R56 AC only works at idle
Old Jul 25, 2015 | 06:38 AM
mattjewell's Avatar
mattjewell
07 MCS 66k.
Recharged the system, AC blew nice and cold while driving main roads. After about a 40 minute highway drive, I noticed the AC getting warmer and warmer, to eventually not being cold at all. Weird thing is, is when I come to a stop light or really low speed, it gets cold again.
Any ideas on where to start?
Old Jul 25, 2015 | 07:57 AM
NB Cooper's Avatar
NB Cooper
It kind of sounds like one of the pressure switches is shutting down the system. At idle the pressures allow the system to function.
Old Jul 25, 2015 | 09:52 AM
AZdsrt's Avatar
AZdsrt
Wild guess here; but it sounds like you over charged the system..
Old Jul 25, 2015 | 10:04 AM
mattjewell's Avatar
mattjewell
It did this same thing before, but not as cold. Completely drained the system and then recharged to appropriate level.
Where are the pressure switches located?
Old Jul 25, 2015 | 11:42 AM
celticfc's Avatar
celticfc
I would recommend going to Harbor Freight and picking up a set of gauges they will tell you all you need to know. It sounds like you overfilled the system and will need to re-do it. You can do a fair amount of damage by overfilling. The gauges will take out a lot of the guess work. I very much doubt you have a problem with the pressure switches, given that it sounds like they are doing their job. See link below for the gauge kit.
http://www.harborfreight.com/a-c-man...set-92649.html
Old Jul 25, 2015 | 01:08 PM
mattjewell's Avatar
mattjewell
Thanks for the reply.
I have a set of gauges. I put in a little over a pound of refrigerant, that's what I've seen to be the correct amount. 1.08 to be exact.
Old Jul 25, 2015 | 01:33 PM
Ender's Avatar
Ender
are your gauges any good? it sounds exactly like a overfill problem maybe get another set to see if something is wrong with your set.. and was the system empty before you put the pound in? did u use a vacuum pump to remove all refrigerant? did you weigh what you pulled out?
Old Jul 25, 2015 | 05:30 PM
ZippyNH's Avatar
ZippyNH
Too much oil from adding the oil+r134a cans can cause a similar issue...many cans have oil plus gas...if you don't shake the can as you add it, or keep adding cans over a couple years to make up for a leak, the oil volumes keeps getting higher....
iggi
18
Feb 9, 2026 01:00 AM
mdutton11
14
Oct 26, 2015 01:47 PM
pocketmaster
Aug 11, 2015 07:36 AM
Lt. Dan
Aug 10, 2015 12:46 PM
Lt. Dan
Aug 10, 2015 08:23 AM
