Drivetrain The Official ALTA AccessPORT Thread
Old Apr 30, 2014 | 12:08 PM
  #3651
bennys8's Avatar
bennys8
2013 Hardtop JCW Compatibility
Hey guys,
Newbie here. I searched through several pages but haven't found an answer yet. I apologize in advance, I know this is a really simple question... Does the Alta Accessport work on a 2013 Hardtop JCW? Manaul transmission if it matters.
Thanks!
Old Apr 30, 2014 | 12:15 PM
  #3652
Richieb0y28's Avatar
Richieb0y28
I don't believe the AP works with your engine (N18)
Old Apr 30, 2014 | 12:16 PM
  #3653
bennys8's Avatar
bennys8
Thanks, Richie. Any recommendations in its place?
Old Apr 30, 2014 | 12:45 PM
  #3654
Richieb0y28
I think there are two options listed in this forum under the "Modifications - Drivetrain Cooper S" threads.
JB+ tune - from BMS and something from Manic Motorsports, but not sure how they are.
Old May 18, 2014 | 03:16 PM
  #3655
LarriB's Avatar
LarriB
I know the Accessport can check and clear codes. Can it clear an airbag light? I was trying to install and amp and I was playing with the X9331 connector and the one above it. When I reconnected the battery, among the many other lights and issues that happened was the airbag light went on. I cured all the other issues, but the airbag is on.
Edit: apparently not.
Old Jun 16, 2014 | 09:35 AM
  #3656
hidperf's Avatar
hidperf
Clubman exhaust and tunes other than Stage 1
I don't know if this thread is even follow anymore, but I thought I'd give it a shot.
I just bought an AP off of another member (hasn't even arrived yet) and I was researching info on tunes. Everything says that I need a 3" exhaust and DP for a stage 2 or higher tune.
I can't seem to find a 3" system for a Clubman. I was really interested in the Magnaflow because I've had great luck with them in the past and I can get their systems at cost.
Since the R55 has dual mufflers and I would assume lest restriction, what are your thoughts on a 2.5" catless downpipe(probably the Way Motor Works) and the 2.25" Magnaflow system? Will it flow enough for a stage 2 tune?
Old Jun 16, 2014 | 09:39 AM
  #3657
ALTA_Chris's Avatar
ALTA_Chris
Hello, for that system, you will need to run a stage 1 tune. The stage 1 tune will run fine with all that, and make good power, but a 3" complete turbo back is required for a stage 2.
Old Jun 16, 2014 | 10:04 AM
  #3658
hidperf's Avatar
hidperf
Wow! That was the fastest reply I've gotten on here yet! Thank you!
I guess custom it is.
Old Jun 16, 2014 | 12:53 PM
  #3659
Dr. Spade's Avatar
Dr. Spade
I'm running stage 2 tune with a 2.5" DP and 2.5" resonator and second cat delete. Rest of the exhaust is stock.
It boost cuts sometimes. In hindsight I should have left primary cat on and kept stage 1
Old Jun 16, 2014 | 01:01 PM
  #3660
hidperf's Avatar
hidperf
Thanks for the info.
I might be completely satisfied with the Stage 1, or eventually moving to the Stage 1 with intercooler and intake. But I also said I wasn't going to mod this car and I've only had it since April.
Old Jun 16, 2014 | 01:12 PM
  #3661
Dr. Spade's Avatar
Dr. Spade
Yea once you do the DP you either need the 2/3 tune or a defouler to get rid of CEL. It gave multiple misfire codes just for that
Old Jun 16, 2014 | 02:24 PM
  #3662
nine5raptor's Avatar
nine5raptor
Will the stage 1 tune not clear the DP codes? Or even the Stage 0 tune?
Old Jun 16, 2014 | 03:48 PM
  #3663
Dr. Spade's Avatar
Dr. Spade
It won't. A defouler might. I have one FS but didn't try it.
Old Jul 3, 2014 | 07:04 AM
  #3664
rockridge's Avatar
rockridge
Do you need to do anything special to get a reasonable size log? I tried to capture a log while I drove to down hall this morning, and it only recorded the first 29 seconds of my trip? I was collecting 21 metrics.
Old Jul 3, 2014 | 07:08 AM
  #3665
hidperf's Avatar
hidperf
I didn't have to do anything special on mine. I recorded 30mins with 20 metrics just by turning datalogging on, nothing else.
Old Jul 3, 2014 | 07:12 AM
  #3666
hidperf's Avatar
hidperf
I've been trying to read this entire thread for weeks now, but I can't get through it all.
I've even got one screen at home where I started from the beginning and a screen at work where I started at the end.
So this might have been answered already but here it goes.
Does the ECU in these cars take a while to "learn" after a new tune is loaded? Will it fine tune things the longer I drive it?
Old Jul 3, 2014 | 11:05 AM
  #3667
akent's Avatar
akent
With mine, I went from a smile to a HUGE GRIN instantly!
I've been driving with a tune for almost two years and it's been the same since day one. No change.
Old Jul 3, 2014 | 11:08 AM
  #3668
hidperf's Avatar
hidperf
That's unfortunate. I was hoping that this part throttle stumble was simply a "learning" issue and would go away.
Time to dive in I guess.
Old Jul 23, 2014 | 07:52 AM
  #3669
countrymanman's Avatar
countrymanman
A member of man is selling an accessory for r56, will this work on my 2012 countryman s?
Old Jul 23, 2014 | 07:54 AM
  #3670
JCW_Coupe's Avatar
JCW_Coupe
i believe the CM has the N18 so no.
Old Aug 8, 2014 | 06:00 AM
  #3671
AustinM731's Avatar
AustinM731
I have been trying to read through this whole forum to find this out but I have not seen it yet. But since AP is now discontinued can I buy one second hand and use it on my 2010 mcs?
Thank you in advance!
Old Aug 8, 2014 | 06:01 AM
  #3672
JCW_Coupe's Avatar
JCW_Coupe
yes you can, i bought one and used it on my 2012 jcw
Old Aug 8, 2014 | 06:18 AM
  #3673
hidperf's Avatar
hidperf
Make sure it's been unmarried (why don't we call it divorced?) from the other car.
But yes, I bought one for my 2010 Clubman S and love it so far.
Speaking of this thread, is there a reason why nobody has gone through and cleaned it up? It's a CRAZY amount of post, most of which are the same thing repeated. I've actually got two tabs open at all times, one that started from the first post and one that started from the last. I've never met in the middle yet.
Old Aug 8, 2014 | 06:21 AM
  #3674
JCW_Coupe's Avatar
JCW_Coupe
we dont say divorced becasue that would imply the AP still gets 50% of the mini after its final :P
Old Aug 8, 2014 | 06:30 AM
  #3675
hidperf's Avatar
hidperf
That's awesome! lol
