Drivetrain Intercoolers
Old Jul 13, 2007 | 11:07 AM
  #201
cooperdanR53's Avatar
cooperdanR53
That makes sense, but it eludes my question
Old Jul 13, 2007 | 11:09 AM
  #202
Dr Obnxs's Avatar
Dr Obnxs
It depends...
on how long you run the pump for . All cars today can run the radiator fan if needed after shut off. They don't drain the battery too much. If you're not running a lightweight racing battery, there are no problems. If you have it set up with a switch and forget to turn it off, then yes, you will eventally need jumper cables.
Matt
Old Jul 13, 2007 | 02:44 PM
  #203
herbie hind's Avatar
herbie hind
Originally Posted by british RACING green
My earlier post was definetly directed to the f1 engine and as to wy they use an a2a vs a w2a. I think this is good knowledge to keep in mind though when comparing the two. Also the amount of water that is used in a w2a has to be taken into account when looking at w2a's. The less water that the system uses the quicker the water will heat up. Also does anyone know at what point the temp of the charge air has to be before it starts to really adversely affect the performance? LIke a scale or graph or something would be great and would really help to show just which system is better for all around driving vs' racing around a track. And why does m7 use the dfic instead of creating a w2a, their products are always so thought out, there must be a reason?
um ... they were first to do dfic? thus they got the "new thing" momentum .? plus there were already some pretty good w2a kits available .
Old Jul 13, 2007 | 03:01 PM
  #204
Tüls's Avatar
Tüls
Turbius Maximus
correction... Alta was the first.. but M7 was the first to release it....
Old Jul 13, 2007 | 04:08 PM
  #205
TonyB's Avatar
TonyB
Because they were the first to post here on NAM (a prototype), Alta was apparently the first, according to some . I had photos from M7 before that, but such a discussion is asinine, I feel... M7 was first to market, and that aspect, is not debatable.
The reasons I have not considered a water system:
- Pricing at tpyically 2x, or more
- Not a 20-30 min install, and might require professional installation (mo $)
- Certainly more weight on an already nose-heavy car...
- Another heat exchanger in front of the radiator
I've got money to spend on my MINI, and I would be willing to entertain disregarding the above mentioned concerns if there was very compelling evidence that a water system delivered hands-down noteworthy gains over air. It seems that at best it is better in only certain situations. If water is lost, or vaporizes (yes, that seems to happen), the IC quickly becomes wickely hot. Given the above associated "costs," I'll pass... as the tradeoffs don't make it wortwhile, for me at least.
Factor in that if anything non-CARB goes on my MINI, I want it to be easily removable, or at least highly stealth. This does not qualify there as well. Just one's cost/benefit analysis...
Old Jul 13, 2007 | 04:18 PM
  #206
Tüls's Avatar
Tüls
Turbius Maximus
I retract... if that is the case... MY BAD!
Old Jul 13, 2007 | 04:22 PM
  #207
ChrisW's Avatar
ChrisW
Would you people get over the weight IT DOES NOT MATTER. DO THE MATH.
Old Jul 13, 2007 | 04:23 PM
  #208
JIMINNI's Avatar
JIMINNI
Good points .
Old Jul 13, 2007 | 04:30 PM
  #209
Dr Obnxs's Avatar
Dr Obnxs
But remember...
Tony has taken weight reduction very, very seriously on his car. One individual part isn't much of a big deal, but tons of parts do add up.
Matt
Old Jul 13, 2007 | 04:32 PM
  #210
TonyB's Avatar
TonyB
Weight does matter, especially for those concerned about performance; as I think most should be who post here (NAM's "performance" forum). This is so b/c the MATH does bear this out...
Tuls, no biggie man.
Old Jul 13, 2007 | 04:33 PM
  #211
ChrisW's Avatar
ChrisW
Matt
I agree if you add little things here and there next thing you know you've added 200 LBS and that does matter.
Old Jul 13, 2007 | 04:34 PM
  #212
Dr Obnxs's Avatar
Dr Obnxs
I surely hope..
that the ALTA/M7 DFIC debate is lost in the fog of history for good. We'd all be better for it.
Matt
Old Jul 13, 2007 | 04:58 PM
  #213
TonyB's Avatar
TonyB
Agreed Matt!
I see these guys are posting from Fresno, so they know about heat!!! I can appreciate the concern guys.
If I was building a MINI for the dragstrip, for some city stoplight fun (disclaimer: not condonig this), or do be a dyno star, a water system does make sense for sure. Ice, ice baby!
