Drivetrain Official ALTA™ Q&A thread PART TWO 2nd Generation MINI
Old Oct 18, 2007 | 02:04 PM
  #301
ALTAPerformance's Avatar
ALTAPerformance
ez to fix. Loosen the clamp. Pull the tube back to where it is supposed to be. Tighten clamp.
adam@altaminiperformance.com
Old Oct 18, 2007 | 02:46 PM
  #302
jascooper's Avatar
jascooper
All done... Man that sucker was hot, even after a half hour sitting in the driveway.
Old Oct 18, 2007 | 04:43 PM
  #303
Xray'dit_Mini's Avatar
Xray'dit_Mini
mine kept working loose every couple of days. You have to make sure there isn't any "pre-loaded" tension along the length of the tube. check the connection at the MAF, coupling, and filter. After a couple of trys I managed to make it stop working off. No matter how tight I got the clamp, it still worked itself loose until I fixed the rest of the connections.
Old Oct 18, 2007 | 05:51 PM
  #304
r56mini's Avatar
r56mini
I haven't checked mine yet but I hope it is not crooked like that.
BTW, get a rear swaybar. I will make the car turn unbelieveably.
Old Oct 18, 2007 | 05:59 PM
  #305
jascooper's Avatar
jascooper
MAF????
Old Oct 18, 2007 | 06:06 PM
  #306
MotorMouth's Avatar
MotorMouth
Originally Posted by jascooper
MAF????
That thing the hose wasn't attached good to.
Old Oct 18, 2007 | 06:21 PM
  #307
jascooper's Avatar
jascooper
So you're saying I may have to adjust the other end of that thing (where it attaches to the filter housing) to keep it from recurring?
I have a rear swaybar (or to be specific, a different rear swaybar. All R56's have rear swaybars). I don't think the car turns any better now that I've straightened out the inlet tube (or whatever that's called).
Old Oct 18, 2007 | 07:13 PM
  #308
r56mini's Avatar
r56mini
What made you go with Mach V springs instead of H&R?
Old Oct 18, 2007 | 07:46 PM
  #309
jascooper's Avatar
jascooper
About 0.2 inches less drop, price, and not liking to follow the crowd.
Old Oct 19, 2007 | 06:55 AM
  #310
ALTAPerformance
OUCH! (Side note: I honestly don't see much if any difference in the drop, and since we are in the ALTA thread I am going to make a plug for the product we carry. The H&R is a known company that has been doing this for MANY decades. They are known for there extremely high levels of quality, R&D, manufacturing principals & techniques, as well as the assembly point for many of bilsteins shocks, OEM applications etc. etc. Having been in the performance aftermarket sine 1996 I have seen so called spring "manufacturers" come and go, but yet H&R is still here. So in addition to running their springs and lowering modules on nearly every car I have owned in the past 7 years, NSX's, M3, Ferrari 360, MINI's, Subaru, Escalade, Mercedes, Honda's Integra Type R, the list goes on, I have never had any complaints with ride quality, performance etc. Plus the liftetime warranty from a known German manufacturer always seals the deal for me. I am glad you are happy with your choice, but in many cases following the crowd can be a VERY good thing. Look at the crowd of monkey's you are in with now that you own a MINI! Not so bad is it?)
Back to the inlet tube, it should not re-occur once it is placed properly. The hose has a notch in it that needs to be lined up with the inlet hose. Then when you put the clamp on be sure the notch in the clamp also lines up with the notch in the hose etc. etc.
Thanks guys and gals. Happy motoring!
Adam@altaminiperformance.com
Old Oct 19, 2007 | 08:27 AM
  #311
jascooper's Avatar
jascooper
Are you kidding? It's pure torture! Put them behind the wheel and they transform into humans. But in front of a computer...
Old Oct 19, 2007 | 09:18 AM
  #312
MotorMouth's Avatar
MotorMouth
give us enough time and you'll have the complete works of shakespeare.
Old Oct 19, 2007 | 11:27 AM
  #313
rattmobbins's Avatar
rattmobbins
LMAO!!!
Old Oct 19, 2007 | 12:15 PM
  #314
scott48's Avatar
scott48
you guys need to update the website for all the new stuff, like BOV, MAF to turbo tube, etc.....then boost gauge!!!........................then ecu!!
Old Oct 19, 2007 | 01:53 PM
  #315
ALTAPerformance
Working on it! Sorry for the delay!
Old Oct 19, 2007 | 02:37 PM
  #316
jascooper's Avatar
jascooper
And now we return to our regularly scheduled program "Chatting with Scott and Adam."
Sorry, I just had to say that...
Old Oct 20, 2007 | 02:33 PM
  #317
scott48's Avatar
scott48
I love that show, I tivo it everytime......anyway; I know our turbo is a BorgWarner one, but I was just wondering if it use ball bearings?
Old Oct 20, 2007 | 10:30 PM
  #318
byhsu's Avatar
byhsu
Is the UP Pipe the same as the Boost Tubes you guys sell?
Old Oct 21, 2007 | 07:09 AM
  #319
a96bimmerm3's Avatar
a96bimmerm3
Journal bearing k03 twin scroll.. good ol KKK, gti/audi turbo with twin scroll opening. Looks like its GT series time!
Old Oct 21, 2007 | 08:04 AM
  #320
chili_red07's Avatar
chili_red07
Would adding the 19mm rear sway bar to an otherwise stock suspension make sense, or would I be better off with new springs? I'm not looking for a drop, just some increased cornering.
Old Oct 21, 2007 | 08:11 AM
  #321
jascooper's Avatar
jascooper
Originally Posted by chili_red07
Would adding the 19mm rear sway bars to an otherwise stock suspension make sense, or would I be better off with new springs? I'm not looking for a drop, just some increased cornering.
Probably one of the cheapest, most effective ways to improve handling. I just put on an Alta 19mm. You'll notice the difference on the first curve. Also rather easy to install.
It also will not diminish comfort AT ALL (like springs will).
Old Oct 21, 2007 | 08:17 AM
  #322
chili_red07
Sweet!!! Thanks for the insight! (sorry checkbook!)
Old Oct 21, 2007 | 09:29 AM
  #323
scott48's Avatar
scott48
okay....too bad it's not a ball bearing one.
Old Oct 21, 2007 | 11:53 AM
  #324
lttletimmy's Avatar
lttletimmy
Do you have the factory stock or sport suspension? 18mm to 19mm (sport to alta) doesn't seem like it would make all that much of a difference so I've been leaning towards the 22mm for that reason.
Old Oct 21, 2007 | 01:10 PM
  #325
jascooper's Avatar
jascooper
18 to 19mm isn't that big a difference. It's how far from the center of the bar the endlinks mount. The closer you get to the bar the more effect you'll get. If I recall correctly, the Alta 19mm is from 117% to 178% stiffness of stock depending on which hole you mount it in (choice of 3).
Unless you're a pretty good driver, a really stiff bar could be difficult to control, and you'll be chasing your **** end up the road whenever you lift off the throttle in a curve.
