Drivetrain Supercharger fluid
Old Jun 2, 2009 | 10:08 AM
  #26
SuperchargerTech's Avatar
SuperchargerTech
M45
Yes, they come with oil installed. We have to
put oil in them for our testing process. We actually
lower very strong magnets into the oil while the unit
is on the tester to be sure there are no metal particles.
We also install magnetic oil fill plugs before we ship the unit.
(these can be inspected during the life of the supercharger
to check for excess wear or problems - if metal particles
attach to the magnet).
Note: If you purchase a M45 for stock - we would not receive
a core back. So you would have to pay the $250.00
core charge. Of course when ever you do replace the
supercharger you can ship the old one in and get your
core charge back. (We usually don't charge the core
charge unless we do not receive the core back within
30 days).
Old Jun 2, 2009 | 05:35 PM
  #27
Nazrin's Avatar
Nazrin
So im assumming your guys sell the M45? If so, can you PM me the price?
Old Jun 3, 2009 | 09:57 AM
  #28
SuperchargerTech
M45 supercharger
The M45 supercharger rebuilt w/PTO gear replacement $550.00
(2 year - unlimited miles warranty)
Warranty covers replacement of part - not labor.
Core Charge $200.00
(There will be no core charge if old unit is
shipped back within 30 days. Core must also
be in rebuildable condition otherwise there will
be a partial or total core charge)
Shipping Pending distance $$$
Old Jun 3, 2009 | 04:12 PM
  #29
Nazrin's Avatar
Nazrin
Is the M45 the teflon coated one?
Old Jul 16, 2009 | 08:24 AM
  #30
DMBFan2's Avatar
DMBFan2
Originally Posted by SuperchargerTech
If anybody is still reading this thread....
Supercharger oil is a very thin full synthetic motor oil. When we
rebuild supercharger we usually use a 5W or at worst a 10W
full synthetic oil. We recommend that the oil is changed after a 500
mile break-in period and every 20K - 30K miles. We also install magnetic
oil fill plugs so they need to be cleaned before install.
Also, when changing the oil you will need to run the motor for about
5 minutes before removing the oil (this makes sure any dirt/metal particles
are suspended in the oil). You will also need a syringe with a 6" - 8" hose
to suck the oil out of the supercharger. Inspect the oil. We also recommend
that you flush the supercharger at least once because you can not get all the
oil out of the supercharger. Run the engine another 5 minutes and pull the
oil out again. Inspect the oil by pouring some onto a nice white sheet of
paper and inspect for dirt or metal particles(if there is excessive amounts
of metal particles something is most likely going wrong). Repeat the flush
if needed and until the oil is clean. Replace the oil for the last time filling
until the oil is at the level of the fill hole.
You can buy the GM supercharger oil but if you do flush the supercharger
the cost of the oil gets excessive. One or two qts. is usually plenty to
flush a couple of times and a refill.
We do offer a kit for those who cannot or don not want to find the
syringe/hose combo. Kit comes with oil,flush oil,syringe w/hose. We sell
it for basically what it costs us - for our customers.
NOTE: NEVER put gear lube into the supercharger. The oil is to thick which
creates a great deal of heat..... usually causing seal failure. NEVER!
We have had supercharger come in that the customer put gear lube into
it to quite the bearing noise. The supercharger got so hot the paint blistered
off the supercharger and melted the seals!
Thanks for the detailed information.
I have an 03S and my girlfriend has an 03 (non-S...) we live in Phoenix and when it is warm out (90-115) we both notice a sound that is similar to a jet engine (turbine) whine when turning off our cars. What could this be?
also, I had my SC replaced 45000 miles ago by the dealer in Scottsdale. Should I check the levels now? Or should I change the oil out for something really good...like a royal purple or Redline type of oil. (something that can take a beating)
Old Jul 16, 2009 | 08:27 AM
  #31
DMBFan2's Avatar
DMBFan2
Forgot to ask if anyone has seen a detailed step by step instruction on how to remove the SC? Would it be worthwhile to upgrade the pulley while its readily available? I have read that an upgrade on the pulley helps prolong the life of the SC. Is that correct?
