Drivetrain D1 Spec Throttle Boost REVIEW!!!!!!!! FINALLY!!!!
Old Sep 14, 2012 | 11:43 AM
  #226
OldGameFreaK's Avatar
OldGameFreaK
I just got mine in!!!! does anyone have a pic of the 8A connector AFTER they modified it?
I think mine needs done. It looks like the others in earlier posts.
Old Sep 14, 2012 | 01:25 PM
  #227
daflake's Avatar
daflake
There is a pic in this thread that shows where it needs to be clipped. Can easily be done with a set of needle nose.
Old Sep 14, 2012 | 01:43 PM
  #228
jay80424's Avatar
jay80424
I used a razon knife to shave off the necessary parts. Sorry, no pic, but it's pretty obvious if you compare the male and female parts.
Old Sep 14, 2012 | 03:02 PM
  #229
OldGameFreaK
I figured it out!!! How the heck do you ever pull it back out of the OBD2 connector? That thing is IN there!!!
But oh hell this thing is FUN!!!
Old Sep 18, 2012 | 10:59 PM
  #230
DVS DEA's Avatar
DVS DEA
Finally got the replacement.
Works perfect.
Old Sep 22, 2012 | 06:13 AM
  #231
Albiecrazy's Avatar
Albiecrazy
Greasy's got a new shipment in - mine is on it's way to my house now!
Old Sep 27, 2012 | 04:02 PM
  #232
Albiecrazy's Avatar
Albiecrazy
Will I need to plug those red, blue and yellow wires if I'm using the OBD port?
Old Sep 27, 2012 | 04:09 PM
  #233
pmxgm's Avatar
pmxgm
no you dont is an option if you are using the obd port for something else
Old Sep 27, 2012 | 05:55 PM
  #234
Albiecrazy's Avatar
Albiecrazy
Alright - thanks pmx, almost had it all together then. I thought the pedal was going to be rough but I had that sorted, plugged in and re-assembled within minutes.
It was the OBD plug that didn't feel right to me. It was hard to see and wasn't sure if i seated it right. I probably shouldn't have tackled this at my son's soccer practice and without taking the knee panel down. I ran out of daylight and decided to unplug everything and do it right this weekend.
For reference, once it's plugged in completely, will the display light up with just the key in or does the car have to be running?
Thanks for any help or advice. I kinda figured this out on my own just looking at the wiring diagram. Reading the directions were pretty useless from the install side - I'm hoping the set-up side is easier although looking at those directions looked awful, too.
Old Sep 27, 2012 | 06:17 PM
  #235
pmxgm's Avatar
pmxgm
Hi albiecrazy, i have the same concern about the OBDII conector so i hardwired it , the screen will ligth up when you put the switch on and remember to set it before you start the car , here some pics of my instalationD1 Spec Throttle Boost REVIEW!!!!!!!! FINALLY!!!!-2012-09-22-16.40.38.jpg
Old Sep 27, 2012 | 06:38 PM
  #236
jay80424's Avatar
jay80424
Ballsy!
Old Sep 28, 2012 | 02:26 PM
  #237
Albiecrazy's Avatar
Albiecrazy
Originally Posted by jay80424
Ballsy!
Dumb is more like it... With 4 kids, my garage is hardly a sanctuary. But I'm going to give it another shot tonight. Got a little start on it and mounted the display and plugged into the OBD - feels better this time.
Dumb question for pmx - when you say turn the switch on, do you mean the ignition or the left switch on the display? From the 'directions' it seems the ignition has to be on... And lastly, will every plug have to be wired up before I will get anything on the display? Thanks in advance.
Old Sep 28, 2012 | 02:36 PM
  #238
jay80424's Avatar
jay80424
ignition to "on", but not start.
The unit will be powered off until you turn the ignition key.
I would get everything plugged in before you turn the key, and make sure to wait 10 minutes after you turn the car off before you unhook anything.
Turn car off>wait 10 minutes> install>turn key to "on">callibrate unit per instructions> Start car and test drive>grin ear to ear.
Old Sep 28, 2012 | 03:13 PM
  #239
Albiecrazy's Avatar
Albiecrazy
Now those are directions I can understand. Thanks, jay!
Old Sep 28, 2012 | 03:22 PM
  #240
jay80424's Avatar
jay80424
No Prob.
Where are you on LI?
I grew up in Centerport.
Old Sep 28, 2012 | 04:58 PM
  #241
Albiecrazy's Avatar
Albiecrazy
Ooooo that's pretty nice. The rest of the install went pretty quick and setting it up was easier than I thought, too. Started at SP6, upped it to SP7 and like it right there for my naturally aspirated little spitfire. I'll save 8 & 9 for emergency situations.
