Drivetrain The Official ALTA AccessPORT Thread
Old May 12, 2016 | 07:43 PM
  #3826
TBui's Avatar
TBui
Hi all
Relatively new. Ive lurked around but have rarely posted anything.
I just got my accessport in earlier today. Fought with my windows 10 computer for about 6 hrs to no avail. long story short i used a Mac and worked first try. installed it (works for 2012 JCW Coupe if anyone was wondering) Having said that. Does anyone have any cool custom maps they'ed be willing to send my way???
thanks in advance
Old May 12, 2016 | 11:32 PM
  #3827
Sstrickstein's Avatar
Sstrickstein
I have a 2007 MCS with a JCW turbo, a Riss Racing 2.5" catless downpipe, K&N Typhoon intake and the Accessport set on stage 1 with the map for 91 octane with no adds and factory throttle settings. Running Shell 91 Octane I'm still getting some light knocks when under high boost, when its hot. Since I live in Phoenix that's not much I can do. I tried the linear throttle map and it was too on/off for me. Any suggestions to get rid of the knocks? I know for stage 2 your supposed to have a 3" exhaust, but I'm running stage 1. Any help is appreciated.
Old May 12, 2016 | 11:37 PM
  #3828
TBui's Avatar
TBui
Do you have 92 octane where you are?
Old May 13, 2016 | 12:32 PM
  #3829
Sstrickstein
This morning I put a three quarter of a tank of 95 octane mixed in with one quarter tank 91. I turned up the tune to 92 octane stage one stock throttle. So far no knocks except for exactly after I filled up. I'm going to leave this tune in for an Autocross tommorow and the. Set it back to 91 octane.
Old May 18, 2016 | 04:00 PM
  #3830
MiniJimmyS07's Avatar
MiniJimmyS07
Originally Posted by oldbrokenwind
If you bought the AP used, it's possible the previous owner didn't "un-install" the AP and it's looking for the original owners ECU. Can you verify this with the original owner?
It is unmarried. My ECU was updated by a MINI dealership after a new hpfp was installed back in 2014. I'm thinking that is why it is not working since COBB stopped updating the MINI in 2013.
Old May 18, 2016 | 04:03 PM
  #3831
MiniJimmyS07
Originally Posted by neonsteve
You could also try it out on someone else's car just to see if it recognizes it and installs properly. You could then uninstall it from the car (some call this "unmarrying" it) and try installing it on your car. It can only be installed on one car at a time.
I will have to try that. Problem is, I live in Rapid City, SD and there isn't a lot of MINIs around here. I will have to wait until the club MINICOW comes here or when MTTS gets here thus summer.
Old May 18, 2016 | 05:42 PM
  #3832
DneprDave's Avatar
DneprDave
Was your Accessport married to the ECU when you brought your MINI into the dealer?
That's not a good thing to do!
Old May 19, 2016 | 05:36 PM
  #3833
mbwicz's Avatar
mbwicz
Today I tried to update my AP on a laptop that I just updated to windows 10. I got an error that said to update the AP on an older version of windows (or an apple). This worked for me, and I just wanted to share this with others.
Before you update to windows 10, make sure that you update your AP (or have an older PC around to update it on).
Have fun,
Mike
Old May 19, 2016 | 07:03 PM
  #3834
bugeye1031's Avatar
bugeye1031
Moderator
Have fun,
Mike
That's bad news.....I wonder if Windows 10 has some sort of compatibility mode...
http://windows.microsoft.com/en-us/w...ersion-windows
Old May 19, 2016 | 07:04 PM
  #3835
bugeye1031's Avatar
bugeye1031
Moderator
Originally Posted by chav
okay I read pages 1-20 trying to find related problems they might cause. my car will do one full pull fine and peak at 15 for boost ( shouldn't it be more?) then I will get the code p2885. I have uninstalled the tune and a couple hours after I still got the code. In the morning I have still not been able to get the code doing 10-120 pulls 40-100 anything that could get it back and cant get it to pop up. Feb 10th I have plans to drop her off at mini for a look. if anything I'm getting the heat shield replaced and hood scoop.
also I do have a leak at the downpipe where it connects to the turbo could that be a problem?
I have a 2009 fjcw with cold air intake and catless downpipe
Did you ever find a solution?
Old Jun 2, 2016 | 07:00 PM
  #3836
Dr. Spade's Avatar
Dr. Spade
P2885 I remember was a diverter valve issue. Mine was sticking. Could be something else but changing my diverter valve fixed it and the 2 other codes that came up.
Old Jun 2, 2016 | 07:02 PM
  #3837
Dr. Spade's Avatar
Dr. Spade
Anyone here run into super knock on stage 2 or 3 tunes? Even on proper mods. I'm afraid to go anything but stage 1
Old Jun 3, 2016 | 12:21 AM
  #3838
Sstrickstein
I've got a JCW turbo, a Riss Racing 2.5" down pipe without cat and a k&n typhoon and I'm getting knocking under acceleration on on ramps to the highway only under slow roll in tuned with the stage one 91 octane tune with no mods and stock throttle. I've to have wondered. But I ran a tank of 95 octane and it went away. It's summer in Arizona so I'm going to go back to a stage zero for now to avoid this. Screw the CEL.