Thanks again.
Old Jul 16, 2009 | 07:32 PM
  #32
Some Guy's Avatar
Some Guy
Thanks again.
Where did you read that a pulley swap can prolong the life of the SC? That is wrong. It doesnt shorten the life (so it seems) but it certainly doesnt prolong it.
Old Jul 17, 2009 | 10:29 AM
  #33
002's Avatar
002
that is the power steering pump
Old Jul 17, 2009 | 03:07 PM
  #34
DMBFan2's Avatar
DMBFan2
Oh No.
Sounds like we will BOTH need new ones soon.
any ideas on where to look for DEPENDABLE and cost effective power steering pumps? (since Mini can't get it right the first time).
Old Jul 17, 2009 | 08:09 PM
  #35
002's Avatar
002
Oh No.
it's normal. You can tell they're going to fail when they start cutting to half power frequently.
Old Aug 23, 2009 | 11:19 AM
  #36
afnos's Avatar
afnos
If anybody's still reading...
Does anyone know if dealerships carry the s/c reservoir bolts or if I'll have to contact Eaton? Some genius (not sure if service dept or PO) stripped out the reservoir bolt on the pulley side and I'm going to do the flush/fill if I can get new hardware. There's an unpleasant noise coming from the pulley side, so I'm assuming it needs to be done (I'm at ~95K mi).
Old Aug 24, 2009 | 05:51 PM
  #37
afnos's Avatar
afnos
Bump
Old Aug 24, 2009 | 08:45 PM
  #38
Nazrin's Avatar
Nazrin
I dunno if Supercharger Tech is still around thou..ive PM'd and emailed them but no response
Old Aug 27, 2009 | 08:04 PM
  #39
afnos's Avatar
afnos
Thanks Naz, I'll try too.
Old Aug 29, 2009 | 06:59 AM
  #40
DMBFan2's Avatar
DMBFan2
Is there only one type of supercharger fluid available or can we "upgrade" on it? Does Redline or Royal Purple make a supercharger fluid? Maybe some fancy European stuff? If I (or anyone else for that matter) will change their fluid in their supercharger, then there should be something really good we can put in it...right?
Old Sep 19, 2009 | 08:23 PM
  #41
dhogan's Avatar
dhogan
Since I'm in there at 85K I pulled the SC. It just looked too difficult to reach in that tiny hole, turn at a downward angle and suck out oil. Plus with it off you can look in the hole. Pour out the oil... get 4.5 oz out from the pulley side and 1.5 from the Wpump side. With a flash light I can see the gears look good, oil is dark. Bought GM oil, $11.98 / 4oz. Put 5.5 oz. in the pulley side and fluid level is good with SC horizontal. Then put 2.5 in the pump end and as I lean it over fluid starts to run out, I catch an ounce before it stops at near horizontal. So for me, basically 1.5 oz went back in the W pump end.
Old Sep 20, 2009 | 08:15 PM
  #42
DMBFan2's Avatar
DMBFan2
dhogan:
where did you get the s-charger fluid?
Everyone else:
Do the EU Mini drivers use the same s-charger fluid as we do? If not, what would be the comparison between the two? Do the folk across the pond have something better?
Old Oct 15, 2009 | 11:00 AM
  #43
Cadenza's Avatar
Cadenza
dhogan:
Everyone else:
K-huevo seems to be knowledgeable on this issue...
https://www.northamericanmotoring.co...02-post71.html
The Waterpump side tends to fail at higher frequency as it has less fluid in the reservoir.
Old Oct 16, 2009 | 07:25 AM
  #44
DMBFan2's Avatar
DMBFan2
patsum
26
May 29, 2021 06:29 PM
IFIXEM2
Sep 18, 2015 08:47 AM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 3, 2015 03:01 PM