Thanks for the quick tips, guys - really appreciate it. I've now done my own intake and this - not bad for me.
Jay - I'm out at the end of the LIE - Riverhead. And commute to E. Setauket - Monday's ride in will be a little more fun.
Old Sep 29, 2012 | 05:38 PM
  #242
sprint1126's Avatar
sprint1126
okay i'm having trouble getting the the plug into the foot pedal it wont fit at all. did anyone else have a problem there or it just slid on?
nevermind i see on page 6 the fix. to late i broke the clip that hold it to the pedal.... got tired of fighting with it!!!!!!!!!!!
Old Sep 29, 2012 | 06:13 PM
  #243
Albiecrazy's Avatar
Albiecrazy
There are two different plugs - one plugs into the stock plug (the one that came off the gas pedal) and the other goes to the pedal. Those went on pretty easily for me.
Also, the wiring for the gas pedal came in the smaller box.
Old Sep 29, 2012 | 06:42 PM
  #244
sprint1126's Avatar
sprint1126
the plug that went into the pedal i couldnt get on, but i see from earlier post i had to do lil tweaking to it to make it slide on, wish id seen that earlier before i got pissed and broke it
Old Sep 29, 2012 | 06:51 PM
  #245
Albiecrazy's Avatar
Albiecrazy
I thought I read a post about altering the plug that goes into the OBD port for Gen 1's. But this is a long thread now...
Found that post on page 6. Crap.
Old Oct 4, 2012 | 04:01 PM
  #246
wakemini21's Avatar
wakemini21
sorry if this question was asked before but theres so many mixed reviews and no one states if they have an r53 or r56 or auto or manual. So this does work with an 09 R56 manual MCS?
Old Oct 4, 2012 | 04:26 PM
  #247
Noonzio's Avatar
Noonzio
I have an R53 auto - I also used it in an R53 manual. There are people in this thread who have it in both R56 manuals and auto's. So yes, it should work in an R56 manual MCS
Old Oct 7, 2012 | 12:06 AM
  #248
BMUN8IVE's Avatar
BMUN8IVE
Please, pardon my ignorance, BUT. . . I have an OBD2 reader for the torque app pro. . .if I am to order the aforementioned splitter, remove the current reader, plug IN the splitter and mount the OBD reader in a new spot WILL this device straight up plug and play? Remove the clip from the pedal, clip in the device, reconnect, and connect whatever part of the device into the extra port on the splitter, and I am good to go? Any splicing, or stuff like that, and it's a no go until I get into a position where I can do it.
I am having the ladyfriend do this(provided I buy it), as I am still recovering from surgery, but will not be able to get down that low for at least a year. . . She isn't an idiot, and has been great in helping me with a couple of things, but I just don't want to end up frustrated, with something broken.
Also, bottom line, is this worth throwing on there? It's a manual 2003 R53, just figure I should be getting stuff done to it I have been meaning to, but have been swamped with work/life. I was all about the Sprint Booster until I saw THIS thread. . .
I just can't imagine paying shop labor for something seemingly so simple. If the benefits are worth it, I am into it, besides, I love another lil device on the dash!
Old Oct 7, 2012 | 06:38 AM
  #249
jay80424's Avatar
jay80424
The ODB port will be plug and play. You most liklely will need to modify the connector that goes to the gas pedal. Unless you buy a used one that has been modified. There is one in the marketplace, but I don't know if it's still for sale.
Worth it, yes!. Best $120 i've spent in a while on the mini.
Old Oct 10, 2012 | 08:15 AM
  #250
Jinjiro7's Avatar
Jinjiro7
Got mine!
After reading this thread, I picked up my D1 on eBay last week Thursday. Got it for $110 + shipping. Not bad. Best part was only took 4 days to ship to Toronto!
Install was straight forward after reading the various tips from the thread (snipping the D1 connector that goes into the pedal, figuring out which wires to splice on the OBD).
The included instructions were a little vague. I used the instructions from the *other* product to show me how to remove the pedal.
Took me longer to get all the wires tidied up and power connector soldered and shrink wrapped, vacuum car.
Went for a drive this morning to try the various modes. SP6 seems to be my sweet spot using Bridgestone RE760 tires. Granted outside temp was 11 degrees C (52 F). SP7 gave me some wheel spin.
Having the option to change profiles is a great feature. I did try Econo just for kicks....haha never do that again.
