Fuel pump or HPFP please help or injectors
Old Feb 1, 2018 | 01:45 AM
ahmedalsurmi's Avatar
ahmedalsurmi
hello
i have a problem in my mini r56 cooper s 2010
when i start my car at cold it keeps stalling and when i drive when its warmed up it keeps cutting and rpm play
i have scanned it with obd and give me this error code P3091 and P2177 system too lean at idle
and today i removed HPFP connector and the same happen but i saw new codes when i scanned it
P3091 P2177 its the same
and this
P0300 random misfire
P0301 cylinder 1 misfire
P0303 cylinder 3 misfire
P0304 cylinder 4 misfire
P0141 o2 sensor heater
P0001 Fuel Volume regulator control circuit/open
Whats the problem please can anybody help me ????
Old Feb 1, 2018 | 06:23 AM
f_p's Avatar
f_p
to check whether the pump is doing ok, use the torque pro and see what live readings you get when idling/accelerating. If you get low/unsteady pressure, then it could be the pump as well...
Anyone else?
Old Feb 1, 2018 | 06:34 AM
J Free's Avatar
J Free
I'd go that route too, I had similar and it was the fuel pump. I had low idle pressure readings.
cornjuice's Avatar
cornjuice
sounds like the HPFP is done for..
Just had the same on my R56 few weeks back. If you check the fuel rail pressure using your OBDII scanner.. you would likely see pressure in the ~80psi range.. instead of ~700-800psi.
Old Feb 1, 2018 | 06:40 AM
f_p's Avatar
f_p
700-800 psi is the reading I am get when car is idleing.
Under full acceration it passes the 1200psi mark...
Old Feb 1, 2018 | 06:54 AM
cornjuice's Avatar
cornjuice
yeah exactly.. should see upwards of +1700psi under hard acceleration .. but I wouldnt try to WOT with a faulty pump; youre just asking for issues.
*if you see 80psi at start.. the pump has failed and needs replacement.
Old Feb 1, 2018 | 08:34 AM
ahmedalsurmi
thanks a lot i will check it today
Old Feb 1, 2018 | 09:31 AM
seandallen's Avatar
seandallen
if it hasn't been changed before, I'd start with a new fuel filter. Cheap fix, and if it doesn't help the problem, it still needs to be done as maintenance anyway on a car as old as yours.
I just did it, and it took less than hour.
Old Feb 1, 2018 | 02:48 PM
ahmedalsurmi
Thanks for your replay
i have checked it again with obd
fuel rail pressure its around 740 to750
so what is the problem
Old Feb 2, 2018 | 07:25 AM
cornjuice's Avatar
cornjuice
are you getting half - check engine light when it idles rough and stalls?
*does it only happen now, from cold-start?
My pump went back and forth for about a week.. sputtering, running rough.. then fine. Hiccup and backfire in the morning then stall.. then fine once warm. Once I started monitoring fuel pressure, I was able to see a few times where pressure went to 80psi as the CEL came on, then went away. Finally.. it died all together.
Theres been some cases of the pump housing cracking, as well as the internal seals failing and causing these issues. If you dont have a pressure issue - I would closely examine all of the coils and wires.. then plugs.
Old Feb 3, 2018 | 09:28 AM
ahmedalsurmi
Yes i get half check enigne when its cold and when its warm too and stall for both
but fuel rail pressure its 740 to 760 when its cold or wram its the same
Old Feb 3, 2018 | 06:36 PM
cornjuice's Avatar
cornjuice
When was the last time you pulled the spark plugs? *need to start ruling out spark/ignition sources next
Old Feb 4, 2018 | 08:19 AM
ahmedalsurmi
The spark plugs are new even coils are new
Old Feb 7, 2018 | 06:37 AM
cornjuice's Avatar
cornjuice
that P0141 o2 sensor heater code is where i would look next, as you have already eliminated spark source.
*above code is referencing your primary O2 sensor as having a short in closed loop mode.. that warrants replacement for sure. Readings are likely throwing your ECU fits.
fast_eddy
Oct 2, 2022 01:55 PM
roach_juts
R55 :: Clubman Talk (2008+)
Jul 29, 2022 10:19 AM
Sep 1, 2015 03:36 PM
candemresurrection
Mar 31, 2015 08:58 PM
