Drivetrain Project X-300
Old Mar 8, 2008 | 09:54 AM
  #851
mcs22004's Avatar
mcs22004
Tempting. You get turbo-like efficiency but roots-like throttle response--good for about 300hp(?). Kudos to Longboard Mini for donating a MINI to science.
It will be interesting to see how it works out over time, but for all the effort I might be inclined to go with a turbo and go way north of the target output for this project.
Old Mar 8, 2008 | 10:00 AM
  #852
mcs22004's Avatar
mcs22004
Originally Posted by JIMINNI
Cool thanks Not a bad price. What kind of performance did they say it will do? Also is it "CARB" legal?
If you want more info, the R53 and other CAIs have been discussed ad nauseum in the M7 CAI thread.
Old Mar 8, 2008 | 11:50 AM
  #853
Bahamabart's Avatar
Bahamabart
In theory the roots should produce tq sooner than the rotex BUT RMW/Longboard will be able to tell us what that gap is shortly. Its a question I raised a while back w/ Jan who at the time did not know because of the early stages. The other thing to bear in mind is the performance of a rotex w/ head, cam , header, ect.......................
Perhaps Longboard would be willing to strip all the other goodies off and give us some plain old rotex numbers
Old Mar 8, 2008 | 11:52 AM
  #854
Bahamabart's Avatar
Bahamabart
In theory the roots should produce tq sooner than the rotex BUT RMW/Longboard will be able to tell us what that gap is shortly. Bear in mind that th erotex will produce linear TQ so at some point it has to produce more TQ than the roots. Its a question I raised a while back w/ Jan who at the time did not know because of the early stages. The other thing to bear in mind is the performance of a rotex w/ head, cam , header, ect.......................
Old Mar 9, 2008 | 11:29 AM
  #855
mcs22004's Avatar
mcs22004
(Moved over from the New Voltage CAI! thread.)
Originally Posted by Longboard Mini
Given the enormity of the TMIC, did Jan consider going to an FMIC?
Old Mar 9, 2008 | 12:25 PM
  #856
newbs49's Avatar
newbs49
Very nice job on the Intake. Like how it matches the other parts and hoses.
Very cool.
Old Mar 9, 2008 | 01:17 PM
  #857
D-MAN's Avatar
D-MAN
WOW!
Old Mar 9, 2008 | 03:21 PM
  #858
Longboard Mini's Avatar
Longboard Mini
No need. The new intercooler cools great. The main reason was to flow more air which it does by double.
LB
Old Mar 9, 2008 | 03:27 PM
  #859
Longboard Mini
Here are more pics.
LB
Old Mar 9, 2008 | 03:39 PM
  #860
GINTANI's Avatar
GINTANI
Quote " In theory the roots should produce tq sooner than the rotex BUT RMW/Longboard will be able to tell us what that gap is shortly. Its a question I raised a while back w/ Jan who at the time did not know because of the early stages. "
The above is not a theory, it’s a fact. Both roots and twinscrew produce more torque through the usable power band than centrifugals. Although a "usable" power band can be questioned by racers, normal driving permits a usable torque band from 2k to about 6k on a Mini Cooper unless you’re Michael Andretti.
This is where things can get interesting. The roots blower will be the first to fall short of torque at upper rpms although it’s very capable in low to midrange torque. Take the example above of a usable torque curve and remove another 1k. Meaning a roots blower will produce more torque compared to a centrifugal from 1k to about 4500 rpms on a Mini.
A twin screw blower again exhibits the same trait of being a torque contender as the roots blower; however being better in design the torque curve will be greater through the torque band. A twinscrew supercharger will produce more torque than a centrifugal and a roots blower from 1k rpms to about 6k rpms.
Now the centrifugal supercharger is pretty different in design compared to its cousins. The centrifugal shares a lot more characteristics to a turbocharger in design and looks. A centrifugal blower makes less torque than both roots and twinscrew in the usable torque band however just like the turbo will make more peak torque at higher rpms. A centrifugal will make a lot less torque in the usable power band of 1k to about 6k but make more peak torque anything higher than 6k rpms.
What’s does all the above really mean.
In straight line acceleration test from start through 6th gear a roots style blower would loose to both centrifugal and twin screw superchargers it’s a known fact.
A centrifugal will fall short in the areas below 6k and prevail in the upper 6k+ rpms. However the centrifugal still has a higher peak number, like any of the above style superchargers eventually once peak torque is produced well it will be downhill from there.
I hope all the information if any helps on clearing up some questions or thoughts on how the superchargers differ from one another.
Old Mar 9, 2008 | 03:45 PM
  #861
newbs49's Avatar
newbs49
Now lets talk about the heat difference between the two as mounted on a MINI.
Old Mar 9, 2008 | 03:54 PM
  #862
GINTANI's Avatar
GINTANI
When we talk about thermal efficiency we should also cover the difference in pressure ratios and how they all reference to heat. Please begin the conversation I think this can be very informative for all.
Old Mar 9, 2008 | 04:25 PM
  #863
cooper99's Avatar
cooper99
So what's your estimated whp now Longboard?
Old Mar 9, 2008 | 05:15 PM
  #864
Revolution Mini Works's Avatar
why after reading this last page do I feel so much smarter?
Old Mar 9, 2008 | 05:17 PM
  #865
PGT's Avatar
PGT
sweet!! now you can go build fast cars Jan!! you've been enlightened
Old Mar 9, 2008 | 05:20 PM
  #866
it's amazing how much I learned today... wonder how I was even able to figure out a system like the Rotrex
wonder how long it is before someone tries to steal this....
Old Mar 9, 2008 | 05:25 PM
  #867
Longboard Mini
I guess they didn't read the whole thread. This has been talked about many many times.
The Rotrex is not your standard centrifugal. Not even close.
Longboard
Old Mar 9, 2008 | 05:34 PM
  #868
GINTANI's Avatar
GINTANI
Im confused where did this conversation go.....We went from talking about superchargers to stealing???????
Sucks Jan who would want to steal your designs and all of your hardwork that bastard should be shot...
My two cents I will keep in my pocket and off this thread....
Old Mar 9, 2008 | 05:42 PM
  #869
Tüls's Avatar
Tüls
Turbius Maximus
I've got a 40 cal, wanna borrow it?
Old Mar 9, 2008 | 05:48 PM
  #870
GINTANI's Avatar
GINTANI
Clarify
Old Mar 9, 2008 | 06:01 PM
  #871
PGT's Avatar
PGT
just when we thought Gintani learned their lesson...
Old Mar 9, 2008 | 06:02 PM
  #872
Longboard Mini
Clarify
What happened to Johan's Mini. You were days into the tune and said the numbers looks really really good and you would post vid and numbers that day. That was over a month ago now? That's got to be one hell of a tune.
Longboard
Old Mar 9, 2008 | 06:09 PM
  #873
GINTANI's Avatar
GINTANI
If your talking about over 300hp on the stock supercharger, then yes you are all correct its one hell of a tune......
Old Mar 9, 2008 | 06:13 PM
  #874
PGT's Avatar
PGT
so, let's see it? you should have the motor all back together by now.
Old Mar 9, 2008 | 06:18 PM
  #875
GINTANI's Avatar
GINTANI
Is that the rumors rofl......I will be scheduling a dynapak dyno test for comparison. Gintani will give you what you want to see no problem.
Johan can you also please post some vid of your car.....Lets end these rumors once and for all.
