Drivetrain The Official ALTA AccessPORT Thread
Old Oct 25, 2016 | 05:42 AM
  #3901
Dr. Spade's Avatar
Dr. Spade
Originally Posted by ALTA_Chris
That map was a custom dyno tuned map for one of our shop cars, so no one else has that tune. Even if it was available, it probably wouldn't work on many cars now since it was done on an old version of the ECU. I wouldn't recommend using someone else's custom dyno tune since they are made specific to one car and their modifications.
Thanks. I was reading thru and the car seems nearly identical to mine in terms of mods so I got excited.
Also there's no tuners in my area (possibly even state) that tune Mini AP's. Lots of local AP tuners that do STI/Evo and such.
Old Oct 25, 2016 | 11:08 AM
  #3902
ALTA_Chris's Avatar
ALTA_Chris
You're welcome. Unfortunately I don't think there are any tuners around that still tune the MINI AP.
If you need a custom dyno tune now, I'd recommend finding another tuning option and selling the MINI AP, they still seem to be selling for a good amount on the used market.
Old Nov 10, 2016 | 10:41 AM
  #3903
Dr. Spade's Avatar
Dr. Spade
Thanks. That's still my end game. I just don't like adding to my sunk costs on this car.
Is there a way to get the JCW maps added to my AP or is it all done by recognition? Can I just add a map in AP manager? I'm assuming the JCW maps are pullable from a friend that has AP on a JCW.
Old Nov 10, 2016 | 10:55 AM
  #3904
Richieb0y28's Avatar
Richieb0y28
You can add maps in your AP Manager. I did that maybe 3 yrs ago, unless something has changed since then.
Old Nov 10, 2016 | 11:07 AM
  #3905
oldbrokenwind's Avatar
oldbrokenwind
Your AP maps all have a similar prefix, matching your ECU software program --- something like "H810B" or "H910B". Your AP can't load a map with a different prefix, and I'm pretty sure JCW maps will have a different prefix from MCS maps. This is one reason why AP owners don't want dealer software upgrades --- upgraded software has a different prefix.
There is a tuner near or in Salt Lake City that has / had capability to change a friends AP map prefix. Wisely it didn't happen (it was one of my custom AP maps). Same company that bought out ZipTie DynoWerks (who did my last AP tune) --- Simple Performance.
I'll second Alta_Chris's suggestion --- get a different tune. You can still use the AP for everything else, just no map storage.
Old Nov 22, 2016 | 04:33 AM
  #3906
coachvminis's Avatar
coachvminis
Ok! My Turn I read back on a couple threads and problems and issues everyone is having...Yes it's an older map and tune..but my Mini is an 09' MCS N14 R56 Auto trans
I have a larger Front Mount, Catless DP no second cat no res to magnaflow muffler
Alta recirc valve alta boost tap and a cold air intake.
I downloaded stage three and everything downloded fine..Now when I get on it it coughs at 4000 rpms...like it's choking out...I need to play with this accessport more for sure.
The airbag light is still on after clearing the codes..weird how do I get that off?
Is it possible the recirc valve is slow? or would the sport button have anything to do with this coughing or loss of boost at 4000 rpms. Like I really can't get on it it will kick back and cough and choke at 4000rpms weird...Little help...
I know its an older accessport and it is updated just received it back from Cobb..
Old Nov 22, 2016 | 06:10 AM
  #3907
Dr. Spade's Avatar
Dr. Spade
Do you have any codes? Diverter valve became an issue before the wastegate on my turbo did. Though both were fine on stock tune.
Unrelated but I was finally able to buy the Stage 4 tune for the Alta 42/56 turbo. If anyone buys a JMTC 42 hybrid and still runs AP, this may come in handy.
Old Nov 22, 2016 | 06:58 AM
  #3908
mbwicz's Avatar
mbwicz
I remember that Alta was pretty specific saying that they needed larger diameter exhaust to run more than stage 2, not just catless. I never went past stage 1, so I don't have any direct knowledge of this.
Mike
Old Nov 22, 2016 | 10:07 AM
  #3909
coachvminis
Dr. Spade
Codes read and cleared...
P2EE5--Thermo input signal
P0597--Thermo heater control circuit open...
Replaced thermostat prob 30-40 thousand miles ago no leaks no drips...cleared code..
Mbwicz
Did not know this though .75 od would not matter in exhaust piping but I guess it might..
I tried running without the sport button on..was slightly better but I still get the kick back cough at 4000-5000 rpms
I raised the rev meter to 6500..
I will try the stage 2 and see if that makes a difference...extra Power is nice in stage 3
turning a wheel in 1st & 2nd and slightly in 3rd...with paddle shift auto trans..
Still can't clear the dreaded airbag light..can't seem to find that to clear it....anything I'm missing?
Old Nov 24, 2016 | 09:16 AM
  #3910
mbwicz's Avatar
mbwicz
anyone got manual maps for an AP?
My car was an auto, and I deleted the manual maps at some point over the last 5 years. New computer, no maps available for a manual car.
