Drivetrain Project X-300
Old Jul 2, 2007 | 12:40 PM
  #201
JIMINNI's Avatar
JIMINNI
Originally Posted by Revolution Mini Works
Must not tip hand
I saw a 65 bug Convertable this weekend, think he said it was 2600cc, slapped a turbo on it, 296 WHP , car weighs less than 1800 lbs. 10+ sec qtr. mile. Point and shoot .
Old Jul 2, 2007 | 12:48 PM
  #202
Longboard Mini's Avatar
Longboard Mini
I built three of those along time ago. I was a big VW guy.
Very fast but you never knew if they were going to stop .
Longboard
Old Jul 2, 2007 | 05:59 PM
  #203
Mini Fireman's Avatar
Mini Fireman
Jan,
Will there be different pulley sizes available or will you set the pulley size by what max rpm the motor will be tuned to run? Maybe the better question is how do you plan to determine the best pulley size to run?
Old Jul 2, 2007 | 06:15 PM
  #204
Revolution Mini Works's Avatar
Originally Posted by Mini Fireman
Jan,
Great questions Mark,
We will have 2 versions of the rotrex
Stroker version= lower RPM , torque setup
1.6L version= 8k rev with high end
Old Jul 2, 2007 | 06:23 PM
  #205
Mini Fireman
I need you to go ahead and move out here to Indy, Jan. Lots of Motorsports here to immerse yourself in. There's even a little racetrack nearby that's kinda famous. Let me know if you need help packing?
  #206
Partsman's Avatar
Partsman
Legion_of_Doom
Does that mean the stroker version can only be used with your engines that have an increased stroke?
or
is that just what you call it because stroker engines are normally low RPM and setup to make torque?
Old Jul 2, 2007 | 06:27 PM
  #207
or
the stroker will run a bigger Rotrex than what we are using on Longboards.
We expect the stroker to be for guys wanting the ultimate torque machine.
Of course I have more projects underneath the radar and have another secret engine being built. Don't ask, as I am not ready to release info on it.
Testing begins shortly on the new street torquer series of M45 projects.... oops maybe I should do another thread?
Old Jul 2, 2007 | 06:49 PM
  #208
Partsman's Avatar
Partsman
Legion_of_Doom
Sounds good, but around here I would need the 1.6l version as there is always "testing" with the local Hondas, Acuras, Subarus, etc
Don't worry, I won't ask. I'm good with just sitting back to see what comes out next.
Old Jul 3, 2007 | 08:24 AM
  #209
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Man I wish you needed a 04' S to be a mule...if you ever do send me a PM Jan. My car is just begging for more money to be bolted on. hahaha
Old Jul 3, 2007 | 08:31 AM
  #210
MSFITOY's Avatar
MSFITOY
Hot Dam
What's the rev limit on the stroker version Jan?
Insert parts under open bonnet...
Old Jul 3, 2007 | 09:04 AM
  #211
Originally Posted by MSFITOY
Hot Dam
sure,
insert credit card in proceesing terminal!
Old Jul 3, 2007 | 01:10 PM
  #212
MSFITOY's Avatar
MSFITOY
sure,
You're funny Jan...What are "we" doing in the future? DOH! You guys didn't hear that...
Old Jul 16, 2007 | 02:13 PM
  #213
curv872's Avatar
curv872
Updates?
Old Jul 16, 2007 | 02:39 PM
  #214
Longboard Mini
Originally Posted by curv872
Updates?
I have put about 2000 miles on the kit and it is running great. We are waiting to get our hands on a Hydra from Alta to start tunning the little beast. We are boosting to 18LBS but we might end up at 20.
I'm expecting really good things once the tune pulls it all together. The car pulls crazy fast to red line. I just added a new Clutch Master stage 3 clutch and lightweight flywheel. I also added an OBX LSD. Yes, I said OBX. I figured for $399.00 why not give it a try. So far it's great. It made a huge improvement on how the car pulls coming out of turns. I also hooked my WM system back up which made another nice improvement.
Once we get the tune done I will get it on the dyno and post the numbers. It should be any day now I hope.
Then I have a date with the 1/4 mile.
Longboard
Old Jul 16, 2007 | 02:43 PM
  #215
mozzarella's Avatar
mozzarella
Longboard
Is Jan your broker?
Old Jul 16, 2007 | 02:54 PM
  #216
Longboard Mini
Originally Posted by mozzarella
Is Jan your broker?
No I just have bazillions in the bank.
Longboard
Old Jul 16, 2007 | 03:06 PM
  #217
Paul Webster's Avatar
Paul Webster
Longboard
Yahhooooo looks like I'll be bumped into 4th then
Old Jul 16, 2007 | 03:33 PM
  #218
Longboard Mini
4th? Who are the other two?
Is Marry going to hit the track?
Longboard
Old Jul 16, 2007 | 03:38 PM
  #219
Paul Webster
Hubie and Brian
Old Jul 22, 2007 | 10:07 AM
  #220
Mini Mizer's Avatar
Mini Mizer
Longboard
Thats why you got to do the porsche disc brake conversion.
I cant help but get excited about people talking about VW's. I plan to build one in the future.
Heres the worlds fastest street-legal, all steel VW Bug.
http://www.vwtrendsweb.com/features/...beetle_ragtop/
2.3L with a monster turbo pushing out 500bhp. Running a 10.06 in the quarter.
anyways enough of the VW stuff. Keep the MINI updates comming.
Old Aug 3, 2007 | 04:05 PM
  #221
MINIAC's Avatar
MINIAC
Is this kit going to be CARB certified
Old Aug 3, 2007 | 05:00 PM
  #222
Mini Fireman
That would not be cheap to have certified. I wouldn't hold your breath.
Old Aug 3, 2007 | 05:18 PM
  #223
typer139's Avatar
typer139
The Fireman's right... it also wouldn't be very quick.. it's a very slow process.
Old Aug 5, 2007 | 10:56 AM
  #224
wilhelmh's Avatar
wilhelmh
So if the system doesn't get CARB-certified, does that mean that a prospective Rotrex owner in Massachusetts--let's call him "Hans"--would fail his vehicle inspection?
FYI, CARB regulations also apply in MA....
Old Aug 5, 2007 | 11:50 AM
  #225
gnatster's Avatar
gnatster
Probably depends on CARB is interpreted in MA. IF all you really need to do is pass a sniff test then mostly it would pass assuming you run a decent cat and have a good tune. Now if they start peeking under the bonnet, all bets are off.
