CooperSAZ's 2005 LY/Blk R53
Old Mar 13, 2016 | 05:08 PM
  #126
CooperSAZ's Avatar
CooperSAZ
I finally got around to swapping out the outer ball joints. Not a hard job by any means but it helps if you have the right tools.
After raising the vehicle and supporting him with jackstands, time to remove the wheels
Here is the driver side lower outer ball joint. At 111,000 miles, I figure they were due to replace.
I chose to remove the two 13mm bolts first. After impacting them off, the LBJ was stuck onto the hub. I grabbed my flathead screwdriver and tapped on the LBJ to jar it loose. Worked after a few taps.
I must have used this tool a million times. Cant imagine life without one.
Now as you apply pressure to the LBJ, I typically choose to lower the garage door down before the BOOM happens. When the LBJ pops out from the lower control arm, there is typically a sizeable BOOM/BANG. I elected to keep the nut on the LBJ as well so nothing takes flight when the LBJ is popped. Name:  DSC06513_zpsugua15sz.jpg
Old lower ball joint vs the new lower ball joint.
Cap removed off of the new lower ball joint. One thing I did notice was playing around with the old lower ball joint. You could swing the old LBJ bolt in 360-degrees at will. With the new LBJ, that thing is so stiff that you are not moving it much, if at all. This is a great way to help stiffen things back up on the suspension.
One thing I do not understand about MINI… The lower ball joints installed on the car back in 2004 were a standard hex-shaped 13mm bolt. Why go to a torx bit? In any event, you will need a T50 bit to torque/secure the LBJ mounting bolts.
Here is the driver side LBJ put back together but not torqued.
Torqued and ready to move to the passenger side.
Old Mar 13, 2016 | 05:09 PM
  #127
CooperSAZ's Avatar
CooperSAZ
Impacted the passenger side lower ball joint nut and the inner wheel carrier nut
Same thing as the driver side. I removed the 13mm bolts holding the LBJ to the hub. On this side, the lower ball joint just fell into my hand. No flathead screwdriver required to separate the lower ball joint.
Lower ball joint separator back in place. Boom coming…
Post-BOOM. Again, leave the nut onto the lower ball joint so nothing takes off on you.
New vs old
Starting the T50 mounting bolts to secure the lower ball joint
T50 bolts torqued and now I am just lining the lower control arm back up.
Everything is torqued and buttoned back up.
Again, I had to use this handmade pic of the surrounding area:
Old Mar 14, 2016 | 11:29 AM
  #128
Love the pics, bet the front end feels much tighter, mine did after 150K.
Old Mar 14, 2016 | 12:14 PM
  #129
CooperSAZ's Avatar
CooperSAZ
Thank you! It has tightened up a bit! Very noticeable.
Question, why go to a torx bit? The bolts on the car when built were a standard 13mm hex. Now they are T50 torx and circular? I dont get it...
Is there a benefit with going to a torx bolt? Or are they just having fun with us? hehe
Old Mar 14, 2016 | 12:25 PM
  #130
They like to change things up with suppliers and safety things , keep us on our feet.
Old Mar 14, 2016 | 01:40 PM
  #131
CooperSAZ's Avatar
CooperSAZ
They like to change thing up with suppliers and safety things , keep us on our feet.
How shameful! hahaha
Old May 31, 2016 | 09:06 AM
  #132
CooperSAZ's Avatar
CooperSAZ
I did the annual swap out of my wiper blades when I noticed one of my brake lights were out. Took some time to swap out the lights and replace them with new units. Back to motoring. 5 minute fix.
I gave him a bath and broke out my polisher and gave him a new coat of polish and wax.
Debating on picking up some black plasti dip and painting the wheels for fun. Curious to see what it would look like...
Old Jun 5, 2016 | 03:46 PM
  #133
sevin's Avatar
sevin
She looks great! Always fun to read your little logs.
This is something that's on my radar as well. From what I can tell, the black is a good match as the trim is already matte and you'll never have to worry about it fading again. No downsides that I can see.
Old Jun 7, 2016 | 10:55 AM
  #134
CooperSAZ's Avatar
CooperSAZ
Thank you!
I agree! I am leaning towards the matte finish as well. Glossy might conflict with the trim too much. Thanks for the feedback!
Old Jul 2, 2016 | 08:46 PM
  #135
CooperSAZ's Avatar
CooperSAZ
Gave him a bath today. Cleans up well.
