R57 Rear fog light
Old May 6, 2021 | 03:32 PM
taker442's Avatar
taker442
Rear fog light
I am new to this car so this might be a dumb question.
i have a 2012 r57 convertible, it has the fog light option on it but the rear fog light does not work?
I took it out and there is a bulb there.
But the fog light switch only has the symbol for the front lights only.
Does that mean the rear fog light does not work?
If so, why does it have a socket and bulb in it?
My manual says I turn on the fog lights and then push down on the switch and should turn on the rear one.
If anyone can help that would be great.
Old May 7, 2021 | 03:54 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
All cars were shipped with the exterior fixtures and wring required. However, To enable the rear fog, you need install the dash switch and have the car coded to activate the feature.
https://www.northamericanmotoring.co...-retrofit.html
Old May 7, 2021 | 06:59 AM
taker442's Avatar
taker442
I do have a fog light switch. Is there a different one I need? My car was equipped with front fog lights. And the fixture has wiring to it for the reverse lights at least.
Old May 7, 2021 | 07:03 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Its a separate switch for the rear fog lights. Your switch panel would look like this if you had the rear fog light option:
The fog switch on the right side is for the rear fog light.
Old May 7, 2021 | 07:25 AM
taker442's Avatar
taker442
Here is a picture of my cars switches, not a separate switch
Old May 7, 2021 | 07:34 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
OK, I did a little extra searching...
You switch panel would look like this with the rear fog light option:
Old May 7, 2021 | 09:01 AM
taker442's Avatar
taker442
Thanks!
Looks like I have front fog lights but not a rear one.
Strange?
Thanks for the information.
Old May 7, 2021 | 09:47 AM
Juppers's Avatar
Juppers
If they share the switch, you may only need the option coded.
Old May 7, 2021 | 10:26 AM
MVPeters's Avatar
MVPeters
Rear fogs were not a common option selected by US owners, though many cars already had the wiring & lamps fitted anyway.
I think you'll at least need to change the switch panel for the one njaremka posted Then get the option coded, probably by the $$$ealer, though with a little luck, it might not need coding!
Old May 7, 2021 | 11:01 AM
taker442's Avatar
taker442
I have not seen a switch panel like that?
must be few and far between.
I do plan on looking for one thou, just to see if I can get it to work.
drpep
Feb 28, 2016 05:33 PM
richie6
R55 :: Clubman Talk (2008+)
Jul 29, 2014 10:09 AM
Bruce/Fl
Oct 16, 2008 08:54 PM
markvibari
South East - Florida
Jun 18, 2003 12:20 PM
Pebbles
Mar 1, 2003 04:20 PM
