Rattle : Supercharger / water pump
Old Jun 3, 2009 | 07:20 PM
  #226
minicati's Avatar
minicati
ok, will buy that gasket maker thanks for info.
Mine looks pretty clean, glad i don't have to spend another $$ for s/c
Few questions now.
1. Is there any torq spec on both plates for s/c when i put together?
2. Should I use loctite? when i remove bolts for s/c plates it was too easy and I see some oil around inlet that with green gasket (bottom of waterpump).
afraid bolts get loose as time goes.
http://www.useloctite.com/products/p...cking090e.html
3. s/c fluid to use. I see thread about that, is it right? "waterpump drive side- 2.5oz; nose gear side(pulley side)5.5oz"
https://www.northamericanmotoring.co...ger-fluid.html
just like to make sure so i don't screw up.
thanks
Attached Thumbnails Rattle : Supercharger / water pump-pully.jpg   Rattle : Supercharger / water pump-pump.jpg
Old Jun 5, 2009 | 10:05 AM
  #227
SuperchargerTech's Avatar
SuperchargerTech
DIY repair
Yes we buy used superchargers. Price pending condition.
E-mail me or call me with what you have available. If
you have any further questions (anybody) fell free to e-mail
me and I will get back with you ASAP. Sometimes I miss
a thread for a while.. there are so many to keep track of.
Charles Judy
Supercharger Technologies
supercharger@excite.com
352-542-0147 Fax: 352-542-9468
Old Jun 5, 2009 | 10:12 AM
  #228
SuperchargerTech
Repairs
We don't use thread lock on the main bolts. Always scares
me if you have to take it back apart. If you torque them
down tight they should not come loose. I don't find loose
bolts on these units when we rebuild them (usually). The gears
look good on your unit but how did the 24 tooth gear get pushed
down further on the shaft (we always see them flush with the end
of the shaft)?
Charles
Supercharger Tech.
Old Jul 8, 2009 | 10:45 AM
  #229
Jon@TheMshop's Avatar
Jon@TheMshop
Originally Posted by Cadenza
FYI...
For California registered Minis, the Supercharger is covered by the "California Emission Control System Limited Warranty" for 7 years or 70,000 miles. From p.40 of the "Service & Warranty" booklet, the Parts List consists of...
- Intake manifold
- Engine Control Module (ECM)
- Supercharger
- Fuel tank
- Exhaust manifold with Catalytic converter
- Transmission Control Module (TCM)
- Knock sensors.
So for you Cali-Mini people, remember to fry your S/Cs at 65k!
Has anyone here in CA got this done under the emissions warranty?
I have a client with a 2002 Cooper and the supercharger seized up. The last time we sent a customer to the Mini dealer for a faulty DME the service adviser told them no such warranty (CA emissions warranty) exists even though they showed him the warranty manual in person.
Old Jul 8, 2009 | 01:18 PM
  #230
Cadenza's Avatar
Cadenza
That's classic! Dealers are sleazy (in general). It's not so strange for a Service Manager to tell/contradict what's written in the Warranty. I think they get away with it because most customers are uninformed and take it lying down. The Mini owner should contact Mini USA and file a complaint about this. If Mini denies there's such a warranty, I would tell them I'll take it up with the BBB and State Attorney General. See how that goes.
When the Mass Airflow Meter ($400) on my '01 New Beetle died at 48k, a SA at a very good dealer knew nothing about the California Emission Warranty and couldn't get VW HQ on the phone to approve the repair even though the language in the Warranty booklet is very clear... I showed it to him. I had to spend 30 minutes getting through VW Customer Service and they opened a case before the dealer replaced it... $400 part and $90 for analysis & resetting the readiness code on the ECM.
Old Jul 8, 2009 | 10:46 PM
  #231
StorminNorm's Avatar
StorminNorm
It must be "original/first" registration and currently registered in CA for the warranty to be valid.
Well slap me silly and call me a broke ****. I am the Customer Jon mentioned and UNFORTUNATELY my car was NOT an original CA. Car.
Jon - Joe and I need to talk! Make me a deal!
Old Jul 9, 2009 | 01:03 PM
  #232
Cadenza's Avatar
Cadenza
Uh Huh... It must be an original CA registration (as stated in the warranty language).
Old Aug 31, 2009 | 08:31 PM
  #233
Neufusion's Avatar
Neufusion
Originally Posted by djkajo
Is this the noise everyone´s talking about ???
http://www.youtube.com/watch?v=eQkvjMHTGTU
Oh god another expensive issue to add to my list. Owned my 04 for less than an year and everything is falling apart...
I have this noise as well. It's loudest by putting my ear close to the metal tube that connects to the intercooler (what is this part called?).
So how much labor and parts cost are we talking here?
Some people mentioned stiegmeier, but what exactly are they getting done?
http://stiegemeier.com/pricing.html
Mini-Cooper Supercharger Porting and Options: Gain Price Blower Porting Only $395 Front-Drive Rebuild Only $295 Blower Porting Plus Front-Drive Rebuild $595 Front-Drive Rebuild Plus Water Pump Drive Rebuild $795 Blower Porting, Front-Drive Rebuild, and Water Pump Drive Rebuild $895
I also read that this rattle has been eliminated by some by only doing a snout rebuid. Hmm...
