Suspension NM Engineering torque arm insert install/engine bushings
Old Jan 2, 2012 | 08:34 PM
  #101
kat1689's Avatar
kat1689
Way, any chance theres a NAM discount on this part?
Old Jan 3, 2012 | 02:51 PM
  #102
conrad0102's Avatar
conrad0102
Originally Posted by Mindspin311
So my torque wrench only goes to 75 ft/lbs, could I do that, then add in another half turn or so to get to 80?
I only lifted my car about 19 inches off the ground and had a hard time breaking and re torquing those bolts. Im sure NM just asked BMW/MINI how much torque they used and just copied that. Im sure your local Home Depot/ Lowes will rent you one if you are really concerned with it. OR you could buy one and return it after using =p. Just don't scratch it up. I bought one from Home Depot just cause I needed one. Was like $80
Old Jan 4, 2012 | 06:39 AM
  #103
etalj's Avatar
etalj
just torque it to 75 ft-lbs. torque wrenches aren't that accurate anyway (unless its expensive)
Old Feb 11, 2012 | 12:58 PM
  #104
Mini///M's Avatar
Mini///M
Did this yesterday. Longest thing was getting the car on the lift and in the air. Easiest install. Great results. Its noticeable and inexpensive.
Old Feb 19, 2012 | 06:36 PM
  #105
sLy201's Avatar
sLy201
this helped a lot when i needed instructions !! thanks 1!!!
Old Feb 20, 2012 | 05:29 PM
  #106
mbwicz's Avatar
mbwicz
I installed the Powerflex version (softer than the NM, according to WMW), to go in my 08 MCSa. I had a significant vibration at idle and pulled them back out. I will install them in the spring again and go through a break-in period. I also just noticed Way's not about overtightening.
My car also has an AP and a slight surge at idle, that made the vibration worse. For the 15 minutes, it made a huge difference in torque steer.
Mike
Old Feb 22, 2012 | 01:24 PM
  #107
sidthekid's Avatar
sidthekid
For people that installed this part on a post-2011 MCS, what benefits did you find other than decreased torque steer (which I don't find any of in my 2012 MCS). I am mostly interested in this part to make the car shift smoother, and I am worried about just trading rough shifts for a rough idle.
Old Feb 27, 2012 | 08:45 AM
  #108
jibber11's Avatar
jibber11
Holy Sniky...what a difference!!!
I thought it was me making that sloppy 1st to 2nd gear change, solid like a rock now!
Awesome......this is a MUST do!
Old Feb 27, 2012 | 10:58 AM
  #109
JPMM's Avatar
JPMM
got mine ordered!
Old Mar 7, 2012 | 05:46 PM
  #110
automan21's Avatar
automan21
Damn still havent installed mine and Ive had it for a year lol.
Old Mar 7, 2012 | 05:54 PM
  #111
automan21's Avatar
automan21
BTW what size are those bolts?
Old Mar 7, 2012 | 08:14 PM
  #112
WayMotorWorks's Avatar
WayMotorWorks
Vendor
16mm bolts
Old Mar 7, 2012 | 08:31 PM
  #113
TerminalVelocity's Avatar
TerminalVelocity
Way sold me on this when I was ordering a set of NM springs and an Hsport rear bar the other day. Installing it this weekend along with the other goodies! With all the positive comments I'm really looking forward to the difference!
Old Mar 13, 2012 | 06:33 AM
  #114
dboard7's Avatar
dboard7
I was just wondering if anyone looked underneath after some time of having there's installed, it's been around a year now and I was installing my oil temp sensor in the oil pan last night and noticed that it looked as if it was coming out?
Old Mar 13, 2012 | 07:32 AM
  #115
TerminalVelocity
I'm assuming everything is still tightened up? Regardless, that doesn't look like I imagine NM plans for it to look.
Old Mar 13, 2012 | 07:40 AM
  #116
dboard7's Avatar
dboard7
yes its the bolt tight, i didnt think so either lol its only coming out on the one side too, the front is nice and snug
Old Mar 13, 2012 | 09:36 AM
  #117
BBoshart's Avatar
BBoshart
Mine did the same thing days after I installed it. I reinstalled it twice just to make sure and it kept doing it. I talked with NM and they said it was fine.
Old Mar 13, 2012 | 10:22 AM
  #118
sean5294's Avatar
sean5294
I just installed mine the other day. I do have a slight vibration at idle but nothing I would worry about.
Old Mar 20, 2012 | 03:03 PM
  #119
JPMM's Avatar
JPMM
well is this right or not?
it looks like there is not enough backing letting the plastic protrude like that
Old Mar 20, 2012 | 06:26 PM
  #120
conrad0102's Avatar
conrad0102
Hmmm.. Mines in the shop this week due to A/C Drain leaking, leaving lakes in my rear floorboards but I will check mine when I get it back this weekend! I installed mine around Christmas time. Also my bushings are the triangular shaped ones. It might make a difference, I don't know.
Last edited by conrad0102; Mar 20, 2012 at 06:37 PM. Reason: forgot to mention something important
Old Mar 20, 2012 | 07:15 PM
  #121
euells's Avatar
euells
Mine are on the way
Got the shipping notification yesterday. My DDM Intake is also due Thursday, So hopefully I will have both mods in over the weekend. Can't wait!!!
Quick question for those have have done the install - I have a floor Jack, stands and ramps. I've never jacked the car up - what is the recommend method - a 4X4 cut to fit between the jack points with the floor jack under it? Any preference - Stands vs. Ramps? Sorry for the questions - but I am not a normally wrench turner and this is my first "structural" mod.
Thanks in advance!
Old Mar 20, 2012 | 07:24 PM
  #122
conrad0102's Avatar
conrad0102
Thanks in advance!
My Car is stock height and was too low for the ramps I have. I jacked up the passenger side with the stock car jack (closest to torque arm) and then put two jack stands on front and rear passenger side and lowered the jack a bit so all 3 stands had weight just to be safe. Then I crawled under the front of the car and worked under that with a light, torque and socket wrench. You really have to beat on the darn thing to get the nut to break. would be easiest to have it up on a lift and have a long socket wrench to break the nut loose. I only had my car lifted maybe 20 inches and i didn't have much room down there and I might have had to reach a bit but I got the job done. I am also 21 years old and limber. I forget some mini owners are more "experienced" in life so my method might not work for some.
I did this all in my garage at home. The torque wrench I have is somewhat short too.
Old Mar 20, 2012 | 07:29 PM
  #123
conrad0102's Avatar
conrad0102
Also, break both nuts then take the bolts out. if you take one out then try and break the other the engine will rock back and forth when you try and torque it and you won't get anywhere lol. Figured that out the hard way. I also had to somewhat force/move a header or something on the engine to get my torque arm to swing out and get the bolt out. It is on a squishy gasket thing-a-ma-bob so it moved. I can't remember exactly what the interferance was now but the overall install is easy.
Old Mar 20, 2012 | 07:51 PM
  #124
euells's Avatar
euells
Well I fall into that "more experienced" crowd so I will probably attempt to get it up on the ramps. My torque wrench is pretty long so I will need some room to get some leverage.
Old Mar 20, 2012 | 07:53 PM
  #125
euells's Avatar
euells
Good to know - thanks for heads up!
