Drivetrain The Official ALTA AccessPORT Thread
Old Dec 20, 2016 | 07:47 AM
  #3951
magoolll's Avatar
magoolll
Ap
Originally Posted by StreetShotz
I have searched through the forums and looked around but I can not seem to find an answer to this.
Can the AP be left plugged into the OBD port? I know that the newer units have a setting for auto on/off but I don't see one for the Alta AP and I would just rather lead it plugged in as I use the information that it provides nearly every day.
any insight would be awesome.
Yes you can keep AP connected while driving. You must turn off the engine to clear any codes.
Old Dec 20, 2016 | 07:52 AM
  #3952
StreetShotz's Avatar
StreetShotz
I know know I can leave it on while driving but what I want to do is leave it plugged in when I shut the car off. Right now it stays powered on even with the ignition off.
wondering if there is firmware or a setting I can change that will power it off with the ignition.
Old Dec 20, 2016 | 12:22 PM
  #3953
magoolll's Avatar
magoolll
If you are connected and you turn off the ignition, AP knows it's connected to your vehicle's ECU file, but the current draw is insignificant unless you restart the engine. If you leave it connected it should not be a problem.
Old Dec 20, 2016 | 12:30 PM
  #3954
StreetShotz
I know this however I want the unit to power off. I do not want it on while the vehicle is off.
the light alone is an invitation to mave my windows smashed and car stole in a bad area.
i want to know if there is a way to hook it up so that it will power on with the ignition on and power off when the ignitions n is off.
Old Dec 20, 2016 | 04:34 PM
  #3955
oldbrokenwind's Avatar
oldbrokenwind
With a little ingenuity and an OBD II cable extender, you could build a circuit to turn off the AP with the engine. However, you'd then have the new circuit draining power. Or, just use the extender cable to allow easier AP connect / disconnect.
Old Dec 25, 2016 | 07:56 PM
  #3956
SpuuDy's Avatar
SpuuDy
Okay, I'm being a little lazy here because I know I've seen something posted about this on this thread but I can't find it. I just got a catless downpipe and I don't want my car to throw the cel but I know the stage two tune will get rid of it. I also know I can do o2 sensor spacers. So, can you run the stage two tune with just a catless downpipe and stock catback?
Old Dec 26, 2016 | 04:15 AM
  #3957
NeonLed's Avatar
NeonLed
Any stage on the accessport will mask the o2 sensor code
Old Dec 26, 2016 | 06:49 AM
  #3958
SpuuDy's Avatar
SpuuDy
Will I be able to run stage 2 though with stock catback?
Old Dec 26, 2016 | 09:17 AM
  #3959
NeonLed's Avatar
NeonLed
If you deleted the second cat then you probably could, but I wouldn't until you either delete the second cat or get a DP back exhaust that has bigger diameter pipe.
Is this the thread you were talking about https://www.northamericanmotoring.co...ge-1-tune.html
Old Dec 26, 2016 | 11:20 PM
  #3960
SpuuDy's Avatar
SpuuDy
Yes it is, put the catless dp on today took about 3 hrs of fiddling around with it but I have the heat Shields back on and didn't have to manipulate the cnt downpipe at all to make it work, all you have to do is convince the pipe to fit so far no cel on stage 1 and I've driven about 17 miles on it so we shall see
Old Jan 30, 2017 | 07:39 PM
  #3961
Freedirt's Avatar
Freedirt
Database for maps?
I have been searching high and low for maps for my Clubman S. A few NAM members have helped me immensely. (Thanks!) However...I haven't managed to find much yet.
That got me thinking...why not make a database of all of the canned tunes we can amass?
Thoughts?
Old Feb 2, 2017 | 10:41 AM
  #3962
BeardedForever's Avatar
BeardedForever
EDIT, I found my answer.
Old Feb 2, 2017 | 11:11 AM
  #3963
hidperf's Avatar
hidperf
Curious about this. Does it just prevent the light from coming on, or does it actually prevent the catalyst code completely?
