2011 R56 non s cooling fan inop
Old Feb 15, 2019 | 08:03 PM
Ralph Green's Avatar
Ralph Green
I have a 2011 non s R56. I had a leaking water pump that was leaking from the weep hole. I changed the water pump, friction wheel, tube to the thermostat and thermostat. Everything was fine for there months and then the problems began. The temp sensor in the thermostat failed. I replaced the sensor. The fan would not operate unless I unplugged the sensor while it was running or turned on the ac. Replaced the relay and fused. Fan still would not come on properly. One morning I went out and it was -5° and started the vehicle. The fan immediately came on. The vehicle would not hear up and fuel mileage was terrible. The thermostat stuck open. I replaced the thermostat. Now the fan only works when cooling temp sensor is unplugged or ac is on. System has been bled about 80 times. Tonight I went into the hidden bent and compared my gauges to the computer. I found out my craven speed temp gauge is off 25°, but when I ran the temp up to 110°C in the hidden menu the fan did not turn on until I turned the AC on. I have plenty of heat in the interior to the point I have to roll the window 1/4 down. Fuel economy is the same during this winter as last winter before the cooling system renew. Hidden menu 7 proves the temp sensor is working. What am I missing? Any and all help is appreciated. Thank you.
Old Feb 18, 2019 | 09:15 AM
MiniToBe's Avatar
MiniToBe
The fan has a stage 1 and stage 2 settings. Perhaps this is the classic fan resistor failure! can you test if those two stages work? we know at least one is.
Old Feb 18, 2019 | 09:21 AM
Ralph Green
So the two wire fans have two speeds? Even with one relay?
Old Feb 18, 2019 | 09:24 AM
MiniToBe's Avatar
MiniToBe
https://www.newtis.info/tisv2/a/en/r...oling/FFUuSkiZ
there are two relays
Old Feb 18, 2019 | 09:28 AM
MiniToBe's Avatar
MiniToBe
K21 & K22
https://www.newtis.info/tisv2/a/en/r...-s-hat/RFRiyOY
Old Feb 18, 2019 | 09:33 AM
Ralph Green
That states s models. Mine is not s model. Mine originally only ran on high and only had k21.
Old Feb 18, 2019 | 09:37 AM
MiniToBe's Avatar
MiniToBe
I remember my '13 base has two relays. plug another one in.
Old Feb 18, 2019 | 09:38 AM
Ralph Green
I did that yesterday. The fan did not kick in and I went to 118.
Old Feb 18, 2019 | 09:45 AM
MiniToBe's Avatar
MiniToBe
the only thing i can think of is the resistor.
has it always been like that, or you just noticed it after the thermo replacement?
Old Feb 18, 2019 | 09:48 AM
Ralph Green
After the first thermostat replacement it stopped. On my third thermostat and did three sensors also. Vacuum filled coolant. I'm to the point of throwing a fan at it. If it is not that, just leaves dme.
Old Feb 18, 2019 | 09:53 AM
MiniToBe's Avatar
MiniToBe
before you go fan up, replace the resistor.
Old Feb 18, 2019 | 10:04 AM
Ralph Green
Where is the resistor located?
Old Feb 18, 2019 | 10:09 AM
MiniToBe's Avatar
MiniToBe
it should be on the fan housing. it looks like a green tube.
Old Feb 18, 2019 | 10:11 AM
MiniToBe's Avatar
MiniToBe
I could be wrong though about this fan. all my minis now are S model. the '13 base was sold a year a go. so, before you buy anything, do more digging please.
Old Feb 18, 2019 | 10:16 AM
Ralph Green
Not on the fan shroud, just the plug end and wires to the fan.
Old Feb 18, 2019 | 11:03 AM
MiniToBe's Avatar
MiniToBe
the other thing i can think of then is the thermostat itself. do they not have two settings. Im thinking like on GM cars, they have a thermostat that opens let's say at 110C and another thermostat opens at 120C, could this be one of these kinds...I'm just thinking aloud!
Mereco
Aug 30, 2017 02:42 PM
Cal45fan
Aug 10, 2016 05:08 AM
Dan1967
Sep 19, 2010 04:36 PM
mpdwag
Aug 7, 2008 04:45 PM
ilscoobydooll
Jun 4, 2007 02:47 PM