I'm now looking to sell the AP, but it has limited functionality to someone with a manual. I'd rather do the homework for the buyer and load a few basic maps.
Thanks for any help. If you PM me, I'll give my email.
Likewise, if anyone needs some auto maps, I'll be happy to supply.
Have fun,
Mike
Old Nov 29, 2016 | 04:43 AM
  #3911
coachvminis
I'm about ready to burn this thing....Such a headache...still choking at 4000 rpms...
thinking sell all bits and pieces and trade in and get the Camaro SS..
Screw this 4cyl POS!!! It's a constant change this change that...is this really worth the extra few HP and Trq...for the $$..
Old Nov 29, 2016 | 05:20 AM
  #3912
randeez's Avatar
randeez
What's your fuel rail pressure look like? Am also in south florida if you want to swap a few coils and see if it helps before you spend $$ on crap that doesn't help
Old Nov 29, 2016 | 05:57 AM
  #3913
Dr. Spade's Avatar
Dr. Spade
Where in South FL are you? I'm in Sunrise.
Take off Accessport and let me know what happens.
Old Nov 29, 2016 | 07:14 AM
  #3914
randeez's Avatar
randeez
jupiter, work all over palm beach and broward counties tho
o...
Old Nov 29, 2016 | 07:22 AM
  #3915
mbwicz's Avatar
mbwicz
The AP is tough because there is limited support. Before you throw in the towel, you might want to seriously look at selling the AP (I just got $450 for mine) and spend the money on a Manic (or other) tune. I'm guessing that there is someone local to you that could tune the car in a day.
Either way there are weaknesses in these engines (maintenance and design), but there are people here to help. I can't imagine that the driving experience between a 200 hp, 2600 lb car is similar to a 400 hp 4000 lb car. Don't give up on the MINI just yet.
Mike
Old Nov 29, 2016 | 08:47 AM
  #3916
coachvminis
South Fl
I'm in Boynton for now..I have a place in Stuart..I will pretty much drive anywhere to figure this out...wrk in west palm..
Fuel Pressure no idea...
Bavarian Motorsport has a set of upgraded coil backs for 170.00 pretty cheap Black Friday special..
Old Nov 29, 2016 | 08:49 AM
  #3917
coachvminis
yep next step
Nice...I reloaded to stage 1..and still the same problem...
Before I leave work I'm going to tack the tune off and go back to factory..and see if that works...maybe its my diverter valve...? Looking into the upgraded elec diverter from Way or ECS...maybe thats it...
I would be more than Happy to cruise down to Sunrise...to figure this thing out..
Old Nov 29, 2016 | 08:51 AM
  #3918
coachvminis
Jupiter
o...
I used to live and work in Jupiter my Boys both Grads from Jup High..
be more than happy to drive up to you and figure this thing out...
let me know...561-670-0101 call or text...Michael
Old Nov 29, 2016 | 08:53 AM
  #3919
coachvminis
Manic?
Mike
Hey Mike..Manic is a little pricey..and I have to ship my ecu...it's my daily..
so would like to figure this thing out though...
Old Nov 29, 2016 | 09:15 AM
  #3920
randeez's Avatar
randeez
Manic tuner down here , Lou (tigger), will take care of ya, he met up at my office on a Saturday and did the tune for mine, no shipping
I have Bluetooth adapter and torque in my car all the time if you meet up and check out whatever, I'd definitely want to check fuel pressure
I got a meeting in lake worth, should be done by like 230 or 3 I'll text you
Old Nov 29, 2016 | 09:50 AM
  #3921
coachvminis
Ok Cool...thanks...Manic (Lou) The Tigger ,, may be the way to go...
Thanks and I appreciate everyone's help...this R56 is by far the most challenging tune I have ever had...coming from the Audi/VW scene..
Old Nov 30, 2016 | 04:06 AM
  #3922
coachvminis
Went back to stock.. And runs so much better I can finally step on it pass 4000 rpms no cough no choke...
With tune cough and choke...
Not sure why the tune 1-2 or stage 3 Ecu just won't accept it..or other parts and pieces....So much for this Cobb-Accessport tune...
Hey Randeez shoot me Lou's number Manic will be my next try at a tune...
Old Nov 30, 2016 | 05:54 AM
  #3923
randeez's Avatar
randeez
went back thru some of this - you installed a catless dp, is the rest of the exhaust still stock with second cat?
Lou is Tigger2011 on here if you want to shoot him a PM, let me find his number i'll text it to you
Old Nov 30, 2016 | 06:14 AM
  #3924
Sstrickstein's Avatar
Sstrickstein
Your problem I am sure will wind up being something unrelated to the accessport and some hardware issue instead. You shouldn't blame the tune when it brings out a mechanical issue when the car is tuned up.
Old Dec 1, 2016 | 03:19 AM
  #3925
coachvminis
Sstrickstein not blaming just trying to figure it out....Tune is what I want and I do feel the extra power just cannot get past the 4000rpm barrier when I step on it...
It can't be driven that way..That is why I went back to stock.
