Roll call - 8"+ wide wheels
Old Oct 8, 2008 | 01:01 AM
  #76
jerjer's Avatar
jerjer
i'm guessing this thread is a good place to ask wide, crazy, unrealistic wheel setup questions maybe?
how much of a difference in stance is a 17x7 +45 vs 17x8 +45, the most important thing i'm trying to understand is how much extra back spacing i can have to clear my brakes. i'm using 17x7 +45 as a test fitment, then i'm gonna run 17x8 wheel, so starting at +45 as a reference point, i can go down in offset (go outward for more back spacing) if it's needed?
hope my question is not too much for this thread? thanks for the help guys~
Old Oct 8, 2008 | 02:23 AM
  #77
maxmini's Avatar
maxmini
I have been using this set of Hammans as my street wheels since 02. They have held up well and I had them powder coated and the lip polished a few years ago.
Randy
M7 Tuning
17/8 Hamman
215/45/17 BFG KDW-2
42 off set
1 3/4" drop on M7 coilovers
Old Oct 8, 2008 | 07:39 AM
  #78
Rally@StanceDesign's Avatar
Rally@StanceDesign
Realize that if you're using a 17x7et45 as the test fitment....the 17x8et45 already has MORE backspacing even though the offset is the same so you will have to take that into account when you test fit.
going down in offset means going down in backspacing. Backspacing isn't the literal meaning of how much space you have for clearance. It's the distance from the inside bead to the mounting face. i.e. Wheel Width/ 2 + Offset = backspacing.
45 will be cutting it close. I generally suggest staying in in the high 30's with a 17x8.
Old Oct 8, 2008 | 07:51 AM
  #79
Konky's Avatar
Konky
17x8 offset 35
Old Oct 8, 2008 | 08:40 AM
  #80
Vernon29RW's Avatar
Vernon29RW
what size tires.....those babies look stretched!! Very Hot indeed
Old Oct 8, 2008 | 08:45 AM
  #81
Konky's Avatar
Konky
205/40
Old Oct 10, 2008 | 11:52 PM
  #82
minimyke's Avatar
minimyke
Those schmidts are the sexxx..Id like to rep some TH lines on my car, but there mucho dinero..heres some pix of my buddys OZ Turbos on my car
O.Z. Turbo 2 piece
15x7.5 [not 8" plus, but lower offset]
195x45
offse +/- 20
megans all the way down in front, a lil up in the back cuz tuckin 15z just in the back looks retarded, so i left it a bit @$$ high.
Excuse the cellphone pix
Old Oct 11, 2008 | 06:51 AM
  #83
Rally@StanceDesign
Wow....OZ turbos, very nice
Old Oct 11, 2008 | 07:28 AM
  #84
Rally@StanceDesign
I miss my old poke.....but here's the new setup for now
16x8 et33 205/40/16 and a ridiculous amount of negative camber
Old Oct 11, 2008 | 10:19 AM
  #85
SD5's Avatar
SD5
love the look of that!!! very nice
have another question for everybody here
was thinking of getting Keskin KT1 in 17x8.5, not sure about offset think they come with
either 20 or 30 and tyres 205/45/17 or 215/45/17 anybody have any idea on which
would fit/look better (does it make a big difference)??? any tire recommendations???? thanks
Steven
Old Oct 11, 2008 | 10:21 AM
  #86
SD5's Avatar
SD5
oh and almost forgot read quite a bit here already and was wondering about rubbing on the tyres with wheels that wide?
Old Oct 11, 2008 | 10:22 PM
  #87
ghosthound's Avatar
ghosthound
i would like to know as well... id love to get some FAT rubber on the car but most of the pix ive seen are the first gen.
Old Oct 12, 2008 | 07:08 AM
  #88
Rally@StanceDesign
That's why a bunch of us with the lower offsets run stretched tires. It helps avoid rubbing while still being able to run the wide wheels.
In terms of your fitment question...what suspension mods do you have? How much negative camber do you plan on running?
I think the 205 will be too much stretch on the 8.5's unless you find a brand of tire with a wider-than-usual 205. 215 would be the safer bet....although it may not offer ENOUGH stretch to avoid rubbing. I usually recommend 215s for stretch on 9's
Old Oct 12, 2008 | 07:26 AM
  #89
SD5's Avatar
SD5
ok first of all i should let you know i'm new here and in the car modification thing too....
that said; suspension i want it to look good and be kinda alright comfort whise..like how the H&R springs look on some of the pictures posted in the forum!
Camber (I'm german so not sure what that meens)?I would have a shop install springs for me cause i wouldn't want to change anything that i wouldn't know how to undo.
like the stretched tyres look and know it very well from back home although never had it on any of my previous cars.
thanks for the advice
Old Oct 12, 2008 | 09:45 AM
  #90
smlzilla's Avatar
smlzilla
WOW minimyke... that look so good.. keep it up and post upmore pics!!!
O.Z. Turbo 2 piece
195x45
offse +/- 20
Old Oct 12, 2008 | 09:46 AM
  #91
smlzilla's Avatar
smlzilla
man rally. i want to see more pics of your current setup up...looks sweet
Old Oct 12, 2008 | 12:24 PM
  #92
LüDICRöüS's Avatar
LüDICRöüS
hey Rally do you have pictures from further away so we can see "the bigger picture?"
Thats HOT CHOCOLATE, quite literally
Old Oct 12, 2008 | 02:08 PM
  #93
Rally@StanceDesign
You can check out my full build-up here: http://www.motoringunderground.com/f...=10415&page=64
full side shot:
Old Oct 12, 2008 | 09:47 PM
  #94
LüDICRöüS's Avatar
LüDICRöüS
Old Oct 13, 2008 | 08:05 PM
  #95
Ryephile's Avatar
Ryephile
Andrew: Your MINI is Volcano-Hot Chocolate
Great stance, and I love the color matched wheel centers.
Old Oct 13, 2008 | 08:19 PM
  #96
Rally@StanceDesign
Thanks Ryan
Old Oct 15, 2008 | 06:31 AM
  #97
Alex@tirerack's Avatar
Alex@tirerack
agreed - This car has no time for quick make powders - this is the real deal home-made. Great motif!
Alex
Old Oct 21, 2008 | 01:01 AM
  #98
Coen_de_K's Avatar
Coen_de_K
Rally,
i already told you but DAMN that looks very nice.. less extreem then you cooper but this is more CLUBMAN!!! I like it!
@all. I just bought 8Jx18" wheels with offset 40. What tyre do I need to still get my car as low as I always go?!
215-35-18
205-40-18??
any recommendations?!
thanks guys!
Coen
Old Oct 21, 2008 | 07:22 AM
  #99
Rally@StanceDesign
I'd probably say the 205's. 215's would still stretch a little though. It really depends on the brand of tire. Can you guys still get Falken Ziex 512's over there? They retired their sale from most vendors but some companies are still allowed to carry them.
Old Oct 21, 2008 | 07:56 AM
  #100
Coen_de_K's Avatar
Coen_de_K
hmmz.. dunno rally.
I will ask for it..
The wheel I bought is a flat wheel without a lip so this is also the reasen why I ask...
thanks
Coen
