Hydraulic motor mount leak
Old Aug 21, 2009 | 09:25 AM
  #126
cube17576's Avatar
cube17576
Coordinator :: STLMini
I have 61k on my car and my 2nd mount was leaking. I was just about to pull the trigger on this, but my car made an unexpected trip (on a flat bed) to the dealership when my throttle housing went bad. I mentioned my mount was leaking and they looked up that they had replaced it (27 months ago) and they replaced it again under Goodwill. I may not like the OEM one that much, but when it is free I'll take it. When this one goes, I'll look at replacing it with the TSW one.
Old Aug 25, 2009 | 07:57 PM
  #127
Step's Avatar
Step
I dont know if it's been brought up before but the repair for these mounts, are relatively simple. However if you don't want to do it your self, and are willing to drive to the Annapolis MD. area i would be more then happy to help you out. If your interested send me a message.
P.S. I don't mean to step on anyone's toes.
Old Aug 26, 2009 | 06:21 AM
  #128
lou's Avatar
lou
Do you mean the replacement or the repair is easy? Do you replace the leaker with the same style mount? Just asking.
Thanks.
Old Aug 26, 2009 | 02:45 PM
  #129
matma92ser's Avatar
matma92ser
No toes are hurting.
Would you mind explaining how the mount can be repaired? Unfortunately I am on the opposite coast so I won't be driving over to Annapolis any time soon.
Thanks!
Matt
Old Aug 27, 2009 | 11:02 AM
  #130
droptopmini's Avatar
droptopmini
Have an '05 Cooper S Cabrio and had my motor mount replaced under warranty about 20K ago. I'm at 52K now and it busted again. Oil all over the place this time. I just ordered a TSW mount from AutoXcooper a few minutes ago. I will not have this problem again. Not as much concerned about the money as I am about the oil stains. I keep my engine compartment extremely clean.
Old Sep 3, 2009 | 01:12 PM
  #131
TigerDave's Avatar
TigerDave
Just bought our 2006 Cooper S convertible with 39k miles last weekend (manufacture date: 01/06) from a So Cal Audi dealer and I noticed the leakage as well. Took it to Brecht MINI and was told "Yeah, that's the hydraulic motor mount. We see this a lot. It's common." They replaced it yesterday. All is good -- until NEXT time!
Old Sep 3, 2009 | 01:21 PM
  #132
TigerDave's Avatar
TigerDave
Originally Posted by homerwest
My 06 MCSC looked like a lot of the pictures I've found in the forums by people with bad motor mounts, so I took it to the dealer this morning. The SA just called telling me that there is nothing wrong with the motor mount, but my oil pan gasket was leaking and was replaced. ????? How does that thick black fluid squirt up to the frame below the motor mount from the oil pan gasket? Does this seam to defy logic to anyone else?
Yep! Funny you should say that because as I posted above, when my fiancee called it in to Brecht Service, she simply said "fluid leak in engine compartment" since we didn't know that it was called a motor mount. Turns out, not only did they replace the mount, but apparently the oil pan was leaking and so they replaced the oil pan gasket as well!
Old Sep 4, 2009 | 12:55 AM
  #133
Cadenza's Avatar
Cadenza
Mine was also built Jan '06 and had its mount replaced. I asked the SA if MINI has redesigned a better mount. The answer is NO.
So I take it BMW decided NOT to make a better mount in order to make all the $ they've lost in warranty repair.
Old Sep 13, 2009 | 12:18 PM
  #134
PenelopeG3's Avatar
PenelopeG3
Another blown mount on our car - 06 MCSa with 49k miles. I think this might already be our 3rd mount.
Old Sep 21, 2009 | 06:12 PM
  #135
TexasPeaches's Avatar
TexasPeaches
I have an 06 and I am also seeing the oily residue right on the frame where the mount is. Is that a hydraulic mount or is it a rubber mount?
Old Sep 21, 2009 | 06:30 PM
  #136
TexasPeaches
I have 85k miles on my car and have had the car all of it's life. I have been researching on-line for 2 days and some say it is a hydraulic mount then, I went to http://www.realoem.com/bmw/ and it is showing to be a rubber mount. I sure want to order the correct part, as to not have to make any returns. Can anyone help me figure this darn thing out. I sure have never had any leaks and I sure hate this. I have cleaned this thing several times a day as it is my every day ride. I hoping it does not stain as bad as some of you have had.
