Hydraulic motor mount leak
Old Apr 2, 2006 | 03:14 PM
crtsfstr's Avatar
crtsfstr
At 21,000 mi. on my 05,I noticed a very uncharacteristic oil mark underneath the right front fender;(cancel the reservations honey, I'm crawlin' under the mini!) After 90 minutes of samping, searching,checking levels and finally reading the shop manual, low and behold the right side motor mount is hydraulic, and it's leaking?! The major amount of oil was on the body frame below the mount; curious because any motor oil leak would have to leak up, not likely. The oil had a defenite rubber tire smell and was always cool regardless of engine
temp. I
Old Apr 7, 2006 | 08:17 AM
hangupndrive's Avatar
hangupndrive
Thanks for the post ... same thing just happened to my '05 MCS Cab @ 17,250 Mi... mount showed oil all around it ... dealer fixed it in a day ...
Old Apr 7, 2006 | 09:09 AM
Central Coast Coopers's Avatar
me too
my 05 at 15,500 or so has the sqame thing-but getting it repaired appears to be the same nightmare anything else is in this part of the world-bring it in an dleave it, we will get to it-sometime.....its 80 bucks, I will likely buy it and do it myself. better than being without my car for a week while some butcher isnt working on it at the dealer.
Old Apr 7, 2006 | 09:14 AM
SRTech's Avatar
SRTech
Welcome to the club! Mine started at about 8,000 miles.
Steve
Old Apr 7, 2006 | 09:25 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
This seems to be a common problem with '04 and up models which use that motor mount. Since it's a warranty issue, I'd have the dealer fit a new one. In case the replacement still has the same problem, you'd be covered for a repeat occurance of the problem.
Old May 7, 2006 | 03:54 PM
///ACS330Ci's Avatar
///ACS330Ci
Add me to the list
Old May 7, 2006 | 05:32 PM
shooler's Avatar
shooler
Mine leaked on my 1st Mini (05). Had it replaced under warranty with no further issues (that I know of). My current 05 has 10K with no problems.
Old May 7, 2006 | 05:47 PM
nypepper's Avatar
nypepper
mine was leaking at 2,000
Old May 7, 2006 | 07:23 PM
CARdiac's Avatar
CARdiac
my 05 leaked, i noticed it at 15K miles. My question is how do I get the dried/baked-on fluid/oil off my engine mount?
Old May 30, 2006 | 02:43 PM
rockymt98's Avatar
rockymt98
Here's another passenger side Hydraulic motor mount leak. My 05, 30,000. Just noticed today but it looks like it's been leaking a while. Here's a couple pictures of it.
Old May 30, 2006 | 02:51 PM
Motor On's Avatar
Motor On
So I just heard about this problem on Sun. was at the dealer today and saw another MINI having their mout actually replaced. Can't tell if I have it cause I've always cleaned the engine at regular intervals, I'm going to let that area get a little dirty and see if mines leaking. I heard that a slow small leak was "normal" which just doesn't sound right to me.
Old May 30, 2006 | 03:27 PM
SRTech's Avatar
SRTech
Well, mine has finally run out of oil at 30,000 miles and now the engine bounces up and down when I hit bumps. I guess I'll replace it now.
Steve
Old May 30, 2006 | 05:50 PM
Rawhyde's Avatar
Rawhyde
I think I'm a member of this club too. I have some oily residue in that area, and I've recently developed a slight "hollow sounding" rattle when going over mild bumps (like creeping through a gravel parking lot) I can also induce it by blipping the throttle just a tad.
Rawhyde
Old May 30, 2006 | 05:59 PM
shankrabbit's Avatar
shankrabbit
I was a member. Replaced under warranty within an hour. They also replaced the belt because the fluid got on the belt.
Make sure if you take yours in that you have them check the belt as well.
Old May 30, 2006 | 06:04 PM
eVal's Avatar
eVal
Can someone who has had this done report what it stated on the invoice? Is there a TSB?
Old May 30, 2006 | 06:11 PM
shankrabbit
Here is an image of my invoice
http://www.geekshocker.com/images/invoice_mount.jpg
Old May 30, 2006 | 06:13 PM
eVal's Avatar
eVal
Originally Posted by shankrabbit
Wow, that was fast! Thank you
Doesn't look like it was handled under a TSB but I could be wrong..
Old May 30, 2006 | 06:16 PM
shankrabbit
I don't think it was. They never mentioned anything about it being a reoccuring problem.
I did ask if it was because of my driving style or perhaps some nasty potholes that have owned me. The SA just said that some mounts just come from the factory faulty and that it had nothing to do with either of those things.
Most motor mounts, he told me, should last up to 150k-200k miles before starting to break apart.
Hm...
Old Jul 6, 2006 | 07:27 PM
MINI_Mark's Avatar
MINI_Mark
Mine just went a couple weeks ago, 2005 with about 15,500 miles.
Old Jul 6, 2006 | 10:13 PM
eVal's Avatar
eVal
In an ironic twist my motor mount went out not long after posting to this thread Only 8k or so too, fixed under warranty no probs.
Old Jul 7, 2006 | 05:07 AM
rhawth99's Avatar
rhawth99
I had heard that the motor mounts were different between an '05 and an '06. Does anyone know if you can tell visually from the outside? My wife's '05 was built in 05-05 and my '06 was built 01-06 and the passenger side motor mounts like the same to me. Thanks in advance!
No leaks at 10.2K miles on the '05 and 4.5K miles on the '06 (knocking loudly on wood).
Old Jul 7, 2006 | 06:58 AM
SRTech's Avatar
SRTech
They changed in the '04 model year sometime so everything after that is the hydraulic mount.
Steve
Old Jul 8, 2006 | 06:37 AM
Tit's Avatar
Tit
Mine just went again for the SECOND time....this one was replaced only three months ago...
If it happens to you, make sure you clean the oil off quick, otherwise the heat of the engine will bake it onto the paint....
Old Aug 7, 2006 | 06:59 AM
Wiggles
Damn! Me 2. Jan. '05 MCS with 40,000 miles.
Old Aug 7, 2006 | 08:36 AM
VBG's Avatar
VBG
A well known issue at the dealer...
I had my passenger side upper mount replaced last week during my 10k service, it had been leaking lightly since about 6k miles.
The 10k service and the mount replacement were both done in about 2 hours. I had the work done at Nick Alexander in L.A. and was quite pleased with their service. The service manager knew exactly what was going on and said they had plenty of replacement mounts in stock.
This is evidently a very wide spread problem with '05s and '06s, it sounds like if you have one of these year models you can plan on it. Numerus SCMM members have discussed it on the MINI Maniacs board, too. I have to wonder if MINI figures it is a lower priority -- not related to safety -- so isn't doing a recall, instead opting to replace them at service time.
I hope the new part fixes this once and for all, although it sounds like some here have experienced it multiple times.
Maybe this is a dumb question, but are we in general too rough on these little cars??
Best,
-- Don
