3rd Gen FAQs 3rd Gen Common Questions & Answers!
Bimmercode App
Old Feb 16, 2019 | 08:23 AM
  #226
ToolmanMini's Avatar
ToolmanMini
Regarding Rear Fogs as Brakelights:
Great, I got the opposite problem of some folks - I activated the rear fogs, cycled the ignition, then coded the fogs to act with brake lights, and only got the TOP of the main brake lights to work, instead of just the bottom like others experienced. I have a 2016 Mini Cooper S, 4-door hardtop. I used this exact coding in my attempt:
Activate Fog Lights:
3068 NSL_Verbaut = Verbaut
Code first, then cycle ignition, then restart Bimmercode for the below options
to show up
Then do the coding for fogs-as-brake-lights:
BDC_BODY
3065 LceLampMapping4, ED
Funktionen
MAPPING_BREMSL_2_L_OUTPUT
Switch to this
nsl_l (this is the rear fog light choice)
You need to do this for right and left. Above is for left,
For RHS just change the l to r
MAPPING_BREMSL_2_R_OUTPUT
nsl_r
So, I put it back to normal. It's more important to have the main, largest brake lights fully functioning, than to have some extra ones down low. Just throwing my experience and specific model into the conversation.Side note, I couldn't do my all-doors-unlock tweak either, as I absolutely do not have the "VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK" option under 3040.
Old Mar 8, 2019 | 02:16 PM
  #227
BenR.'s Avatar
BenR.
Just found out about Bimmercode, so what OBD adapter are you guys using ?
Central unlock when ignition off
Is it possible in Clubman S 2018 ? How do we know if we have the option under 3040 ? BTW without going into expert mode ?
Does *stu...* Chimes
Possible to make them stop, since I live in Quebec I know its freezing out there dont need the car to tell me...
Or anybody living in Quebec that has one ? :P
Old Mar 8, 2019 | 02:21 PM
  #228
ToolmanMini
I got this one, and it works perfectly with my 2016 Mini Cooper S 4 door hardtop.
Amazon Amazon
Tim
Old Mar 13, 2019 | 07:03 PM
  #229
brunoresendelopes's Avatar
brunoresendelopes
Hello all,Do you know if is there a way to update the maps without inserting the code?
Old Mar 13, 2019 | 07:24 PM
  #230
detours's Avatar
detours
I would love this too!
Old Mar 25, 2019 | 10:15 AM
  #231
BenR.'s Avatar
BenR.
Well I tried it, but unfortunately it doesnt work..... :( I should try to code it again see if it gonna change anything.
On the other hand, had fun with the app deleting the chimes and changing the windshield washing cycle.
Old Mar 30, 2019 | 06:36 PM
  #232
dabusdriver's Avatar
dabusdriver
New here but very interested in the coding here mentioned. I downloaded the Bimmer app, so do you use it by connecting to your F54 car via bluetooth or usb, or do you have to use a laptop or iPad? Thanks for any clues.......
Old Mar 30, 2019 | 06:47 PM
  #233
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Obd port dongle-device, see Bimmercode website for most recent supported devices. No laptop needed, just a phone or iPad.
Old Mar 31, 2019 | 07:40 AM
  #234
dabusdriver
Thank You
Minnie thank you for the info.
Old Mar 31, 2019 | 08:16 AM
  #235
C-Rex's Avatar
C-Rex
Hey folks - I just picked up my brand new cooper s hardtop. I love it but I’m a little frustrated by how the up and down steering wheel buttons work for changing radio stations. I’d like to just press it once to go to the next station, but you need to press up or down then press ok. Any way to code the car to make it just go to the next station (or song If you're streaming)? Also - any way to code full screen CarPlay?
Old Mar 31, 2019 | 04:46 PM
  #236
NBCGLX's Avatar
NBCGLX
When you're streaming from Bluetooth, the up/down arrows bring up a list that you can scroll through (and then hit the OK button to select)? I wish that's how those buttons worked in my car (2019 F57), but instead it just goes to the next/previous song, and it always displays the last song that was playing, not the newly selected one.
