Driver side window problem...
Old Feb 20, 2009 | 12:59 PM
  #26
3dognight's Avatar
3dognight
I just started having the same problem with my 08 MCS, but the weather here in the mid Willamette Valley in Oregon hasn't been all that cold. Don't think it would matter anyway since my MINI is parked in the garage at night and never gets iced over.
So, I'm really looking forward to arranging my first service call at the dealership which is 80 miles away.
Old Feb 23, 2009 | 09:29 AM
  #27
Jeru99's Avatar
Jeru99
Originally Posted by esonwood
Just had the response from my dealer BMW say it needs a software update so its booked in for mon 23rd i will let you guys know if this has worked
They fixed the window this morning. Fortunately, it only took a couple of hours, not counting the drive there and back. The service advisor said that this window issue is happening quite a bit and that there was some new guidance issued by MINI since I was there for the same problem just a couple of months ago. They didn't replace any parts. We'll see how long this fix lasts.
Old Feb 23, 2009 | 10:04 AM
  #28
BMacUC's Avatar
BMacUC
Same issue with my 08MCS and it has been rather frigid here in Cincinnati over the past few months. Just had it in for service last week and all is well since but reading this thread has got me a little worried. I also thought it may be an issue with cold weather but my SA told me it had nothing to do with it. And, I also worried about the functionality of the windows over the life of the car, especially in the cold months. Well hopefully, this first fix is the last for the windows...
Old Feb 23, 2009 | 10:58 AM
  #29
esonwood's Avatar
esonwood
mine has just had the software update done and so far so good i hope it lasts
Old Feb 24, 2009 | 04:28 AM
  #30
PaulK's Avatar
PaulK
Great thread. I am experiencing this problem since yesterday on my 08 Cooper. I was hoping to find some sort of reprogramming fix. Guess I'll have to call the dealer.
Old Feb 24, 2009 | 04:41 AM
  #31
cabwy's Avatar
cabwy
Hi all!!! I just had my windows' software updated for this very same problem.
My SA told me that the software update is basically a temporary fix but he is seeing it work for several other mini's in the area. He said that Mini is looking for a permanent solution but not to expect it to be introduced before another couple of months.
So far my "fix" is doing the trick!! (But it is hard to relax and not worry that my window might be down)
Old Feb 28, 2009 | 10:33 AM
  #32
MINIspud's Avatar
MINIspud
subscribing b/c i have this same issue and i was told it needs a sw update.
Old Mar 6, 2009 | 01:05 PM
  #33
3dognight's Avatar
3dognight
Well had my MINI in for window rehab on Wednesday. Window is now working fine. Also told them not to touch the tailpipes, which they honored. And also found out that I had the wrong floormats. My husband has complained about them not fitting right ever since I brought the car home. Turns out I had the european mats.
Old Mar 10, 2009 | 08:41 PM
  #34
User 051420's Avatar
User 051420
My car's in service for this right now.
Dealer opened a PUMA case, as there isn't a service bulletin out yet. SA claimed that the problem is rare to Northern CA, and they'll likely just reprogram the car.
If this car is as much of a shop queen as my last MINI...
Anybody else miss "real" switches?
Old Mar 11, 2009 | 08:27 PM
  #35
Bent13's Avatar
Bent13
Seems like a strange issue, hopefully it will be resolved soon.
Old Mar 12, 2009 | 02:48 PM
  #36
drewthat's Avatar
drewthat
Originally Posted by Sveen
LOL yeah right, except the window motor and all the fuses would blow if you got the car in the water. Unless they mounted the water sensor on the bottom of the car to give you a 5 second head start before the water reached the battery.
But you are correct on the second idea, the computer monitors the voltage from the lift motor to look for over-torque condition which would be cause by some thing getting trapped.
Actually they will not. Your power windows will continue to work even if the car is submerged under water. I don't know of any cars where the windows will roll down automatically when the car is submerged, but manually you can still open them.
Old Mar 12, 2009 | 02:57 PM
  #37
drewthat's Avatar
drewthat
Originally Posted by jaxsngrl
Cameroom- my dealer did say that the windows automatically opening is some safety feature but didn't specify what. I didn't think to ask till I was gone and thinking about what he told me.
