Suspension NM Engineering torque arm insert install/engine bushings
Old Mar 21, 2012 | 07:50 AM
  #126
Island Don's Avatar
Island Don
Originally Posted by euells
Got the shipping notification yesterday. My DDM Intake is also due Thursday, So hopefully I will have both mods in over the weekend. Can't wait!!!
Quick question for those have have done the install - I have a floor Jack, stands and ramps. I've never jacked the car up - what is the recommend method - a 4X4 cut to fit between the jack points with the floor jack under it? Any preference - Stands vs. Ramps? Sorry for the questions - but I am not a normally wrench turner and this is my first "structural" mod.
Thanks in advance!
Other than the embarrassing problem due to being in "park" (covered in another thread...) the other parts of the install I did this weekend went smoothly using ramps. I have the molded style, and the rubber air dam in front of the wheels hit, but flexed so no real problem. Drove it right up.
Don
Old Mar 21, 2012 | 08:18 AM
  #127
conrad0102's Avatar
conrad0102
Of course! Stay safe.
Old Mar 21, 2012 | 09:20 AM
  #128
JCW Jet's Avatar
JCW Jet
Originally Posted by cenobyt
Did this installation today on my MCSa 2010. It wasn't so easy. Put the car up on my rhino ramps, crawled underneath, loosened front bolt, dropped back bolt. Popped the bushings in and then tried to swing the arm back up.
Right off the bat, I realized that the arm itself sat slightly tweaked to one side. The bushing was thus rubbing against the right side of the bracket. With force I could push it up but regardless the hole for the bolt was off by about an inch.
I remembered reading that people needed to rock the motor to pop the bolt in. I tried and it was useless no matter how hard I pushed the engine would not rock enough to line up for the bolt.
I tried jacking the motor up. Not good enough. I tried getting help, two of us under there couldn't move the engine enough. We tried everything we could without damaging anything else to try and get it to line up. Nothing worked.
I called Way, he verified all we needed to do was rock the motor. We tried again. No go.
Finally with me under the car lining up the bolt and my helper pushing his back against another car will leg pressing the oil pan was able to move the motor into place.
It then all went back together easy.
In neutral no vibration. In gear while moving none. There is now zero lag and almost no torque steer.
In drive while sitting in traffic however it's vibrating and its a pretty significant vibration.
total time 2.5 hours. It wasn't easy. Not sure what the issue is with my mini but it didn't go as smooth for me.
I would recommend it though.
Good morning all from No. Virginia...I will try to put a wrap on this thread with a few observations. First, these "inserts" by NM, while an interesting concept, fail some basic engineering principles....equal force, constant load, yada yada...I have NM stuff all under my hood, great quality, great fit, great design and precisely engineered....but these inserts won't make the cut and I'm guessing will slowly get squeezed out of most mounts...undetected by most. So, here's the best solution...install the BSH lower engine mount/torque arm instead....beautiful design, integrated bushing (available in street flex or race flex), I have both and only use the torque arm w-race flex for autox or rally events. It's available from Helix, on sale now at $110....link is below. Last, the quote above about the bolt misalignment generally happens when someone torques the motor to pull up on ramps or into an uphill garage...untorque the motor by putting the gearbox in Reverse in the garage, nice easy release back a few feet , back in 1st, nice easy release forward....parking brake on, gearbox in neutral, block the wheels, jack Er up. Good Luck
http://www.helix13.com/2nd-gen-mini/engine-exhaust/#go
Old Mar 22, 2012 | 07:13 PM
  #129
llewellyn's Avatar
llewellyn
Is there a big difference between the street and race bushings? I've been considering the BSH mount for a while now.. debating between NM Bushings or the whole arm.
Old Mar 22, 2012 | 08:44 PM
  #130
JPMM's Avatar
JPMM
Anyone interested in a good deal on a never used set of inserts?
I'm liking the looks of this arm.