Old Mar 31, 2019 | 06:19 PM
  #237
C-Rex's Avatar
C-Rex
In you’re streaming music through car play and press the up or down on the steering wheel button it shows the song name that’s currently playing on the hud or in the small display by the speedo. Then there’s arrows above and below so you need to press one or the other to move to another song. This is the first car I’ve had that doesn’t just go to the next or previous.
Old Apr 29, 2019 | 09:04 PM
  #238
pdx_wee_car's Avatar
pdx_wee_car
Originally Posted by isugoo
Hi guys, does anyone here can help me how to disable the rear arch reflector light off?
Bimmercode found me the front one but they were not be able to find the rear one.
FYI to disable front:
MAPPING_SIDEMARKER_L_OUTPUT = OFF
MAPPING_SIDEMARKER_R_OUTPUT = OFF
I guess nobody has worked out how to turn the rear arch sidemarkers/reflectors off? Sorry for the noob question, but is there a cheat sheet somewhere that I've just completely missed? I've gone through 10 pages here and caught the odd random tip on what to do with Bimmercode, but a pointer towards a full list would be appreciated.
Old Apr 30, 2019 | 02:55 AM
  #239
DeeAitch's Avatar
DeeAitch
Re cheat list the only one I've managed to find is an old one from one of the BMW forums - sorry but that still doesnt have what you are looking for!
https://f30.bimmerpost.com/forums/sh....php?t=1020138
Old May 5, 2019 | 08:22 PM
  #240
isugoo's Avatar
isugoo
I still haven't found how to disable the rear sidemarkers...
Old May 29, 2019 | 12:22 PM
  #241
one2three_us's Avatar
one2three_us
Anyone knows how to code out DDC?
Old May 29, 2019 | 08:40 PM
  #242
TVPostSound's Avatar
TVPostSound
DDC is an integral part of traction control and ABS.
No way to code out.
Old Jun 1, 2019 | 12:37 PM
  #243
cub4bearindiana's Avatar
cub4bearindiana
Hi everyone.
I just got my veepeak OBDCheck BLE adaptor and the full versions of bimmercode.
I have 2015 MCS and it has LED front headlights with the LED alpha like LEDs... I always wanted to use my FOG front lights just with the LED alpa lights without headlights being ON... Is there a way in expert mode to code it?
Any info on that is welcome.. thank You!
Old Jun 1, 2019 | 01:35 PM
  #244
TVPostSound
Originally Posted by cub4bearindiana
Hi everyone.
What is that!
Old Jun 1, 2019 | 02:29 PM
  #245
cub4bearindiana
Originally Posted by TVPostSound
What is that!
My bad. Couldn’t find right word. The LED DRL halo light around the front headlights.
Old Jun 1, 2019 | 03:58 PM
  #246
TVPostSound
Fogs on with DRL/Parking lamps
3068 NSW_EIN_AUF_LDS_STL =Activ (EIN_ AUF means To go on)
Old Jun 1, 2019 | 04:00 PM
  #247
TVPostSound
more for you to play with:
https://www.northamericanmotoring.co...ml#post4330643
Old Jun 1, 2019 | 05:18 PM
  #248
cub4bearindiana
You are the best. Finally got my front fog lights to work DRL, without headlights ON! Thank you much
Old Jun 17, 2019 | 03:02 PM
  #249
Agraz400's Avatar
Agraz400
Is there any way to restore settings back to stock if the original backup file has been lost? Or is there any place to find what all the factory settings should be for the BDC module? Spent many days/weeks trying to code US union jack lights for a US 2019 F56 halogen front/rear car with no luck. Finally got them to function correctly, but only with it throwing a red lighting malfunction error when you brake while the car is in motion. Put the factory lights back in and realized the stock settings backup in bimmercode was lost due to a new phone and not having thought to export the file. Tried to remember what all the stock settings were, but now I'm not sure what might have been changed in one of the many attempts to get the UJ lights working %100. The stock halogen lights now seem to have a flicker on startup, and throwing a right light malfunction warning with the headlamps on.. but the message clears when you hit the brakes. Went back and compared everything I could think of from left to right, and it all seems to be set to the same things, so I really can't see why only the right side is throwing the error. At my wits end, so any help or input to at least get the car back to stock working order is welcomed. Thank you
Old Jun 18, 2019 | 06:31 AM
  #250
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
You should be able to restore from your backup, granted if you coded something after it saved your stock setup it will have been overwritten