If you take it in for inspection and they hook up the scanner, will it detect the pre and post catalyst readings being identical?
Old Feb 5, 2017 | 04:03 PM
  #3964
SpuuDy's Avatar
SpuuDy
I know that I put a catless downpipe on and it's not throwing any codes. Has to get relicensed this year we shall see if I can get through Missouri emissions testing..😳
Old Feb 5, 2017 | 07:21 PM
  #3965
phxsteele's Avatar
phxsteele
mine went through Arizona emissions with no problem.
Old Feb 5, 2017 | 08:17 PM
  #3966
hidperf's Avatar
hidperf
Looking forward to this. I'm also in Missouri.
Old Feb 7, 2017 | 07:21 AM
  #3967
SpuuDy's Avatar
SpuuDy
I happen to know a few "buddies" and there's a few shops south of stl that don't do the sniffer test or whatever it's called, they just check for the engine light. Pm me if you want to know the locations.
Old Feb 7, 2017 | 11:12 AM
  #3968
Sstrickstein's Avatar
Sstrickstein
Well here is a new one. My Accesport
Screen won't light up. Any suggestions
Old Feb 7, 2017 | 12:40 PM
  #3969
Sstrickstein
I just sent it back to Cobb. They still repair them.
Old Feb 15, 2017 | 06:07 PM
  #3970
Sstrickstein
Here is a question. What is the primary performance difference between stage one and stage two tunes?
Old Feb 15, 2017 | 06:13 PM
  #3971
BeardedForever
I'd like to see a stage 3 map. Be nice to know what HP I can expect with the associated mods.
Old Apr 30, 2017 | 09:36 AM
  #3972
alwayzspeedin's Avatar
alwayzspeedin
Which tune should I use. Current mods.
2.5 cat back exhaust, FMIC , cold air intake , charge pipe muffler delete , bov Alta spring upgrade , torque solution bov adaptor.
I hot got my Accessport the other day got alittle happy and just flashed the stage 3 tune on my MCS. Car drive great in the street but in the freeway in 6th gear it would go pass 3200-3500 rpm and would go pass 7 psi. Car would feel like it's cutting power so I easied off it.
Im waiting on my car less down pipe and colder spark plugs NGK iridium
should i run run a stage 2 till the other mods get put on? Thanx in advance. Also no Cel right now.
Old Apr 30, 2017 | 10:51 AM
  #3973
Richieb0y28's Avatar
Richieb0y28
If I'm not mistaken, I think you can only run stage 1. To fully utilize stage 2 with no issues, you'll need a 3" turbo back setup. That's what I'm running now on my JCW.
Old May 2, 2017 | 08:59 AM
  #3974
spjonez's Avatar
spjonez
Has anyone with the stage 1 tune used this part?
http://altaperformance.com/i-1400712...bo-engine.html
Under the dyno tab:
The ultra smooth interior surfaces of the ALTA Hot Side Boost Tube combined with the removal of the restrictive intake muffler allows your turbo to run more efficiently and free up HP. This above test was done on our MINI Cooper S, with intake, FMIC and turbo back (no AccessPORT or ECU tune) already installed. The before and after show how the Hot Side boost tube makes a noticeable change in horsepower. After installation, we saw an increase in boost of about 1.5psi higher, which this carried across the entire RPM band. Except above 5700, where the ECU didn't like seeing this extra boost.
Does the accessport handle this? Definitely don't want my ECU to panic at higher boost levels.
Old May 2, 2017 | 01:46 PM
  #3975
alwayzspeedin
. With the stage 1 tune when the car is cold I feel the kinda sputters around 3k rpm. But once the car is warm the car runs like a champ.
On another note I have a obx exhaust 2.5 pipping with a oem down pipe. ( but soon to be obx down pipe also. Would you think I can run the stage 2 tune.
Other mods already on. Cold air intake box, charge pipe ( with turbo muffler delete), and obx 2.5" exhaust