It's a feature that keeps you from crushing your fingers if you were to put them on the glass and try to close the window. The window motor is able to sense resistance in the window, when it exceeds a certain threshold of resistance the window will automatically roll down half way. Keeps small children and pets from being accidentally decapitated.
You can try this your self. Open the door and keep it open (to avoid the danger of actually jamming your hand between the glass and the roof). Roll the window all the way down. Press the button for auto up and then quickly put your hand on the edge of the glass, as the window is going up apply downward pressure, the window will stop and roll back down.
In cold weather especially when you get snow and ice buildup on the window, or the window freezes shut, that ice adds resistance, and the motor senses it and the computer interprets it as little (insert pet name here) is getting it's (insert body part here) stuck in the window and rolls it back down.
When the window gets "reprogrammed" they are actually adjusting the resistance threshold, because the cars computer gets a little confused and has a tendency to lower the window even though the physical resistance is no longer there.
There's your safety feature
Old Mar 12, 2009 | 04:25 PM
  #38
GregO's Avatar
GregO
window
Some don't. And shouldn't.
http://www.youtube.com/watch?v=5dzi_8Rscfs
Hilarious though.
Greg
Old Mar 12, 2009 | 05:17 PM
  #39
JudgeS's Avatar
JudgeS
Just had a problem today, window didn't come back up after the door was closed getting in (had to hit the button to have it come all the way back up), it happened again when I wasn't paying attention, and window was about a half an inch down (started whistling). After I cleaned off the window seemed to go back to working normal. Hope it was just because of dirt/salt build up and not related to the ongoing issues here.
Old Mar 18, 2009 | 05:18 PM
  #40
ahmed412's Avatar
ahmed412
I have been to the dealer 4 times now, and getting very sick of it.
Every time they say there is a new update, but 2 days later, same thing.
Plus now I hear a lot of wind noise on the highway..
Old Mar 18, 2009 | 06:10 PM
  #41
chadtoolio's Avatar
chadtoolio
Just so some of you know...there was a bulletin release that stated that cars until 9-2009 could be affected by this issue. Although the reprogram could do some good, the bulletin made me aware that the problem could come back. I expect they are waiting on either further developement of software and testing or there is a third party vendor for the FRM that wont be released until the third quarter.
Old Mar 18, 2009 | 06:19 PM
  #42
chadtoolio's Avatar
chadtoolio
Originally Posted by Alto Clef
For those of you getting a software update, who also have the Bluetooth option, be sure to check that your phone still works before you leave the dealership. On my first "update" visit, I didn't think about doing this, and realized later my car and my phone were no longer talking to each other. Went back, and they told me they "updated the update", which could be legit, or the tech could have installed the wrong version of the update the first time...
My window is still working properly, fifteen days out.
The "wrong version" can't be installed in the car, at least not by us. The VO is determined by the SSS or PROGMAN and automatically determines what updates your car needs. No input from any dealer tech unless directed by Teileclearing would take place, wouldn't even have an alternate VO to install.
Old Mar 19, 2009 | 07:17 AM
  #43
Alto Clef's Avatar
Alto Clef
Thanks for the insight. I was guessing, based on my interpretation of the SA's comments. Do you have an idea how an update could have "killed" the Bluetooth? Does MINI (like some software companies) have difficulty issuing timely updates that are fully compatible?
Old Mar 19, 2009 | 05:23 PM
  #44
chadtoolio's Avatar
chadtoolio
I've seen random programming issues affect other modules, but not often. Is anything on your Most bus working. Do you have Sat. Radio, Hifi, or Ipod? Could be that he left the most bus cable unplugged. If you look under the Gbox on the right side, above and further back than the fuse box, you will see multiple sets of most bus cables. There will be several that are just loose for accessories but theres a rectangle plastic bracket that holds two connectors. They should be clipped onto the bracket. One would be a real pain in the *** to remove, and is not the one you have to access when programming. The other one however might be in the general area of the bracket and could be disconnected from it's mating half. Just look there and if you see 2 obvious connectors that should be together plug them in. These are Fiberoptic signals for Audio commands and such and no Power or ground runs through them so you can't damage anything. If that doesn't work, the ULF(Telephone module) would just have to be checked the normal way.
