F55/F56 No em part # for rear sway bar bushings (2014 MCS)??
Old Jul 6, 2022 | 11:11 AM
2014MCS_Miami's Avatar
2014MCS_Miami
Hi good people of N. American Motoring,
So I've got that knocking noise from the rear and I can see the rubber bushings for the sway bar are in pretty horrible shape.
Ive searched for the past hour and all I can find are the Powerflex 21.4mm polyurethane option (strange, isnt MCS rear sway bar 22mm?) but no OEM option. I'd go for the Powerflex but they arent precut with a slit and I dont want to mess with that.
Also, when I go to Mini/BMW's online store for my local dealer it only shows the bushings as a set with the sway bar but not available to buy separately.
Is this accurate, can I not actually order OEM replacement bushings anywhere and is there no part number for them?
Old Jul 6, 2022 | 11:41 AM
TVPostSound's Avatar
TVPostSound
OEM sway bars' bushings are bonded to the bar, and are NOT serviceable.
The bushing rubber resistance is part of the engineering.
Some have removed bushings from the bar and used aftermarket.
The issue doing that, is that the sway bar's stiffness are determined using the bushing rotation resistance.
Using aftermarket neoprene will lower the bars rating.
I dont think the OEM bar is 22mm
My recommendation is to replace the bar with a VIP 23mm solid , $249 shipped
http://www.vipcustomparts.com/F56%20parts%20page.htm
That was my first bar, and was amazing.
You can then service the bushings in the future.
CSP
Suspension
Jan 30, 2021 08:49 AM
TVPostSound
Jan 16, 2019 12:19 PM
66stang21
Suspension
Sep 10, 2016 08:49 PM
CassRacing
Suspension
Jan 27, 2014 05:28 PM
fafnir
Suspension
May 16, 2006 10:25 AM
