Suspension 19mm Rear Sway Bar Bushings Options
Old Mar 15, 2024 | 09:59 AM
ED955S's Avatar
ED955S
It's been awhile that I have not log in NAM but I am glad it is still very much active to fellow enthusiasts.
Still have my 2004 MCS since new & loving it to date.
I have an aftermarket H&R 19mm rear anti sway bar and recently developed clunk noise on bumps and road imperfections. I was able to isolate the clunk noise by disconnecting the sway bar from upper end link. Problem is worn sway bar bushings.
Will the Powerflex PFR5-504-19 bushing work to replace the H&R original bushing. Both are 19mm but I wonder if the Powerflex will fit into the clamp.
TIA.
Old Mar 15, 2024 | 02:45 PM
ED955S's Avatar
ED955S
ECS Tuning replied it will fit. Will update including the clunking suspension sound after installation
Old Mar 16, 2024 | 03:02 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I believe the H&R bar uses the OEM sway bar bushing clamp bracket. In such a case, as long as the aftermarket bushing uses the OEM bracket, any bushing of the correct size can be used. Otherwise, I would suspect having to go to the bar manufacturer for replacements.
Old Mar 16, 2024 | 03:02 PM
Mini_Crazy's Avatar
Mini_Crazy
Replacement Bushings
Noisy H&R bushings can be replaced with #33556772788 Febi (Teflon-lined) for R56 (18mm).
or 19mm SuperPro SPF2277-19K (slightly stiffer then Febi). These both work in the stock swaybar brackets.
Grease them well with SuperLube synthetic grease. (I believe the SuperPro bushings came with a capsule of SuperLube)
Old Mar 20, 2024 | 08:53 AM
megaDan's Avatar
megaDan
Grease it well, and often. I struggled to find a creak/clunking sound. Was only resolved after SIGNIFICANT grease application to the poly RSB bushings.
Old Mar 24, 2024 | 02:45 PM
ED955S's Avatar
ED955S
I tried to install the 19mm rear anti sway bar power flex bushing today to replace the 19mm H&R aftermarket but would not fit in the clamp. Requested ECS Tuning to return my order.
Attached photos:
Powerflex - H&R - Clamp
H&R - Clamp _ Poweflex
H&R - Powerflex
H&R - Powerflex side by side
Old Apr 2, 2024 | 02:55 PM
ED955S's Avatar
ED955S
ECS sent return slip.
Old Nov 1, 2024 | 02:44 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We offer replacement bushings and brackets that will work with any 19mm rear sway bar replacement on a Gen 1 or Gen 2 MINI
https://www.waymotorworks.com/swaybar-bushing-set.html
Old Mar 11, 2025 | 11:05 AM
ED955S's Avatar
ED955S
Revisiting my DIY install of my 19mm rear sway bar bushings using Superpro SPF-2277-19K. The H&R bushing cracked and causing knocking sound.
Superpro 19mm bushings
H&R 19mm bushings
H&R 19mm bushings (55K kms)
redwhiteR562007
Jan 8, 2023 04:40 PM
2014MCS_Miami
Jul 6, 2022 11:41 AM
66stang21
Suspension
Sep 10, 2016 08:49 PM
iporkgoats
Suspension
Nov 15, 2010 11:57 AM
Iautox
Suspension
Oct 1, 2007 11:29 PM
