Hydraulic motor mount leak
Old Oct 5, 2006 | 07:07 AM
  #51
minimusprime's Avatar
minimusprime
well you are pretty set over there in michigan. I did a rally with the michigan city motoring club last weekend and metro city mini set a tech along in a spanking new jcw. His name was brandon and he didn't drive a mini himself but man does he know how to fix them.
Old Oct 5, 2006 | 07:19 AM
  #52
YellowDinanMini's Avatar
YellowDinanMini
I think I know who you are talking about, he does know his stuff.... it's just the service people that you have to get past... I don't want to start trash talking too much about them on here though, pm me if you're curious, It's actually a decent story.
Old Oct 5, 2006 | 07:43 AM
  #53
minimusprime
here, here... If only we could speak directly to the techs... my whole world would be turned upside-down.
Old Oct 10, 2006 | 09:55 AM
  #54
jcandp's Avatar
jcandp
For my first post on NAM I'm asking for acceptance into the leaky motor mount club...
Our '06 MCS only has about 6000 miles on it and I just found a puddle of hydraulic fluid over the weekend. Called my local dealer (Mini of Pittsburgh) and the guy in service acted quite concerned. He even went as far as to recomend that we not drive it the 50 miles to the dealer. He told me to call Mini Road Assistance and they would shuttle our MCS to the dealer for repair then back to us when it's done.
Old Oct 16, 2006 | 11:36 AM
  #55
Redcoat's Avatar
Redcoat
Funny, jcandp, I was just into MINI of Pittsburgh on 10/13/06 and they replaced my mount under warrenty no questions asked. It was my first service at 13,000 on my '06 JCW. I figured it must be pretty common for them since they had them in stock. They didn't act surprised, but didn't let on that it was a common occurance either. I'll just have to keep my eyes on this one.
Old Oct 18, 2006 | 10:55 AM
  #56
MiniMacPR's Avatar
MiniMacPR
Moderators: I believe there are several threads about this issue, and its becoming more common for 04 and 05 owners to realize they have the issue after reading the threads. How bout a merge and a sticky?
Anyone else agree?
Old Oct 18, 2006 | 12:23 PM
  #57
eMINI's Avatar
eMINI
I agree. However, It doesn't seem to be limited to '04 & '05 cars.
Old Oct 18, 2006 | 12:36 PM
  #58
MiniMacPR's Avatar
MiniMacPR
True, I was under the impression that the motor mounts previous to '04 were solid and not oil filled, but this thread has apparently disproven that.
Thanks for the clarification!
Old Oct 18, 2006 | 12:44 PM
  #59
minimusprime
Just an update for those tuning in. I just had mine changed not too long ago. Mine didn't look any where near as bad as some of those in this thread. Matter of fact mine was just leaking on the support bar underneath it and had some dried up residue.
I would definatly have it taken care of sooner rather then later just for piece of mind and because that black stuff trashes the paint in your engine bay. The double edged sword is that if you clean it off before you take it into the dealership it may not be obvious to them that the part is shot. However, this is a common problem and my mini sa was talking to me in the back room and showed me the box of them that he had that were shot. He said many times they will just pull and replace them without the customer even saying anything about it.
Old Oct 19, 2006 | 07:47 PM
  #60
kenchan's Avatar
kenchan
i can tell you that my 06/03 build does not have the pressure cooker
type. i just looked at it while i was figuring out if the engine damper i
just ordered would be a direct bolt-on on my car or not.
Old Mar 22, 2007 | 10:49 PM
  #61
CynMini's Avatar
CynMini
I poped my fourth cherr, oh I mean, "hydraulic engine damper" this week at 37.5K miles. In my case I could feel a lot of engine movement way before it poped and it's not worse after it poped. So I am wondering if something else is wrong and it's causing the mounts to go pop. I am getting tired of this and I am wondering if Mini will continue to replace them after the warrenty is up??
Old Jun 10, 2008 | 07:00 PM
  #62
rbennett's Avatar
rbennett
New part number on the fixed motor mount
If this part was fixed in 2007, and the part fits on the 2005 mini cooper s, does anyone have the new part number so I can ask for it when I go in to have my second hydraulic motor mount replaced it is replaced with one that will last?