Originally Posted by ScottG
Good morning all from No. Virginia.......but these inserts won't make the cut and I'm guessing will slowly get squeezed out of most mounts...undetected by most. So, here's the best solution...install the BSH lower engine mount/torque arm instead....beautiful design, integrated bushing (available in street flex or race flex), I have both and only use the torque arm w-race flex for autox or rally events. It's available from Helix, on sale now at $110....link is below. Last, the quote above about the bolt misalignment generally happens when someone torques the motor to pull up on ramps or into an uphill garage...untorque the motor by putting the gearbox in Reverse in the garage, nice easy release back a few feet , back in 1st, nice easy release forward....parking brake on, gearbox in neutral, block the wheels, jack Er up. Good Luck
Old Mar 23, 2012 | 03:35 AM
  #131
JCW Jet's Avatar
JCW Jet
Absolutely! There is a huge difference....Let's say the the stock bushing is like marshmallow, nice and soft....and almost everyone loves marshmallows! The BSH street flex is very solid bushing, barely moves if you stab your fingernail in it....Xfers a little vibration feedback thru the car in neutral or 1st gear at idle....now the race flex is like a rock....not a suggestion if you are a commuter. The pic just posted is the arm you get....black anodized...billet aluminum...nice!
Old Mar 23, 2012 | 04:51 AM
  #132
euells's Avatar
euells
Don
My inserts came yesterday - as well as my DDM CAI. I tried to be disciplined and install them both before taking it out, but just could resist a spirited drive through the curvy road that traverses the perimeter of our local state park after installing the new intake. The exhaust was just too hot when I got back to attempt the install. It's supposed to rain all weekend, so I will target Saturday morning to do the install.
Old Mar 24, 2012 | 04:16 PM
  #133
euells's Avatar
euells
Just finished the install - it was easy for me. All in all - took about 30 minutes, but that was mainly due to having to dig up my impact wrench to break the bolts loose. Once installed - I had to force the arm back up into place but remounting was a piece of cake.
When I first started the car - I noticed some vibration, but it seemed to go away. I have no noticeable noise or vibrations now. Shift does seem SOOO much smoother now. I will take a more spirited spin tomorrow if the rain lets up.
Thanks to everyone for all the advice - it surely helped in making it a smooth.
Old Mar 31, 2012 | 02:49 PM
  #134
JPMM's Avatar
JPMM
Brand new ,never installed R56 NM Engineering torque arm insert for sale $50 shipped ,in the USA ,Paypal OK.
SOLD
Old Mar 31, 2012 | 04:08 PM
  #135
conrad0102's Avatar
conrad0102
Did you end up taking it out on dry ground? how did it hold up? I totally love my shifting now.
Old Mar 31, 2012 | 08:21 PM
  #136
hamptup's Avatar
hamptup
I originally order the bsh torque arm but feared engine vibration transmit would be more noticeable so I went with the NM bushing. Install was easy and took no more than 15 mins to install with the correct tools. The bushing insert took out the slop with quicker reaction. Great mod for a stock daily driver imo!
Old Apr 1, 2012 | 06:59 AM
  #137
madmaxxed's Avatar
madmaxxed
I just installed my NM torque arm bushing inserts. I used a set of ramps. I don't understand the write ups on the troubles for install. I got mine in with no issues at all within minutes. The misaligned bolt hole wasn't a problem at all. I was able to move/rock the engine with just a finger more or less and was able to wiggle the bolt into place with no trouble. I really don't notice any vibration at all. In my opinion, I didn't notice a lot of change. I guess a bit more driving will bring out the feel maybe.
Old Apr 1, 2012 | 07:48 AM
  #138
drsimmons's Avatar
drsimmons
I've had mine in for a couple days now and love it. The original slight
vibration seems to have disappeared and the steer torque is greatly
removed.
Old Apr 1, 2012 | 11:35 AM
  #139
euells's Avatar
euells
I have been driving it all weekend and I love it! My son came home this weekend (he loves to drive the MINI) and he noticed it right away. We took a couple spirited runs around the State Park near my house. I am absolutely loving the mod. In conjunction with the new DDM Intake - it has really revved up the excitement factor of the car.
Thanks again to Way at WMW for suggesting these mods.
BTW - I am noticing a very slight vibration at idle after starting up cold. Once the engine heats up - I really don't notice it at all. It is in no way detracting from the mod though - a very small, insignificant price to pay for silky smooth shifting.
Old Apr 1, 2012 | 11:43 AM
  #140
euells's Avatar
euells
Glad the install went good - but i am surprised that you don't notice an immediate difference, especially while shifting. My engine seemed to move a lot with the clutch engaged but now it doesn't go anywhere. I can literally shift with one finger now.
