Drivetrain D1 Spec Throttle Boost REVIEW!!!!!!!! FINALLY!!!!
Old Mar 16, 2013 | 08:14 AM
  #301
TimL's Avatar
TimL
D1 spec offers more flexibility for about half the cost of sprintbooster, but it also occupies your obd port.
Old Mar 16, 2013 | 08:16 AM
  #302
nutsofamily's Avatar
nutsofamily
Is that a bad thing?
It is less expensive and AJ in Vancouver can get them, so no Hong Kong shipping.
Im no techy so any extra info would be great.
I see they are on revision 3.5 now.
  #303
Redhatch's Avatar
Redhatch
They both do the same thing, change the ramp rate of the throttle. The D spec is cheaper and has a lot more maps. I have the D spec and it has been flawless. I would recommend it.
Old Mar 16, 2013 | 08:18 AM
  #304
nutsofamily
Also, there is this 3 drive pivot controller, any thoughts to the tech gurus?
Old Mar 16, 2013 | 08:19 AM
  #305
Redhatch's Avatar
Redhatch
You can hardwire it in or use a obd splitter if you want obd access. You can get an obd splitter on ebay for 20.00
Old Mar 16, 2013 | 08:23 AM
  #306
Redhatch's Avatar
Redhatch
I think the D spec is a knock off of the Pivot
Old Mar 16, 2013 | 03:47 PM
  #307
daflake's Avatar
daflake
Unless you hardwire it.
Old Mar 17, 2013 | 11:53 AM
  #308
Derek1387's Avatar
Derek1387
So the general consensus is its a worthwhile mod? I would be putting it in my 2009 Justa...
Old Mar 17, 2013 | 07:49 PM
  #309
scoopy's Avatar
scoopy
Originally Posted by nutsofamily
So what are the differences between these 2 devices?
I think they are the same. It is just cheaper and you have 9 settings
Old Mar 20, 2013 | 10:09 AM
  #310
IQRaceworks's Avatar
IQRaceworks
I'm still wondering how it's going to get rid of the lag. From all of the info I have found on the D1, and Sprint Booster.....all they do is tell the computer that now a 20% pedal position will equal a 60% motor throttle position (and so on). How does that get rid of the lag? If you mash the pedal to 100% (WOT)....it's going to max throttle with the D1 just like it would stock. Does the D1 actually make the TIME it takes to respond less?
Could someone take a video clip showing the improvement in pedal position vs engine rpm? I HATE how much of a lag the pedal position has on my MCS...when I tap the pedal to try to match the rpms when down shifting...the engine doesn't even rev. It's almost as if it's got a half-second delay built in.
Could someone take some video showing the response time of the different maps that the D1 booster has?
Thanks!
Old Mar 20, 2013 | 12:29 PM
  #311
RickBe's Avatar
RickBe
If it takes you .2 second to push the pedal 20%, you are now getting 60% power in .2 second rather than the previous 20% (using your example, not claiming those as capabilities of the controller). I suspect it's more like you are getting 60% rather than 55%, but even that little bit FEELS much better, and more proportional to what I expect when I step on the trottle.
Old Mar 21, 2013 | 01:22 AM
  #312
Derek1387's Avatar
Derek1387
Just ordered mine off of ebay. Offered $108 and he took it.
Pretty excited!
Old Mar 21, 2013 | 07:56 AM
  #313
nutsofamily
Pretty excited!
Could u post a link please or vender handle?
Old Mar 22, 2013 | 01:15 PM
  #314
jonnieoh's Avatar
jonnieoh
A quick Google search shows that the D1 Spec throttle controller is popular not only with us MINIacs, but with modders of VW's, Honda Fits, Subaru's, etc.
So is there a specific model for us MINI owners, or is it a universal one for all these different makes and models?
I just want to be sure I'm not ordering one from some guy on eBay who is selling me one for a VW 1.8t engine or something!
Old Mar 22, 2013 | 02:51 PM
  #315
RickBe's Avatar
RickBe
There are cables that are specific to the car for which the unit is intended. If you buy a used one, and it was previously installed on something else, you may need to buy the proper wiring and plugs. If it's new, tell the seller what model of car you have, and the unit should include the proper wiring and plugs for your car. It looks like the wiring set that came with mine will also fit a dozen or more different cars, so there is some interchangeability.
Old Mar 23, 2013 | 05:17 AM
  #316
THE ITCH's Avatar
THE ITCH
Jon
Check out Greasey's Garage in Massachusetts. They usually have them in stock and will sell them uninstalled. The price on the web page is an installed price.
Steve
Old Mar 29, 2013 | 01:33 PM
  #317
bugeye1031's Avatar
bugeye1031
Moderator
Thanks!
I haven't installed my D1 yet, but I believe that all that it does is change the throttle mapping (accelerator pedal to throttle intake opening) and that it will not change the lag. The lag is a side effect of drive by wire, and I don't think that we can ever get rid of that....unfortunately.
Old Apr 5, 2013 | 05:23 AM
  #318
Babyblue02's Avatar
Babyblue02
Just a quick question, if I got a 17% pulley and a DT bpv would this help any. Sorry if this has already been asked.
Old May 10, 2013 | 03:41 PM
  #319
cenobyt's Avatar
cenobyt
Just got around to installing mine. 2013 has set screw at base of pedal. Unscrewed that and pedal popped off. Hooked it all up. No power. Pushed extremely hard on OBD connector and got power. This works as advertised. May even try Eco mode on long distance highway trips. Can also verify that this works on an automatic.
Old May 24, 2013 | 12:48 PM
  #320
diver7's Avatar
diver7
Has anyone tried the D1 Spec on a vehicle with an automatic? I have a 2013 automatic and would love to get rid of the accelerator lag.
Old May 25, 2013 | 02:30 PM
  #321
OldGameFreaK's Avatar
OldGameFreaK
Yep the OBDII port only uses 2 wires power and ground. Just cut off the connector and wire it in.
Old Jun 6, 2013 | 09:39 AM
  #322
jamez's Avatar
jamez
Keeping the old thread alive, I just bought one from ebay. Original offer to one of the vendors at 108AU it was not accepted. $110AU offer (to what I assume is another version of the same vendor) was accepted.
$130.99CAD shipped to Toronto, Canada supposedly (I'll update when it arrives)
Old Jun 6, 2013 | 11:34 AM
  #323
diver7's Avatar
diver7
I got mine from Greasy's Garage (http://www.greasysgarage.com/). Arrived last Saturday. Works great. Total came to $156.72 delivered.
They only show them installed on their site but just give them a call and they will ship one to you.
Old Jun 6, 2013 | 12:25 PM
  #324
STF_U's Avatar
STF_U
Got mine from Greasy's too, installed yesterday on my R50, works great! Definitely puts just a little more pep in it
Old Jun 14, 2013 | 06:16 PM
  #325
jroland's Avatar
jroland
Here's a follow up review. I've had the D1 Spec installed for 6 mo now. Still love it. No error codes. Took it out when I went back for service, just because. I run it at SP 4-5 mostly, because if its higher then the shifting is jerky. Sometimes I put it back to "nor" for a while, then back to sport just to feel the difference again. I love this thing! Buy it!
Sent from my iPad using NAMotoring