Out and about, the check engine light came on today. Woopee! Car ran fine, came home and put him in the garage. Connected him to the scanner and code P0340 came up. Camshaft Position Sensor! I guess it could be worse.
Cruising through NAM, it appears that the standard operating procedure is to clear the code and wait for strike two. So that is what I did. I cleared the code and took him for a test drive. Put on about 10-15 miles and nothing. He appears to be running fine like any other day. So I will sit and wait.
Mileage marker – 113,028 miles.
Currently, I am (being lazy and) sitting on the following parts: power steering hydraulic lines, fluid and new power steering fan, new radiator, new hoses and plastic connectors, new MINI fluid, new thermostat, new oil pan gasket, new dip stick o-ring and camshaft position sensor o-ring.
I will order the new sensor along with the transmission mount for when I go in and replace a bunch of stuff. Glad I was being a little lazy… I hate going in twice. But if the car triggered the CEL once, I can only assume it will do it again? While I am replacing the radiator, the front end will be exposed and make this sensor swap quite easy. Might as well while I am in there!
Cheers to all and Happy Fourth of July!
Old Jul 4, 2016 | 06:35 AM
  #136
minsanity's Avatar
minsanity
I remain a fan.
Great work!!!!
Old Jul 9, 2016 | 10:54 AM
  #137
CooperSAZ's Avatar
CooperSAZ
Originally Posted by minsanity
I remain a fan.
Great work!!!!
Thank you sir!
Old Jul 9, 2016 | 11:18 AM
  #138
CooperSAZ's Avatar
CooperSAZ
Spent some time on the MINI this morning.
I have been experiencing some odd things but was unable to put a finger on what it was… I was experiencing the following:
- Rough start/idle until warmed up which generated a sound that appeared to be valve train related (to me)
- There was a metallic flutter/valvetrain sound at idle (warm) up to 1500-1800rpm and then it disappears. Not the diesel sound emitted from a going belt tensioner but in the ballpark of that sound.
- Apparent loss of power in the higher rpm range of each gear
- (Recently) the DSC light would be triggered and stay on, until the MINI is shut down. Light is reset and off until triggered again.
- (Recently) The ‘Check Engine Soon’ light came on but the MINI appeared to be running fine.
Threw him on the scanner and picked up code P0340 – Camshaft Position Sensor.
I cleared the code and waited to see how long it took before it came back on. That was the same day or about 12 miles later. Here is your sign! Hehe So not knowing or wanting to screw things up, we parked him for a few days and the wife took the Ody to work and I took the CRX to work. Nice having three cars for that reason.
So I went ahead and ordered a replacement part from a local dealership and it arrived is $82 flat.
Let the fun begin!
Safety first. I felt compelled to jack him into the air so that I could sneak the jack underneath the motor to support it while I remove the engine bracket.
Bay shot
Coming around the side and focusing on the passenger side
Focusing on the camshaft position sensor
You have to remove the passenger side engine bracket. This consists of 4 main bolts that secure the bracket to the engine, a single nut (18mm) securing the bracket to the passenger side mount and a little nut/bolt for the ground wire. This is the time to place the jack underneath the motor to support it for when the bracket is removed. I typically get the motor to lift a fraction of an inch to let me know it is in place.
Here are the front 2 main bracket to motor bolts. (16mm) An extension will serve you well.
Here are the 2 rear main bolts securing the bracket to the engine.
Bracket has been removed and now the old camshaft position sensor is visible.
The red piece is a ‘lock’ that needs to be slide one way or the other to unlock the sensor. Then push down on the tab and disconnect the sensor from the wiring harness.
Old Jul 9, 2016 | 11:19 AM
  #139
CooperSAZ's Avatar
CooperSAZ
Old camshaft position sensor removed with some oil on it.
Old sensor vs New sensor
Here is the location on the cylinder head where the sensor fits into to monitor the camshaft. The sensor was covered in oil so that tells me that after 113k miles, the o-ring was failing and I was leaking a small amount of oil.
Here is the red locking mechanism on the wiring harness. I don’t think I have seen a picture of this before so I thought I would post how is works to help someone out.
Locked:
Unlocked:
Here is a great pic of the old sensor depicting oil pre o-ring and post o-ring. Oil is clearly getting past the o-ring and then leaking out on the side of the motor… shameful!
