Suspension Installed TEIN SS coilovers with EDFC
Old Aug 23, 2007 | 06:02 PM
JCW2006AUS's Avatar
JCW2006AUS
Hi,
Thought you guys might like to know recently purchased TEIN super street coilovers with EDFC, had them installed yesterday with no problems, installed the EDFC myself and had the coilovers installed by the Pro's.
The ride is outstanding compared with the Eibach spring kit I had before, The EDFC is an added advantage being able to adjust the damping rate on the fly.....
Cheers...
Mark
Old Aug 23, 2007 | 06:54 PM
joshK's Avatar
joshK
Do you have any pics of the system including interior pics of the adjustment module? I was going to get the H&R springs but I'm anxiously awaiting the Tein R56 setup as the on the fly adjustment seems too good to pass up...
Old Aug 23, 2007 | 07:16 PM
JCW2006AUS's Avatar
JCW2006AUS
I will take some pics and post them....
Old Aug 23, 2007 | 07:18 PM
jeffc's Avatar
jeffc
7th Gear
Grats on the new suspension. I should have my new coilovers installed in a couple weeks.
Old Aug 23, 2007 | 07:34 PM
kenchan's Avatar
kenchan
ss come with 500lbs/in, no?
do they over anything in the mid-200's?
Old Aug 23, 2007 | 07:39 PM
El_Griton's Avatar
El_Griton
SICK! when my car becomes a race car Im either going to get the race set up with the controler or some motons.
I would like to hear how they do on the track!
Old Aug 23, 2007 | 07:42 PM
JCW2006AUS's Avatar
JCW2006AUS
YES! 500lbs/in or 9kgs/mm tight but nice!
Old Aug 23, 2007 | 07:54 PM
PGT's Avatar
PGT
9K??? I had 8k/8k on my Cusco's on my (much heavier) Subaru and took them off after a month and sold them.
Old Aug 23, 2007 | 07:57 PM
kenchan's Avatar
kenchan
yep.. i would not run 500lbs/in on my 3500lbs+ G either...
too stiff for street. your car will rattle and mushroom towers in no time.
Old Aug 23, 2007 | 08:32 PM
billie_morini's Avatar
billie_morini
I wonder if the M7 coil overs that I read so much about today would have been better. oh, what is the country of manufacture for these TEIN products?
Old Aug 23, 2007 | 09:14 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Does the EDFD work on any other coil-over system or just the TEIN set up?
Old Aug 24, 2007 | 04:14 AM
JCW2006AUS's Avatar
JCW2006AUS
Here is some pics..
Attached Thumbnails Installed TEIN SS coilovers with EDFC-mini-tein.jpg   Installed TEIN SS coilovers with EDFC-mini-edfc.jpg   Installed TEIN SS coilovers with EDFC-edfc-close.jpg
Old Aug 24, 2007 | 06:09 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
That is sweet looking. Did you check my post #11? I am interested in the EDFD, but I did not know if it worked with anything other than the TEIN.
Old Aug 24, 2007 | 06:33 AM
PGT's Avatar
PGT
EDFC is designed for TEIN and only certain models. I'm sure it could be adapapted for others but it's basically four boxes with actuators and a control box that turns the adusters for you.
Old Aug 24, 2007 | 08:23 AM
kenchan's Avatar
kenchan
TEIN is made in Japan. They have some nice products, but not sure about wat they were thinking running 500lbs on a 3K lbs car on street.
Old Aug 24, 2007 | 09:12 AM
minimusprime's Avatar
minimusprime
the thing that drives me away from this system is.
1) spring rates. (although my buddy has them and it's not as bouncy as you would expect)
2) inability to find a camber plate that works with the edfc system.
I gues that's things instead of thing... but w/e you get the picture.
Old Aug 25, 2007 | 10:22 AM
brownflyer's Avatar
brownflyer
Check out this link for the EDFC unit.
http://www.vividracing.com/catalog/p...oducts_id/1581
It sounds like you can apply it to other c/o's as long as they have the same adjustment setup.
Old Sep 11, 2007 | 11:23 PM
ninjlao's Avatar
ninjlao
Ninja Mini
some lighter cars need stiffer rates. 9k is good for these cars. You can trust tein, these guys test out there cars on the track with many different rates before they bring a product out. BTW 93 rx7 are very light and some of the more expensive manufacturers had 19kg spring rates for them.
Tein had 17kg all the way around for the FD on there ra models/
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
