Roll call - 8"+ wide wheels
Old Jun 11, 2009 | 01:00 PM
  #151
M!N!-ME's Avatar
M!N!-ME
Originally Posted by SHRTSTAK
Hardly ever on NAM anymore but just stumbled across this thread...
Here's mine:
BBS RS
5x130
F: 16x8 ET38-18mm adapter = ET20
R: 16x9 ET50-25mm adapter = ET25
205/40 Falken 512s all the way around.
Thanks to Konky again for the epic camera work.
baaaadddd!!!!
Old Jun 11, 2009 | 01:27 PM
  #152
roofaS's Avatar
roofaS
Freakin' amazing!! Just beautiful!
Old Jun 11, 2009 | 02:13 PM
  #153
Mach V Dan's Avatar
Mach V Dan
Originally Posted by ScottieCoop
quick question I have my eye on a set of BBS LM replicas.
17x8 with an ET45 all round with 205x45x17 tyres.
Whoah, 205/45R17 on an 8"-wide wheel? You're going to have MAJOR stretchiness. (See some of the pictures in this thread.) Is that what you're going for? If you just want to match a tire to the wheel, I'd at least go with a 215, if not a 235. I'd say 225, but there's not much available in 225/40R17.
Will these wheels fit with no problems or are they to wide for hitting the struts or rubbing ??
The wheels will be close to the strut in front, but they should clear by a few mm.
--Dan
Mach V
Old Jun 11, 2009 | 07:20 PM
  #154
SHRTSTAK's Avatar
SHRTSTAK
Originally Posted by UKCoopeR
i like the color combo , looks painful to clean tho!
You have no idea
Originally Posted by M!N!-ME
baaaadddd!!!!
Thank you.
205/45 won't stretch too much on an 8.
Old Jun 26, 2009 | 12:35 AM
  #155
minimyke's Avatar
minimyke
Old Jun 26, 2009 | 09:04 PM
  #156
Type R 564's Avatar
Type R 564
Rota MC
18x8 45et
5mm spacers in front
215/35/18
no rubbing!!!...for now
Old Jun 27, 2009 | 08:52 AM
  #157
Rally@StanceDesign's Avatar
Rally@StanceDesign
More low!
Old Jun 27, 2009 | 09:14 AM
  #158
daemon2's Avatar
daemon2
Is the wheel rubbing on the rear arch - causing the rear arch to pull away from the bodywork?
Originally Posted by minimyke
Old Jun 29, 2009 | 02:02 PM
  #159
D Unit's Avatar
D Unit
Where is everyone buying their adapters to make the BBS RS fit? I want to get some 17" BBS RS but most of them come in 5x114.3. Do they make adapters for these? Is it better to redrill them? Or do I need to look for some 5x130 pattern and buy adapters to make them fit?
Old Jul 2, 2009 | 09:49 AM
  #160
soccerbummer1104's Avatar
soccerbummer1104
did i make a mistake? i am waiting on my TD PR1.2's in 17x8 to come in, but i have a set of bridgestone podenza's (sp?) sitting in the garage that are 225/45/17, should they have been 225/40/17?!?!? i bassed my decision on the fact that stock tires are 205/45/17, was this wrong, or will i be ok? btw, im running stock ride height.
Old Jul 2, 2009 | 10:16 AM
  #161
bonehead04's Avatar
bonehead04
Those sizes should still be okay. Still under 3% diff in rolling diameter. Your speedo will just be slower. Would have been closer to stock sizes with a 40 sectional.
Old Jul 2, 2009 | 10:31 AM
  #162
Rally@StanceDesign
225/45/17 won't be a big issue, but it certainly won't be visually attractive. That's a lot of sidewall for 17's
Old Jul 7, 2009 | 08:38 AM
  #163
SimonTW's Avatar
SimonTW
Image BPS split rims. 18x8's on the rear. Only 7.5 on the fronts though fitted with 215 35 18. Just needs a little more drop on the front though yet.
Old Jul 7, 2009 | 08:50 AM
  #164
M3This's Avatar
M3This
Originally Posted by Type R 564
Rota MC
18x8 45et
215/35/18
You have more room to go down ... Im 18x8 with same tire size as you but +32 Rear and +27 Front and have zero rubbing
Old Jul 7, 2009 | 12:23 PM
  #165
VicSkimmr's Avatar
VicSkimmr
18x8 et 45 w/ 15mm spacers in front, 215/35/18
Old Jul 7, 2009 | 06:23 PM
  #166
Mini Fireman's Avatar
Mini Fireman
True story, but on his 1st gen MINI the clearance is not exactly the same in the wheelwells.
Old Jul 7, 2009 | 10:06 PM
  #167
maxmini's Avatar
maxmini
After about 30 lovely hrs of pulling these apart and re siliconing them etc. I finally put them on the car. I've had them sitting in boxes for about 4 years and recently took the plunge to get the perfect , but not my taste , polished wheels powder coated and mounted with a set of Falken rt 615's that the local rep wanted a review of . The wheels are 17/ 8 and a billet 3 piece by a company in the UK called Super Lite. They have been making race wheels for many years now and have all kinds of styles. I put the first 100 miles on them this weekend to get the shine off them and will go at it harder next weekend but I can already say they will stick a lot better than my other set. This set will be the " faster " option between my " fast " and " fastest " set
Randy
M7 Tuning
These are my " daily drivers " Hamman 17 /8 with BFG KDW/2 rubber.
Old Jul 25, 2009 | 02:03 AM
  #168
howsoonisnow1985's Avatar
howsoonisnow1985
Yo Max what size are those RT 615s with the 17x8s
Old Jul 25, 2009 | 01:50 PM
  #169
maxmini's Avatar
maxmini
Those are 215/45/17
Randy
Old Jul 25, 2009 | 10:08 PM
  #170
howsoonisnow1985
Originally Posted by maxmini
Those are 215/45/17
Randy
Ouww!
Thanks, I was hoping you'd say 225/45 or 235. I just got some Toyo R888s in 235/40-17 to fit on 17x8. I will pray to the Car Gods they fit.
Old Oct 2, 2009 | 10:43 AM
  #171
kcle730's Avatar
kcle730
Rota MC
18x8 45et
215/35/18
Hi type-R, I was wondering, I just bought a set of Motegi Racing 18x7.5, with ET45, is it require to have spacers?? im at stock height right now
Or does anybody noe? Thanks =]
Old Oct 4, 2009 | 09:56 AM
  #172
e30r56's Avatar
e30r56
What tire size are you going to run?
Old Oct 4, 2009 | 06:04 PM
  #173
kcle730's Avatar
kcle730
Hi e30, Im going to be running on 215/40/18, i heard this was the recommended size for it
Old Oct 4, 2009 | 08:37 PM
  #174
e30r56's Avatar
e30r56
Forgot to ask too, r56 or older? I think you will be fine on an r56, but not sure on the older cars.
Old Oct 4, 2009 | 08:45 PM
  #175
kcle730's Avatar
kcle730
oh hahah i have a R53, i been looking around. and this site says it should fit fine with stock height http://www.wheelsmaster.com/rt_specs.jsp