As Matt said some time ago, this is all full of compromises, as is life. The DFIC (as the Alta v2) is an attempt to obtain some of the virtues of an FMIC, while staying in the stock top-mount location, and eliminating some of the drawbacks (cost, complexity of install, and pressure loss due to extra plumbing). The current DFIC was designed for the street, and from what some have noted, including research from Matt, and some limited evaluation from myself, it serves that purpose quite well (better than my improved GRS system and stock IC with larger scoop). It seems that with higher output engines, and under harsher conditions, the DFIC doesn't shine as well. It sounds as though Peter of M7 is having another DFIC made for these purposes. As for me, for my 15 or so minute canyon bursts and/or commutes, the DFIC, at least with my current mods, is the best I've had...
Old Jul 13, 2007 | 05:12 PM
  #214
JIMINNI's Avatar
JIMINNI
Agreed Matt!
Was a cool 95f. here today .
Old Jul 13, 2007 | 05:20 PM
  #215
Tüls's Avatar
Tüls
Turbius Maximus
Matt
yeah for sure.... sorry about that that prolly came off wrong....
Old Jul 13, 2007 | 05:26 PM
  #216
TonyB's Avatar
TonyB
My undergrad football team scouts Fresno talent (namely the Clovis schools) very well, so I make it a point to visit Fresno during the Fall sometimes, and it is always HOT!!! It actually hit the 90's here today also... Keep cool.
Old Jul 13, 2007 | 05:43 PM
  #217
JIMINNI's Avatar
JIMINNI
Late fall here in Fresno we all get that free mist injection for our IC's, its called "tule fog" . I,m sure you have experianced it .
Old Jul 13, 2007 | 07:38 PM
  #218
MINICHEF's Avatar
MINICHEF
NOW IF I COULD ONLY SEE WHERE I WAS GOING WHILE GETTING ALL THIS FREE INJECTION
Old Jul 13, 2007 | 10:22 PM
  #219
Longboard Mini's Avatar
Longboard Mini
I know the tule fog all to well. I lived in Auburn for a short while and drove to Fresno for jobs a few times. You can not explain how thick that fog is.
It was 94 here in Rancho Santa Margarita today. I am looking for a better IC and will be testing the laminova W2A for RMW's very soon. Jan has some really great ideas and is the only guy I know crazy enough to to see then to completion.
I do love my WMI system for days like these. It's progressive and tunable for days like this.
Longboard
Old Jul 13, 2007 | 10:24 PM
  #220
Revolution Mini Works's Avatar
Originally Posted by Longboard Mini
I know the tule fog all to well. I lived in Auburn for a short while and drove to fresno for jobs a few times. You can not explain how thick that fog is.
It was 94 here in Rancho Santa Margarita today. I am looking for a better IC and will be testing the laminova W2A for RMW's very soon. I do love my WMI system for days like these. It's progressive and tunable for days like this.
Longboard
Meet me at Cars & Coffee tomorrow and I will bring the W2A over
Wait til you hear the GP with the new Custom RMW exhaust and "special" collector made for the JCW head
Old Jul 13, 2007 | 10:29 PM
  #221
Paul Webster's Avatar
Paul Webster
Jan Shouldn't it be;
"meet me at Las Vegas dragstrip for your first lesson, I'm racing mine and I'll give you a few pointers Longboard"
Old Jul 13, 2007 | 10:46 PM
  #222
Longboard Mini
Oh Paul, what you don't know about me as that I have been driving and racing things with engines since I was 4. I don't need a lesson, just a little push to smash your record. Man it's going to feel gooooood.
Jan and I did a little racing today along with six other friends. Man that was fun.
Longboard
Old Jul 13, 2007 | 10:50 PM
  #223
Longboard Mini
I will be there at 7am. The boys are coming and looking for breakfast burritos.
I added a couple things to the car tonight .
Longboard
Old Jul 14, 2007 | 09:26 AM
  #224
SpiderX's Avatar
SpiderX
Matt
The water pump on the 62 runs for 5 minutes after the car shuts off 20K mi with no problems..... this pump is much larger than the water pump for and IC
Old Jul 14, 2007 | 02:27 PM
  #225
UKXPAT's Avatar
UKXPAT
Originally Posted by RandyBMC
To answer an earlier question - I use the Gintani on the Mule. With the TK kit, it was starting to heat soak on the track in Summit Point, where the ambient temps were considerable. What is heat soak? Well, I define it as the point at which the system can no longer maintain temp, so it continues to climb or remain the same after load - no reduction after load drop. Once that happens, you are hosed, as the ECU will start to dump fuel at a predetermined IAT, and you trash the air/fuel ratio. It wasn't so bad that I would change it, as it only required momentary load shed to reduce the temp again (which is what I was doing on the straight with Steve right behind me!).
Without the load of the TK kit, I never saw any problem at all, mostly due the larger reservoir I use on the Mule - which is key to a w2a.
What I've seen is that there are few units on the market that really work, and several that are much worse than stock.
In the case of intercoolers, so far, you really do get what you pay for. The Pace and Gintani are a couple of the few that work.
Hope that helps!
Randy
TK Kit?