Old Mar 19, 2009 | 08:42 PM
  #45
Alto Clef's Avatar
Alto Clef
Everything was fine after a follow-up visit (for "updating the update"...), and as far as I could tell during the few days of Bluetooth outage, everything else was working fine (Hi-fi factory upgrade, non-satnav, ipod not connected at the time). Whether it was connector or a software tweak, whatever they did has kept the window and everything else working fine now for a few weeks. Thanks for the info!
Old Aug 18, 2009 | 07:52 PM
  #46
Tron Chief's Avatar
Tron Chief
Originally Posted by Jeru99
I just got off the phone with the dealer. The window reset procedure is to press the the window switch down and hold it down as the window lowers and keep holding it down for 15 seconds after the window has gone all the way down. Then flip the switch to the up position and hold it up while the window goes up and keep holding it up for 15 seconds after the window is all the way up.
Please note that when you go from holding the switch down to holding it up, that should all be in one motion. In other words, to do this correctly you should be holding the switch down or holding it up through the entire procedure. The switch should never rest in the middle position.
I haven't tried this yet. I literally just hung up with the service guy (who said he was well aware of the window issue). I'll post back to say if it works or not. I asked him if this was a permanent fix or if this would just be temporary (like when they did whatever they did to fix it a couple of months ago). He basically hedged and said that if it does happen again, they'll have to keep the car a few days.
I suspect if this does fix the problem, it probably isn't a permanent fix. It is good to know how to reset the window though so I can at least delay getting the permanent fix until I have to go in for scheduled maintenance.
My problem was with the passenger side window. It would not roll up with the key I had to hold the switch in the up position to get it to go up. It would open with the fob or with a single flip down. Resetting worked perfect thanks to the near 60,000 other Mini owners for the help
Old Jan 26, 2010 | 06:52 PM
  #47
cjboomer's Avatar
cjboomer
Same problem on the 2009
I live on the Central Coast of California and we have been experiencing unusually high amounts of rain. Last week I noticed that the driver's window wasn't making that little "pop" noise when it seals closed. The next day, my seat was wet, because the window was open enough to let in rain. I tried to raise the window, and it went to the top and then immediately came down again. This has been happening since. Fortunately, I can manage after several attempts to get it almost fully closed but not quite. Wouldn't the 09 have been reprogrammed? I live 160 miles from a dealer so this is a big deal. Anyone know how to fix it without taking it in? And why don't the dealers/manufacturers read these posts! I love my Mini but as far as getting good information (how about a DVD manual that really explains things? or a website manual?), it's the worst car I've owned. Anybody have a dealer with a website that has a FAQ or troubleshooting page?
Old Jan 26, 2010 | 06:59 PM
  #48
orangecrush's Avatar
orangecrush
If you call the dealer, you can get the exact instructions but if I remember correctly...
You close the doors and push both front window buttons and push them down, once down, hold them for 10 seconds and then roll them up. When you hit the top, again, hold the buttons for 10 seconds.
Then go down one last time. Again, when you hit the bottom, hold the buttons in the down position for 10 more seconds.
Whenever we disconnect batteries in the bodyshop, we have to do this to many cars.
It's no big deal and once you get it done, you shouldn't have a problem again.
If my instructions don't work, call the dealer and they'll tell you how to do it over the phone.
HTH's,
Mark
Old Jan 26, 2010 | 07:04 PM
  #49
orangecrush
Well, don't I have egg on my face.
I thought no one answered so I was trying to help. Apparently you've already got it fixed and a dozen answers.
My bad...
Mark
Old Jan 26, 2010 | 07:17 PM
  #50
Bent13's Avatar
Bent13
Pain in the *** problem, I've had my car in 4 times for this problem in a year. They "reprogrammed" it 3 times and told me I got an updated module the last time in November. I still have the problem... It works for a while after programming then acts up permanantly
