R56 rotors
R56 rotors
I am trying to do a brake upgrade on my R53, I recently purchased some R56 calipers without rotors. I'm trying to find some Brembo cross drilled or slotted rotors, but I don't know if they will fit for the R56 calipers. If I get rotors made for the R56, would I need different lug nuts?
The R56 rotors will most likely have M14 holes and you have M12 bolts so that an easy fit. So long as you have the R56 calipers and you are looking for the correct, stock size, R56 (294mm I believe) rotor you should have no problems.
You're basically putting on the former JCW big brakes option for the R53.
Unless I'm reading this all wrong I don't see an issue.
The stock R56 brakes today are what was the R53 JCW stuff of old.
ie, if you have the R56 stock calipers now you need only to find the stock rotors for any R56 today and you have what was once an 'add-on' to the order of your car called the JCW brakes. Despite having the larger holes for lugs they will fit up just fine and work with the M12 bolts.
As for branding, I doubt you'll find any Brembos. Most will be either oe factory parts or the general aftermaket offerings which are all going Asian imports. The only place I believe you'll score European parts (BMW supplied) will be the Dealer or someone who has removed them for the fit of a new BBK and has no use for them any longer.
Tires, Wheels & Brakes
09-01-2015 12:13 PM
thebordella
08-31-2015 01:37 PM
08-26-2015 10:28 AM
brother i
Tires, Wheels, & Brakes
08-23-2015 01:15 PM
