Drivetrain D1 Spec Throttle Boost REVIEW!!!!!!!! FINALLY!!!!
Old May 17, 2012 | 01:01 PM
  #26
MSFITOY's Avatar
MSFITOY
Sounds like my other custom tune for another car...the tuner adjusted the throttle rate for a faster ratio and it takes much less pedal travel for power to come in...I'm going to have to try this out...just waiting for some cool pics of this diy...
Old May 17, 2012 | 01:59 PM
  #27
MSFITOY's Avatar
MSFITOY
WTF?!? $28 for shipping to NC? Wowii...how much does thing weigh?
Old May 17, 2012 | 02:00 PM
  #28
Raze's Avatar
Raze
its coming from canada
Old May 17, 2012 | 02:04 PM
  #29
MSFITOY's Avatar
MSFITOY
I know...is that what they charged you too Raze?
Old May 17, 2012 | 02:06 PM
  #30
Raze's Avatar
Raze
i payed a little over 40$ im overseas in Europe right now with my mini
Old May 17, 2012 | 02:55 PM
  #31
MSFITOY's Avatar
MSFITOY
haha...ok I feel better...in the mean time before you get pics up, where are the junction cable connected to? It looks like the go pedal pushes a rod through the firewall...is the transducer on the other side?
Old May 20, 2012 | 09:21 AM
  #32
MSFITOY's Avatar
MSFITOY
Well...I'll post some pics when mine gets here...I got one through Ebay for $130 total...
Old May 20, 2012 | 02:39 PM
  #33
scoopy's Avatar
scoopy
I also got mine there
Old May 20, 2012 | 02:53 PM
  #34
MSFITOY's Avatar
MSFITOY
Do you have it installed? What did you pay?
Old May 20, 2012 | 04:15 PM
  #35
scoopy's Avatar
scoopy
i got mine at 140 shipped to Philippines. i haven't installed it yet. i'm looking for pictures here. I also do not know how to remove the knee bolster hehe. Reason i don't want install it yet is because i want to see how raze spliced the wires. are you going to use the obd2 port?
Old May 20, 2012 | 04:25 PM
  #36
MSFITOY's Avatar
MSFITOY
knee bolsters? pull on it...
no need for obd...it only connect there for power...you can tap anywhere there's power...
Old May 20, 2012 | 05:03 PM
  #37
scoopy's Avatar
scoopy
can you show me some pictures? i'm kinda illerate when it comes to this. so basically you can just tap anywhere correct? did you remove the 3 colored wires the one in the middle plug? are you going to remove the obd2 port from the d1 spec and just splice the wire and tap it to a power source wire?
Old May 20, 2012 | 05:21 PM
  #38
MSFITOY's Avatar
MSFITOY
when I get mine, I'll post pics ok?
Old May 20, 2012 | 05:36 PM
  #39
scoopy's Avatar
scoopy
alrighty will wait for that. thanks
Old May 21, 2012 | 09:31 AM
  #40
Raze's Avatar
Raze
LED Mounted
The controller mounted
Throttle interrupt cable
ODBii port (I cut this out)
Spiced into ODBii port
Extra wires (DO NOT USE)
Old May 21, 2012 | 02:39 PM
  #41
scoopy's Avatar
scoopy
Ok so basically you tap the black wire to the brown wire and the red wire to the red/blue wire? Tnx
Old May 21, 2012 | 02:46 PM
  #42
Raze's Avatar
Raze
yep, but only do this if you want to hard wire the D1 in. other then that just use the OBDii connecter. (i use that for other things)
Old May 21, 2012 | 08:17 PM
  #43
scoopy's Avatar
scoopy
yup i want to hardwire the d1. as im using the obd2 port for the scanner that i have. thanks.
well i think there's no harm done if the d1 is hardwire isnt it'
Old May 22, 2012 | 04:24 AM
  #44
THE ITCH's Avatar
THE ITCH
Raze
Great job on the pictures. Just so everyone has all the info, and for those who may not want to tap into the OBD II port you can always purchase one of these and have plug and play.
http://www.amazon.com/OBDII-Splitter-J1962M-2-J1962F-145802/dp/B000TMCX72
Steve
Old May 22, 2012 | 05:38 AM
  #45
Tank251's Avatar
Tank251
Looks like a lot of work to install. [I have ten thumbs so not very handy]
For those that have used this, have there been any issues when the dealer service people see it?
Old May 22, 2012 | 09:52 AM
  #46
MSFITOY's Avatar
MSFITOY
Thanks for the images! Did you have to dismount the throttle pedal to get to the connectors?
Old May 22, 2012 | 09:59 AM
  #47
Raze's Avatar
Raze
Nope i just used a small screw driver to pop the connector off the pedal, pluged it into the supplied harness connector and just plugged the harness connector into the pedal and routed the wires.
Old May 22, 2012 | 11:01 AM
  #48
andyroo's Avatar
andyroo
Originally Posted by THE ITCH
Raze
Steve
that looks like a good solution. I ain't hardwiring anything.
Old May 23, 2012 | 02:59 AM
  #49
53LVMini's Avatar
53LVMini
Just installed this tonight, wow what a difference. Its pretty much a cooper s with a sport mode function. What can i say, throttle response is how it should be, rev matching went from difficult to spot on easy. I would put this mod up there with the one ball cause its cheap and almost necessary for a more aggressive driver. I assume you could also save some gas money with the "eco" mode seeing as it also made a huge difference. Another plus about the D1 is that it shows battery voltage with a push of a button which is very convenient...the display itself is all eye candy also, showing you at what % your throttle is at when driving. I highly recommend this mod, ive seen some negative reviews about it on this forum and just cant comprehend why at this point, cant wait to drive to work tomorrow! Thats rare! FYI: I might post a video soon on the install seeing as how there really isnt a detailed sticky, though its easy it still doesnt hurt to speed up the install process for some.
Old May 23, 2012 | 07:13 AM
  #50
scoopy's Avatar
scoopy
ill be doing mine this weekend but doesnt hurt if you have a video
