Roll call - 8"+ wide wheels
Old Apr 10, 2010 | 11:44 PM
  #326
maxmini's Avatar
maxmini
Originally Posted by jollyroger927
Ok the vmaxx coils are on, with my stock 17"s i had to put spacers in the front. Im hoping maybe i wont need them with the 215's on the 8" wide. If the offset makes it work. I hate spacers.
Anyone know where to get longer studs for the front? I bought lug studs and wanted to install them but im thinking i might want to get longer ones.
Turner Motorsports has a good selection of longer studs.
Randy
M7 Tuning
Old Apr 11, 2010 | 06:55 PM
  #327
Cudda_Kine's Avatar
Cudda_Kine
Since i've ordered a very low offset, i shouldn't be worried about it rubbing on the inside right? Just the outside (Fenders)?
Old Apr 11, 2010 | 08:10 PM
  #328
JohnnyVillan's Avatar
JohnnyVillan
^^You have a low offset but you're wheels are still really wide.
You're 15x10 et12 wheels will have 22mm LESS inner clearance than my 15x8 et15 wheels.
Thats why I'm telling you you're gonna be cutting it REALLY close in the front. I dont think I have 22mm of space between my wheel and my strut.
Old Apr 11, 2010 | 08:54 PM
  #329
Rally@StanceDesign's Avatar
Rally@StanceDesign
He should be fine on the inside. Same inner clearance as a 9 et25.
They're just gonna poke WAY too much, especially up front.
Old Apr 11, 2010 | 09:21 PM
  #330
JohnnyVillan
^^Im still not 100% sold on that inner clearance. I think he's gonna be within millimeters of his front struts. Tire sizes are gonna be important.
I do agree with the poke issue though. But I guess some would argue that my car pokes too much too. I just wanna know if these things clear the brakes. Once I see his car sittin on the new wheels, Im gonna sell my Sportmaxes and buy a more reasonable size lol.
Old Apr 11, 2010 | 10:23 PM
  #331
Un0RiGiNaL's Avatar
Un0RiGiNaL
Originally Posted by Cudda_Kine
Can someone please help me! I have XXR 16x8 's on both the front and rear of my car. It looks really nice from the front but there's a BIG tire gap from the wheels to the car. Not sure if i should lower the car or put bigger tires if they can fit without rubbing. Tires are 205/40 's. Here's some pictures...
Should i lower my car to make the wheel gap smaller or put thicker tires on there?
Wait so why are you buying 15x10's if you saw how goofy your car looked like that? Do you at least have springs or anything?
Old Apr 11, 2010 | 11:56 PM
  #332
Cudda_Kine's Avatar
Cudda_Kine
I've decided to go wider, then get airbags/coilovers. How much will airbags cost? $1,000?
And i'm getting taller tires than my old 16x8 setup.
45's vs 40's.
Old Apr 12, 2010 | 12:19 AM
  #333
call it spade's Avatar
call it spade
Old Apr 12, 2010 | 12:58 AM
  #334
Cudda_Kine's Avatar
Cudda_Kine
Will I be damaging my wheel bearings, running 15x10?? How is that blue rally mini running them without damage?
Old Apr 12, 2010 | 05:18 AM
  #335
Creeve's Avatar
Creeve
45's vs 40's.
$2,000 excluding the additional cost of coilovers and installation.
Old Apr 12, 2010 | 06:17 AM
  #336
Rally@StanceDesign
Of course you'll be damaging the wheel bearings. You're gonna be running 15x10's et12. That's a massive amount of additional leverage/load on the bearings.
You're aware that that blue mini is a designated autocross competition car not a daily driver right? Autocross courses are tiny, he probably puts 20 miles a year on those wheels at most. Cars like that are either trailered to events or are driven there on stock wheels and then they get the race wheels installed once they're at the event.
Old Apr 12, 2010 | 06:20 AM
  #337
Rally@StanceDesign
Haha how are you not sold on it? Throw 10 et12 into an offset calculator versus 9 et25 and then look at puma's car or miniboy's car. Like I said, 10 et12 has the same inner clearance as 16x9 et25 and there are multiple people running that without clearance issues. It's 100% proven that it will clear on the inside.
the only issue will be that it also pokes a FULL inch MORE than puma's setup, which is just silly.
Old Apr 12, 2010 | 08:52 AM
  #338
Cudda_Kine's Avatar
Cudda_Kine
Are trucks built with better wheel bearings or something? *noob question*.
I see all these old toyotas with 15x10 225/50/15's driving around all the time!
How about 15x8 et12? I think i could just return the 15x10's and get 15x8 et12 and still use the same tires i bought (225/45/15).
Old Apr 12, 2010 | 08:58 AM
  #339
Rally@StanceDesign
Totally different geometries. Same is true of RWD cars as well. They are designed to run much wider, lower offset wheels.
et12 is still a low offset. You're still going to decrease the lifespan of the bearings....it just won't be as quick as it would be with 15x10's and that offset.
15x8's et12 won't fit with 225's installed.
Old Apr 12, 2010 | 09:23 AM
  #340
Un0RiGiNaL's Avatar
Un0RiGiNaL
Lol..
You should've thought about it before you purchased 15x10 wheels...
Old Apr 12, 2010 | 11:37 AM
  #341
Cudda_Kine's Avatar
Cudda_Kine
How often would i need to replace the bearings? If it's every year, then not too bad.
Is that why my car is shaking when i drive? and constantly turning to the right? I thought maybe it was just my alignment.
Old Apr 12, 2010 | 11:46 AM
  #342
Cudda_Kine's Avatar
Cudda_Kine
Why wouldn't 225's fit the 8's?
Old Apr 12, 2010 | 01:38 PM
  #343
Rally@StanceDesign
Because the offset is so low.
Old Apr 12, 2010 | 02:03 PM
  #344
Cudda_Kine's Avatar
Cudda_Kine
Sh*t, will 225's fit my 10's? That's the size i've ordered. 225/45/15.
Old Apr 12, 2010 | 04:56 PM
  #345
JohnnyVillan
^^Yea but thats not enough stretch to really get low
For now you'll be fine if you're running stock suspension (aside from looking kinda silly)
Old Apr 12, 2010 | 05:31 PM
  #346
Creeve's Avatar
Creeve
Ok, I mean absolutely no offense by this but sometimes I feel like Cudda is just trolling us all.
I'm sure your not and its all legit, it just feels that way sometimes.
Old Apr 12, 2010 | 08:03 PM
  #347
Cudda_Kine's Avatar
Cudda_Kine
lol. I really did buy 15x10 rims though :-P
I'm just going to see how long i can ride with them before i get problems (tickets, car damage?).
Old Apr 14, 2010 | 12:41 PM
  #348
Cudda_Kine's Avatar
Cudda_Kine
Is there any way to make sure the wheel bearings don't fail? besides not using wide rims & changing axels. Any wheel bearing upgrades?
Old Apr 14, 2010 | 02:25 PM
  #349
Rally@StanceDesign
No our wheel bearings a pre-pressed in the hubs from the factory. There aren't any aftermarket options as far as I've ever seen.
Old Apr 14, 2010 | 04:12 PM
  #350
Un0RiGiNaL's Avatar
Un0RiGiNaL
