the D1 to the cord in the car the correct way. If you accidentally plug in the D1 to the throttle cord in the car, the D1 won't turn on.
Old Dec 17, 2011 | 06:09 AM
TimL's Avatar
TimL
Next question
I see the AJ Racing site lists the D1 only for the R50/R52/R56; I presume the R50 version is what you're using for the R53?
Old Dec 17, 2011 | 08:51 AM
PierreLeona
From what i remember , it is all the same like literally R53 and R56
Give them a brief call or email but from what I remember the rep there, Jason, told me they were all the same. The only.difference is auto and manual ttranny .
Old Apr 4, 2012 | 07:43 AM
OldGameFreaK's Avatar
OldGameFreaK
Since this is all a few months old, I was wondering how things were going with it? are you still happy with it, do you have any other feedback on it? Do you have any pics of where you found to install it?
Old Apr 4, 2012 | 11:56 AM
Raze's Avatar
Raze
I have this installed on my r53 for several months now and completely love it.
Old May 17, 2012 | 02:51 AM
scoopy's Avatar
scoopy
i just got mine just wondering where do you connect the red blue and yellow wires? did u guys use the extension?
Old May 17, 2012 | 04:11 AM
Raze's Avatar
Raze
i do not remember any loose wires. but i did have to tell the store that i orderd it from that my car was an r53 manual and he included an adapter to fit everything together
Old May 17, 2012 | 04:59 AM
scoopy's Avatar
scoopy
on the back of the module there are 3 adapters one for the settings, one for the obd2 then in the middle of that there are one adapter for speed signal, braking input and astern(power connecting 2 according to the manual)
Old May 17, 2012 | 05:58 AM
Raze's Avatar
Raze
did you get the cable adapter that you install into your gas petal??
Old May 17, 2012 | 06:11 AM
scoopy's Avatar
scoopy
yup i did
Old May 17, 2012 | 06:49 AM
scoopy's Avatar
scoopy
do you have any pic on how and where you mount the module and the controller? and also what did you do on the obd2 cover is it lying down?
Old May 17, 2012 | 07:30 AM
Raze's Avatar
Raze
i cut the OBDii plug and spliced the wires into the ODBii port and hide the module behind the dash & feed the controller screen from the back of my tack to the control module.
Old May 17, 2012 | 07:32 AM
scoopy's Avatar
scoopy
u just followed the color of the wires?
Old May 17, 2012 | 07:39 AM
Raze's Avatar
Raze
nope i pulled the OBDii port down and spliced the wires into the corresponding wire from the back of the OBDii port using the plug just to verify that i was doing it to the right wire
Old May 17, 2012 | 08:00 AM
scoopy's Avatar
scoopy
ah i see if you have the time or if you can take a pic please do let me know i just want to make sure. did you remove the knee bolster when you put this thing?
Old May 17, 2012 | 08:03 AM
Raze's Avatar
Raze
i removed the knee booster and the top half of the dash, but i have heard of poeple attaching things to the back side of the knee booster
Old May 17, 2012 | 08:25 AM
MSFITOY's Avatar
MSFITOY
any pics?
Old May 17, 2012 | 09:16 AM
Raze's Avatar
Raze
I don't have my camera on me at the moment.
Old May 17, 2012 | 09:18 AM
Raze's Avatar
Raze
I'll post some this weekend after I pick up my camera
Old May 17, 2012 | 11:52 AM
jonnieoh's Avatar
jonnieoh
Okay, you've officially captured my interest.
For those who've never experienced what this product can do, please try to explain further:
1.) Is the throttle response truly, noticeably quickened? (Really)?
2.) does it make it easier to lose traction when leaving a stoplight "aggressively" in 1st gear? (which in my opinion, is a negative; front-wheel burnouts are not cool. Ever.)
3.) List any other details that we might find beneficial to know...
THANKS!
Old May 17, 2012 | 12:47 PM
Raze's Avatar
Raze
1)very noticeable throttle responce that can be set to how ever you want it. either lightning quick or turtle slow. you can do it all. this does all the same things the sprint booster does @ 1/2 the price
2)you can tune it how ever you want to drive that the great thing about the Throttle booster.