While the engine bracket was out, I decided to clean it up so it is ready to get installed back under the bonnet…
Old Jul 9, 2016 | 11:20 AM
  #140
CooperSAZ's Avatar
CooperSAZ
New camshaft sensor installed. There is a single 10mm bolt that secures the sensor to the cylinder head. Does not need to be gorilla tight, just snug
Panning out with the new sensor installed
Wiring harness connected to the new installed sensor. Notice the red part on the wiring harness in the unlocked position.
Red slide on the harness slide over into the locked position
Once that is complete, its time to slide the engine bracket into place and around all of the hoses
Front two bolts securing the bracket to the motor
Two main rear bolts torqued securing the bracket to the engine
Align the motor so it sits on the engine mount. Torque the motor mount nut back down
Ground wire secured and you are done! Engine bay shot and everything buttoned back up
Old Jul 9, 2016 | 11:28 AM
  #141
CooperSAZ's Avatar
CooperSAZ
After everything was buttoned up, I turned him over. Expecting the worst, I heard nothing but the motor turning over and idling beautifully. No metallic valvetrain (to me) sound at idle or starting up.
Interesting…
Rev a few times and the car sounds fantastic! Let him idle for about 5 minutes and no engine lights… Good sign… Time for a test drive. Took him for a quick stroll around the block incase there is a failure. He did great and sounds great. Much more quite albeit there is an intake, header and exhaust on him.
Time for a longer range test and got him to a major street before opening him up.
Wow, I would be willing to bet a picked up a bit of performance now. You never really know WHEN you start to lose power… but you surely know WHEN you gain it back. He is much more spunky through all of the gears! Wow. Big difference. Is that possible to get some power back? This monitors the camshaft position, so does this impact the ignition timing and fuel introduction?
Something happened and he feels like brand new again… much more spunky and he pulls much more now. Very happy camper. I am about 15 miles in now and no check engine light.
Fingers are crossed that this is it so I am pretty happy. I would encourage anyone to swap out this sensor if you get the chance. Its $75-85 depending, very straightforward to swap out and in the end, you eliminate a small oil leak and gain a bit of performance back.
I will follow up once I have a few more miles under my belt.
Cheers.
Old Jul 13, 2016 | 01:25 PM
  #142
apljcks's Avatar
apljcks
I created an account, just to say thank you for this. You wanna come to Yuma and work on mine? haha
Old Jul 13, 2016 | 03:15 PM
  #143
CooperSAZ's Avatar
CooperSAZ
Welcome to the forum! Thank you for the kind words.
I hope it helps people out along the way. The forum has been good to me so I want to pay it forward.
What else do you have to work on?
Old Jul 13, 2016 | 03:50 PM
  #144
apljcks's Avatar
apljcks
Well, I just got rid of my 2000 BMW Z3 in exchange for a 06 Chili Red R53. I think it basically needs everything you have done so far. Honestly this is really the only thread I have found that comprehensively covers all of this basic maintenance stuff that needs to be done. Someone should sticky this.
Old Jul 20, 2016 | 11:02 PM
  #145
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
Apljcks, join the club! I bought mine 3 months ago, just did all the motor mounts, control arm bushings, ball joints, cv boots, front crankshaft position sensor, timing chain tensioner, radiator resistor, bypass valve, and oil pan!!! It seems like 2016 is the year a bunch of us second/third generation of owners to decide to revive these things!
Just...uh...be prepared for it to stop working...a lot. I've owned mine for just over three months and I've only driven it to work 10-15 times, lol.
Old Jul 21, 2016 | 09:44 AM
  #146
CooperSAZ's Avatar
CooperSAZ
Liquid Yellow is starting to be a rare color and its not often you can catch two in the same pic!
sarom058’s MINI along with my MINI. Excuse the dust, he just got his Cooper mobile again...
Old Jul 21, 2016 | 10:10 AM
  #147
sarom058's Avatar
sarom058
My MINI just got so excited to see a friend! ...and then after six weeks in the garage, it promptly broke again a day later
Old Jul 21, 2016 | 10:25 AM
  #148
CooperSAZ's Avatar
CooperSAZ
What? It was running so well!
Old Jul 21, 2016 | 10:50 AM
  #149
Nice to see to LY park together. yea, what happened :(
Old Jul 21, 2016 | 12:58 PM
  #150
CooperSAZ's Avatar
CooperSAZ
Having some fun here…