Old Apr 1, 2012 | 07:05 PM
  #141
hamptup's Avatar
hamptup
Very happy with installing the insert. Took all but 15 mins. and the steering input feels solid and percised. Only slight vibration at idle but nothing worth removing it.
Old May 7, 2012 | 05:24 PM
  #142
Carpeviam's Avatar
Carpeviam
Got mine installed today. I was skeptical about all these reviews saying how it was such a noticeable change...but I'm a believer now. Its exactly as people said it was!
I could tell on the first shift that it seemed more precise. Very noticeable. The car does seem to put power to the ground easier, but I can't be sure thats not my mind playing tricks. But the reduced slop in the shift is there for sure.
There is slighly more vibration at idle, but not alot. People say it gets lessened after a week or so, but we'll see. But its not bad at all and I'm ok with it the way it is.
IMHO, the engine mount shoulda come from the factory on at least the JCW car. Its not like people who buy a JCW are looking for comfort, so something as low cost as that engine mount would be a welcome addition as a stock item on the car even with a tiny bit of vibration.
Old May 7, 2012 | 06:48 PM
  #143
drsimmons's Avatar
drsimmons
You didn't think us folks on NAM would BS you did you?
The vibration that I had is gone now. It's been over a month on the
install.
Saw your other post also, you'll find the FMIC helps in cooling the engine and turbo as well. Not sure about the Alta, I've got a Forge but I'm sure they are similar.
Those are all really good upgrades/mods to the Mini.
Try a 19 mm h-sport rear sway bar if you havent' upgraded that yet. You'll really love it.
Enjoy.
Old May 7, 2012 | 07:14 PM
  #144
Carpeviam's Avatar
Carpeviam
install.
Enjoy.
I just got back from going for another drive! :D The car really seems to want to pull hard now. And I'm not even using the FMIC map on the AccessPort yet.
But I have the JCW suspension on the car, so I probably won't be adding any more suspension parts to the car. I think if I was ever to do more to the suspension, it'd probably be camber plates in front to add a little more camber to the front, and then I'd also try to reduce camber in the rear.
But for now, I think I'm done. I just want to enjoy driving for now. But I dont' know how some people get such good gas mileage...I can't stay off the throttle! :D
Old May 7, 2012 | 07:22 PM
  #145
drsimmons's Avatar
drsimmons
^^^I can get 34.5 combined if I go easy but generally it's like
27-29mpg.
I'm with you, I'm done for awhile. Time just to drive it and enjoy
the ride.
Old May 12, 2012 | 09:48 AM
  #146
JPMM's Avatar
JPMM
Installed the BSH arm, I like it, some character building vibration, however now I have a tiny rattle in the dash that I can't nail down at certain RPMs that I wasn't expecting
Old May 12, 2012 | 11:15 AM
  #147
TerminalVelocity's Avatar
TerminalVelocity
Have you had the NM engineering insert prior to this? I'm interested in seeing if there's a noticeable difference. I have the NM insert and for the price it's incredible.
Old May 12, 2012 | 01:20 PM
  #148
JPMM's Avatar
JPMM
Yes, I had the inserts,I think the BSH arm does a better job of controlling the engine movement,as I did'nt I even think I had the inserts in, the previous owner had installed them, I bought a new set thinking I didn't have them as the the engine was moving around alot, under accelleration.
Old May 12, 2012 | 01:36 PM
  #149
TerminalVelocity
Interesting! I've found them to be excellent but then again prior to installing them it was stock so anything was better than that. I think the NM is a great mod for the price but as an entire unit the BSH looks top notch and all told it's not that much more expensive.
Old May 13, 2012 | 03:01 PM
  #150
JCW Jet's Avatar
JCW Jet
Hey JPMM,
The vibration you are most likely hearing is the secret glove box....mine does it also, but only first thing in the morning....The BSH arm will break in a little....but here's a little trick for anyone that wants a little more comfort from the BSH arm....I drilled (4) 5/8" holes thru the rubber bushing to remove a few notches off the 90 durometer reading of the bushing. I'm sure it's not recommended my BSH but it hasn't caused any issues on mine. Drll 2 holes on the horizon of the center of the lower bolt hole and 2 vertically....it helps a little on the sound & vibration. Also, NM is redesigning their inserts to include a stainless steel plate on either side of the bushings to stop them from squeezing out....they should be out shortly.
