Drivetrain Blow Off Valves
Old Apr 27, 2008 | 11:05 PM
silversmoke06's Avatar
silversmoke06
Blow Off Valves
What Is there know know about them is there any better aftermarket ones?
Is their Upkeep to be done on them. and The supercharger How often is the reccomended oil change lifespan Im at 60k and i dont want it to die on me.
I know mini and everyone says non serviceable but i dont beleve that.
So what do i do and what oil do i use
I kinda would like a little bit louder BOV though.
Old Apr 27, 2008 | 11:19 PM
AZblackOUT's Avatar
AZblackOUT
Blow off valve? You turbo? Do you mean Bypass Valve?
Old Apr 27, 2008 | 11:23 PM
billzcat1's Avatar
billzcat1
No such thing as a blow-off valve on a Roots-charged Mini. Since the throttle body is upstream of the "compressor", there are no pressure spikes associated with closing the throttle body and therefore no need for a blow-off valve.
Minis do have a bypass valve which functions differently than the bypass valve on a turbocharged car - in this case they exist primarily to bypass the blower at light/part throttle so that the engine can consume air without having to move it through the blower. This in turn creates significantly better economy at the expense of on-throttle boost propagation. It slightly reduces the lag between matting the pedal and boost being generated... to the tune of 100-200 milliseconds.
You can get upgraded bypass valves but mostly what they do is hurt your fuel economy while providing no additional horsepower and very slightly improved throttle response.
Old Apr 27, 2008 | 11:28 PM
silversmoke06
Yeah i ment bypass valve
And i just like the noise when i shift.
If i get worse gas milage its totaly out.
i was unsure if it would need to be maintained
as with the supercharger
Old Apr 27, 2008 | 11:32 PM
MJohnson81's Avatar
MJohnson81
The bypass valve won't give you any different noise as far as I know, but it will hurt your gas milage. As far as the supercharger they are susposed to last up to 100,000 miles, so you have a lot of miles left.
Old Apr 27, 2008 | 11:39 PM
silversmoke06
No oil changes on that thing? i hear that talked about alot.
Old Apr 27, 2008 | 11:58 PM
billzcat1's Avatar
billzcat1
The bypass valve will actually make less noise at part throttle if you have an intake. That familiar whistle will go away at very light throttle.
Sorry, can't answer about the oil changes. I wish Roots had a pressure-fed lubrication system.
Old Apr 28, 2008 | 12:11 AM
UKSUV's Avatar
UKSUV
The Mini has the bypass valve directly on the throttle body which suck total ****. What I have told a few people was to plumb a Forge or EVOMS diverter valve from a 1.8T. You can put stiffer springs in it to push a little bit more boost.....
silversmoke06
I have an intake its just a big *** foam air filter element in a box.
and i hear it all the time.
i dont mind the little sneesing noise when i shift i rather like it.
Old Apr 28, 2008 | 12:17 AM
silversmoke06
but ill get crap milage right?
and how hard is it to do that?
Old Apr 28, 2008 | 12:22 AM
UKSUV's Avatar
UKSUV
I dont know...Ive never done it (can't since Im JAC)... . But Im sure its doable since the BMW guys use stuff like that on the AA SC kits.....
Old Apr 28, 2008 | 12:51 AM
silversmoke06
AA supercharger kits?
Old Apr 28, 2008 | 12:57 AM
UKSUV's Avatar
UKSUV
Active Autowerke....BMW's...they do nothing MINI....I also have a BMW 3 and a VW Touareg so Im on quite a few forums....
Old Apr 28, 2008 | 11:49 AM
jtack's Avatar
jtack
I have the Detroit Tuned Bypass Valve. It gave noticable quicker boost response. Tap the gas just a little and it will go into boost. Loss in mpg was maybe 1 mpg if any at all. I still get very noticable intake whistle. Not hard to install.
Old Apr 28, 2008 | 02:24 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
NVm
PsychoRallye
21
Feb 17, 2019 06:08 AM
olson187
Oct 21, 2015 05:25 AM
Fordgt4
Oct 10, 2015 10:42 AM
Southern Marylander
Oct 1, 2015 07:53 AM
Nicefeet
Sep 24, 2015 06:53 PM