Thank you
Old Jun 10, 2008 | 09:47 PM
  #63
CynMini's Avatar
CynMini
Guess what? Yep, you guessed it, I now have 49K miles and I just poped another one! So I am very interested if there is a new damper.
Old Jun 11, 2008 | 09:43 AM
  #64
Xymox's Avatar
Xymox
At $70 a pop (pardon the pun), that can get pricey
http://www.germanautoparts.com/beta/...E2/145/4450741
Old Jun 11, 2008 | 11:26 AM
  #65
rbennett's Avatar
rbennett
Thank you.
Does anyone know of a aftermarket solid polyurethane engine mount that replaces the 2005 mini cooper s hydraulic engine mount 22116778610? Can you please post the links of the venders if you know them?
Thanks again.
Old Aug 20, 2008 | 08:56 AM
  #66
Terrie's Cabrio's Avatar
Terrie's Cabrio
My passenger side was replaced today under warranty after making clunking sounds for the last 4 months. It started leaking over the weekend. Mechanic said this was common. Ugh!!!!!!!!!
Old Aug 29, 2008 | 09:07 AM
  #67
OldRick's Avatar
OldRick
If you smell "fruity" fluid, check the radiator thermostat housing. They crack frequently - about as often as the motor mounts die...
Old Sep 6, 2008 | 12:04 PM
  #68
OldRick's Avatar
OldRick
After mine was replaced (`05 S, 45K miles) I was able to clean off the black goop easily with isopropyl alcohol, without messing up the paint.
Old Sep 8, 2008 | 03:41 PM
  #69
Davemon's Avatar
Davemon
Anyone have trouble changing one of these? I removed the nut and the bolt fromt he two attachment points, jacked up the motor a bit, and the darn thing won't move. I can't get that bottom part with the pin to come up out of the chassis. I tried drinking a beer but that hasn't fixed it either.
The "one" in question is the passenger side one which seems like the one most folks here have experienced failure in.
Dave
Old Nov 7, 2008 | 12:55 PM
  #70
homerwest's Avatar
homerwest
Hmmmmm.....
My 06 MCSC looked like a lot of the pictures I've found in the forums by people with bad motor mounts, so I took it to the dealer this morning. The SA just called telling me that there is nothing wrong with the motor mount, but my oil pan gasket was leaking and was replaced. ????? How does that thick black fluid squirt up to the frame below the motor mount from the oil pan gasket? Does this seam to defy logic to anyone else?
Old Nov 7, 2008 | 02:14 PM
  #71
Crashton's Avatar
Crashton
I think your SA is full of beans.
If there is oil under that mount it is from that mount. It seems that all 05 & 06 MINI's have the mount fail. IMHO there is no way oil from a leaking oil pan under the engine is going to get up there.
Old Nov 7, 2008 | 02:22 PM
  #72
Big Daddy's Avatar
Big Daddy
I had the same thing happen at Mini Windsor just last week. The SA said that there is no fluid in the motor mounts, just a spring and that the oil was coming up from around the pulley. Huh???? So, I got good old Chad at Detroit Tuned to send me some pics of a torn apart, leaky, fluid-filled motor mount. Argument over. They are going to replace it under warranty. It is so lame when these so-called professionals don't even know the cars they are supposed to advise us on.
Old Nov 7, 2008 | 02:44 PM
  #73
homerwest's Avatar
homerwest
Thanks Chuck and Big Daddy. I will be leaving for the dealer in a few minutes, and might need to chat a bit more with him.... My SA used to be a salesman, and was not very helpful in that role.
Old Nov 7, 2008 | 09:24 PM
  #74
mini_macky's Avatar
mini_macky
hmm, i'm noticing a LOUD clunk from the passenger side (LHD) when powering out of a left hand turn on the track and also notice a "clipping" sound somewhere in the front when i suddenly lift off from the throttle when cruising. time to check on my motor mounts
Old Nov 7, 2008 | 09:50 PM
  #75
CynMini's Avatar
CynMini
Take it to South Bay Mini. I drive an hour to take my car there, because they are the best. They will replace it, no questions asked. They have replaced 5 of them for me, the last one was 10 miles before my warranty was up.