Old Jun 14, 2016 | 11:50 AM
  #3839
Dr. Spade's Avatar
Dr. Spade
Did you go full throttle at lowish RPM while on tune?
Old Jun 14, 2016 | 11:55 AM
  #3840
Richieb0y28's Avatar
Richieb0y28
I've been running stage 2 for 3 years now. No issues - and I've driven it all over the RPM spectrum.
Old Jun 14, 2016 | 09:47 PM
  #3841
Sstrickstein
I ran a carbon cleaner though the oil and changed it. I also have been running better fuel and the linear throttle setting and 91 stage one tune. I only get knock under top gear heavy load role on like with a sudden snap in the throttle. It goes away with high octane like 95 octane.
Old Jun 15, 2016 | 09:25 AM
  #3842
Dr. Spade's Avatar
Dr. Spade
The tunes I've had 0 issues with are Stage 1 and Stage 1 FMIC.
I did some internal damage by not having the proper mods while running stage 2 (decatted stock exhaust).
Not sure why I got an issue on Stage 3 (full 3" turbo back with high flow cat in DP) and FMIC. But once I went back to Stage 1 FMIC, no issues other than CEL for O2 sensor.
Old Jun 16, 2016 | 07:37 PM
  #3843
NeonLed's Avatar
NeonLed
I had the same problem a month ago. The car would knock above 11psi in 3rd or 4th. I was reading up on colder plugs and pulled the trigger on theses https://www.ngk.com/product.aspx?zpid=9815. Manic recommends them for their stage 2. Car pulls hard and hasn't knocked since I put them in.
Old Jul 12, 2016 | 10:06 AM
  #3844
Dr. Spade's Avatar
Dr. Spade
So perhaps my problem on Stage 3 was just blow by. Installed an oil catch can on Sunday and haven't gotten the hiccup since.
Curious, what peak boost numbers are you seeing? On stage 1 FMIC I saw 18 which I thought was high. Yet on Stage 3 it was 18.8. Felt faster on 3, perhaps a little more top end as peak boost occurs between 3-4K
Old Jul 12, 2016 | 08:51 PM
  #3845
Sstrickstein
With my JCW turbo I'm getting 20-21 pounds boost peak. 239 hp on the dyno. Problem was using shitty gas. Started using chevron instead of circle or shell and almost no knocks.
Old Jul 19, 2016 | 08:19 AM
  #3846
Dr. Spade's Avatar
Dr. Spade
So it's a lot faster on stage 3. More than 0.8PSI of peak boost would imply.
I went back to stage 1 since I was getting code 2885 on stage 3. Likely due to wastegate not performing optimally.
Old Jul 19, 2016 | 08:22 AM
  #3847
Sstrickstein
Yeah 2885 seems to always be related to bad waste gate or linkage.
Old Jul 25, 2016 | 11:03 AM
  #3848
spjonez's Avatar
spjonez
On Wednesday I'm receiving a used Accessport and the manual is not included. After I plug it into my computer and check for firmware updates are these the correct steps to use it:
1) Plug it into my car to identify my ECU since it's a different car
2) Plug it back into my computer to search for maps
3) Plug it back into the car to flash a map
When they say to turn the car on but don't start it, I'm assuming they mean insert the FOB but don't push the start button, turn all accessories off (AC, stereo, etc), flash, remove FOB, remove AP, insert FOB, wait 5s then press the start button?
I'm currently on the lookout for an intercooler otherwise my car is stock (engine wise). From what I've read I should flash stage 1, then stage 1 FMIC when I install one, is that correct?
Thanks!
Old Jul 25, 2016 | 11:37 AM
  #3849
oldbrokenwind's Avatar
oldbrokenwind
Sounds about right ---
I get this instruction when resetting the ECU or changing maps. My process is:
1) Insert FOB and press "Start" button, WITHOUT allowing engine to start.
2) Ensure all accessories are off.
3) Proceed with desired task.
AP can be connected either before or after step 1, just gotta allow time for it to recognize the ECU. The AP will prompt you how to proceed when it completes the task.
Each map will display a description of its requirements. You should not use a map unless your car is equipped as the map requires. You should find there are several "Stage 1" maps available. Also a "Stage 0", probably for un-modified cars.
Thanks!
Good luck ---
Old Jul 25, 2016 | 11:43 AM
  #3850
spjonez's Avatar
spjonez
When I insert the FOB the interior lights come on then when I press the "Start" button the engine starts (2009 Mini Cooper S). How do I press the "Start" button and not have the engine start?
I'm going to be very conservative with maps until I have more modifications done. I'm assuming there's a stage 1 map I can use since that's what the screenshot on page 1 of this thread shows on a 2010 Mini Cooper S. I will definitely read the requirements first
Thanks for the help!