Old Sep 5, 2009 | 10:13 PM
  #234
drmike@txwerks.com's Avatar
drmike@txwerks.com
I'm posting here to give a thumbs-up to Supercharger Technologies. $550.00 to rebuild both ends of the unit (including new water pump gears), and they finished the job the same day they received the supercharger! They even took the time to smooth out a couple of chips in the rotor coatings that I noticed when I took the unit off the car. Very good communication as well. I put the rebuilt unit on my '03 S and have had absolutely no problems since.
Old Sep 7, 2009 | 11:27 AM
  #235
newbs49's Avatar
newbs49
Sounds like you got a great deal on the rebuild.
Old Sep 8, 2009 | 02:29 PM
  #236
Cadenza's Avatar
Cadenza
So what do you listen for when the S/C is playing its music. I just got a stethoscope for this purpose.
Old Sep 8, 2009 | 03:18 PM
  #237
dotBob's Avatar
dotBob
Coordinator :: Houston MINI Motoring Society
The noise is not quiet: I could hear the chewing of the gears from in the cabin and outside of the car. It was that way for several months before I had it taken care of.
Old Sep 12, 2009 | 01:54 PM
  #238
burberryed's Avatar
burberryed
Supercharger Problems
After removing the supercharger from my 2004 MINI (50K miles) and changing the oil, I now have a lot more noise and the engine runs very rough. The noise appears to be coming from the output of the supercharger, The oil levels and gears where find. The vanes had some end play, but the feflon coating was good. What could I have screwed up? I am driving my 1987 Toyota Supra (20 MPG & not near as much fun)while Tinker Toy is sick. HELP !!!!! THANKS Ed Burberry-burberrye@bellsouth.net
Old Sep 12, 2009 | 02:24 PM
  #239
BlimeyCabrio's Avatar
BlimeyCabrio
Any possibility that you overfilled it with oil? If there's more than just enough for the bottom gear to dip into and sling around, it will literally beat itself to death with oil...
Old Sep 12, 2009 | 02:52 PM
  #240
burberryed's Avatar
burberryed
I put 2.5 oz of GM supercharger oil in the water pump end and 5.5 oz in the pulley end. Is this correct? Thanks
Ed Burberry
Old Sep 19, 2009 | 01:13 PM
  #241
Usagee's Avatar
Usagee
How many miles does the supercharger/waterpump generally have from when people first notice the gear-crunching noise to total gear failure (waterpump seizure)?
Old Sep 19, 2009 | 01:31 PM
  #242
dotBob's Avatar
dotBob
I went for at least 25,000 miles before replacing the supercharger/water pump. Probably even more than 30,000 miles. More than a year of high mileage highway driving. It never actually failed.
Old Sep 19, 2009 | 01:35 PM
  #243
JAB 67's Avatar
JAB 67
Mine failed (seized) while still under warranty, at approximately 16K. I had noticed the noise for a few thousand miles.
Old Sep 20, 2009 | 06:17 AM
  #244
BlimeyCabrio
Ed Burberry
Here someone says they only needed 1.5oz on the pump end:
https://www.northamericanmotoring.co...ml#post2877245
Old Oct 15, 2009 | 06:56 AM
  #245
miniRover38's Avatar
miniRover38
So does anyone know how much oil a mini SC actually takes?
If I remember correctly, one of the early pages in this thread stated 4oz. on the PTO/pump end.
So what are the real specs?
Old Oct 16, 2009 | 07:35 AM
  #246
DMBFan2's Avatar
DMBFan2
I know it might be easier to access the the drain/fill plugs by taking the car apart, but is it necessary? Seems like a really LONG process. Is a GM product the only product out there for the SC? To do this at every oil change seems excessive. I would think RedLine or Royal Purple would make this as well and it should last longer. What do you think?
Old Oct 16, 2009 | 09:26 AM
  #247
AutoXCooper.com's Avatar
AutoXCooper.com
Our shop puts 6oz in the front cone and 4 oz in the PTO.
Old Oct 16, 2009 | 06:46 PM
  #248
miniRover38
Thanks AutoX.
DMB, you shouldn't have to take the front that far apart. Bumper/bumper support, then just slide and tilt the MFE (modular front end) forward. It leaves enough room to work and only takes around 20 minutes if you've done it before. I'm sure those other companies make supercharger oil as well. If I remember correctly someone mentioned using some synthetic Redline supercharger oil. It looks like a lot of people have even started making their own service plugs in the top of the PTO cover. Then all they have to do is remove the intercooler.
Old Oct 18, 2009 | 02:23 PM
  #249
pmfranke's Avatar
pmfranke
On fleebay someone is selling helicopter oil for cheap .Its supposed to be da kine
Old Oct 19, 2009 | 12:07 PM
  #250
DMBFan2's Avatar
DMBFan2
Key words "suppose to be". Maybe if we knew the viscosity of the SC fluid in comparison to the helocopter fluid. I think I read somewhere that the SC fluid was 50w but then again I have been known to be wrong.
Does Redline or Royal Purple (anyone for that matter) make a coolant additive to increase the effectiveness of the oil? I would imagine that it gets pretty hot in the sc and the oil takes a toll in that much heat.
Also, does anyone know of aftermarket parts that would make the changing of the SC oil easier/quicker/cleaner? Since the amount in the SC is not that much, maybe a large syringe with a hose attached to it? Just a thought.