Old Sep 21, 2009 | 06:40 PM
  #137
TexasPeaches
I am sorry, it is the mount that is on the top, it is to the left side of the motor right above the pulleys and belt. I also would like to find out what the tork lbs should be, because I have no clue and no clue on how to find out. I live over 2 hours away from the nearest mini shop and am in a small town where no one seems to know a darn thing about my car. Therefore I trust them not. I am a do-it-yourself-r and would like to do this myself if I can. I am also cheap and have always worked on my own vehicles. I plan to continue that if at all possible
Old Sep 21, 2009 | 08:30 PM
  #138
quikmni's Avatar
quikmni
Sounds like your mount is leaking. Your 06 should have the fluid filled mount. It is a thick black fliud, much thicker than oil. It is tough to get all the fluid off all of the places the fluid leaks and sprays on. I just engine degreaser and various brushes.
It is item 3 in the picture and they still call it a rubber mount but it is filled with fluid.
P/N appears to be: 22116778610
I am not sure of the torque on the bolt. You will need a external torx bit, I think size E12 but I am not sure.
Old Sep 22, 2009 | 08:27 AM
  #139
TexasPeaches
Thank you for the reply. I am glad to know that I am not loosing my mind. A friend of my husbandsd told me to try and spray a little windshield washer fluid on the frame and let it sit for about 30 minutes, lightly brush and then rinse it. He said that it usually eats away at that stuff pretty good. I was going to try it last night but we were having one heck of a lightning show and I was not about to get under the hood. I may try it tonight, weather permitting and see how it works. If it works, I will post it
Old Sep 22, 2009 | 08:54 AM
  #140
mini_racer's Avatar
mini_racer
Isopropyl (i.e. Rubbing) alcohol dissolves the dried hydraulic fluid instantly.
Old Sep 22, 2009 | 04:54 PM
  #141
TexasPeaches
I will have to try that. I just tried the windshield washer fluid. Waste of my time. It did not work. I am mainly trying to keep it clean until I get the part in,then I will do extensive cleaning before mounting it. Thanks for the advice.
Old Sep 22, 2009 | 05:08 PM
  #142
Cadenza's Avatar
Cadenza
In my case, the oil stain from the motor-mount never came off.
Old Sep 22, 2009 | 05:19 PM
  #143
mini_racer's Avatar
mini_racer
Regardless of how dry or old the black hydraulic fluid is, Rubbing Alcohol will get it off easy.
Old Sep 22, 2009 | 05:33 PM
  #144
Cadenza's Avatar
Cadenza
Hmmm... I thought Brake Cleaner would be strong enough of a solvent.
Old Sep 23, 2009 | 11:27 AM
  #145
MINIdave's Avatar
MINIdave
It's strong enough, just not the right chemical solvent........rubbing alcohol is the right stuff as mentioned above.....using the wrong chemical could actually set the stain.
Just so you all don't feel like the Lone Rangers here, other German cars use the mounts too, and they fail in those cars as well. I don't know if they fail this often, but they do fail.
Old Sep 23, 2009 | 12:45 PM
  #146
Cadenza's Avatar
Cadenza
Thanks, I'll give rubbing alcohol a try.
The rubber mounts in my '01 New Beetle (160k) are still good. My '87 Porsche 944S (126k) oil-filled mounts haven't popped but need replacing.
Old Sep 26, 2009 | 06:54 PM
  #147
TexasPeaches
Just thought I would write to tell all of you with the 2006 Mini S. I went to Carquest the other day and my guys down there did some research and found the motor mount. I only paid $77.16 tax and all for the motor mount and it looks to be almost the exact one on the car. It is a rein Automotive part # AVE0110P. Carquest's part # WPC A7000276437.
Old Sep 26, 2009 | 08:08 PM
  #148
k-huevo's Avatar
k-huevo
TexasPeaches, where are you located? A new bolt will also be required because the frame bolt is a single use torque to yeild. 22 11 6 766 753
Old Sep 27, 2009 | 12:08 PM
  #149
Cadenza's Avatar
Cadenza
Do you know if it's oil-filled or solid rubber?
Thanks!
Old Sep 27, 2009 | 06:40 PM
  #150
tomthegr06s's Avatar
tomthegr06s
I have the same problem with my 06 with 21000 miles..that mount is filled with hydraulic fluid, its not solid..have appointment on oct 5 to get it changed..hydraulic mounts are made to take the vibration from the motor so when it idles or you rev it you wont really fill any vibration.other than that i think they suck..not heavy duty enough..i used to replace them on mercedes benz all the time with low miles when i use to work for them..well this is the 3rd time in about 9 months this car will see the dealer..not happy at all..not reliable car sorry to say..just fun..
