'09 Mini Clubman - driver's side window won't close completely.
Old Feb 29, 2016 | 09:28 AM
mbu's Avatar
mbu
On my '09 Clubman, the driver's side window won't close that final distance when the door is closed. I haven't driven it for the last 8 months and the vehicle has around 5,000 miles on it. Everything was working on it when last driven. The battery was dead when I tried to start it and therefore I had the battery charged.
Any advice on how to fix this? The dealer is over 300 miles away.
Thanks,
I posted here because I thought the window closing equipment is basically the same for all mini's and not just a "Clubman" thing. Hope this is okay!
Old Feb 29, 2016 | 11:43 AM
MothAudio's Avatar
MothAudio
What exactly is it doing? I have the same car and my passenger window will intermittently roll back down 1/2 halfway when I attempt to close it. The solution, I found, is to creep it back up manually so it almost to the top, but not completely closed. Pause, then I'm able to close w/o it dropping back down.
Old Feb 29, 2016 | 11:48 AM
mbu's Avatar
mbu
Okay, I washed the vehicle and did a general cleanup on the inside... and lo and behold, the window started working again! I don't how how the window closing works but maybe a switch that works at the latch was a little corroded and when I opened and closed the door several times it established a better contact. I guess I'll never know for sure but the bottom line it's WORKING!
So to everyone that DIDN'T respond - Thanks!
Old Feb 29, 2016 | 11:54 AM
mbu's Avatar
mbu
MothAudio,
You posted when I was responding.
When one opens the door latch, the window opens just a crack and once the door closes, it shuts completely. Nice feature as it makes the door easier to shut. My problem was that it would open a crack but not make the final seal when closed.
Old Feb 29, 2016 | 11:57 AM
MothAudio's Avatar
MothAudio
^^ Gotcha.
Old Feb 29, 2016 | 12:12 PM
Gitmoe's Avatar
Gitmoe
My '09 used to do the same thing intermittently. I found rolling the window down all the way then opening and closing the door a few times then rolling it back up usually fixed it. One time I disconnected the battery which also seemed to fix it. I think it's a bug in the software honestly. I was always able to get it to basically fix itself.
Old Feb 29, 2016 | 12:46 PM
mbu's Avatar
mbu
Gitmoe,
You bring up a good point. Is there some way a person can reset everything to the original settings?
Old Feb 29, 2016 | 05:25 PM
AZdsrt's Avatar
AZdsrt
Originally Posted by mbu
Gitmoe,
Yup. With window in down position, lever the window all the way up and continue to hold the lever for a few seconds. Lever the window all the way down and continue holding the lever for a few seconds. I think the exact process is in the manual somewhere..
Old Feb 29, 2016 | 06:09 PM
mbu's Avatar
mbu
AZdsrt,
Thanks for your response!
I'll have a look-see in the manual...
Old Mar 1, 2016 | 02:43 PM
Reset the windows.
https://www.northamericanmotoring.co...problem-2.html
Old Mar 1, 2016 | 04:09 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
From Belt line down the Clubman is 90% hard top, moved to 2nd Gen Stock Problems/Issues.
Thanks.
uslfcfan
Jan 25, 2016 08:28 AM
shieldsy33
Jan 21, 2016 08:59 AM
cdavidell
Jan 21, 2016 01:49 AM
cdavidell
Jan 20, 2016 01:50 PM
cdavidell
Jan 20, 2016 01:46 PM
