R56 My full engine built will be here.
Old Jul 13, 2015 | 03:26 PM
  #501
minivinnie92's Avatar
minivinnie92
I wish I was closer :(
Old Jul 13, 2015 | 05:27 PM
  #502
cerenkov's Avatar
cerenkov
Same here. I'd love to experience this build in person.
Old Jul 13, 2015 | 07:05 PM
  #503
Indimanic's Avatar
Indimanic
Yay..,
No more oiled air filters 4 u!!
I guess a good lesson to watch grams per....
You can try cleaning it if has less than 40K on it.
I wonder if a JCW MAF would make sense as you are sucking a lot more air??
Question for Nick.
Old Jul 13, 2015 | 07:18 PM
  #504
SPRINTCARS's Avatar
SPRINTCARS
Originally Posted by Indimanic
Yay..,
Question for Nick.
The oil that was on the filter was from the factory. I never sprayed oil on it. How it came from AEM when I bought the system is how it was. And that was 2 years ago.
Old Jul 13, 2015 | 10:19 PM
  #505
hamptup's Avatar
hamptup
All it was just an oily maf from a filter that caused all the grief?
Glad you're back on track!
Old Jul 14, 2015 | 06:46 AM
  #506
SPRINTCARS's Avatar
SPRINTCARS
Actually, I can't really say it was oil from the air filter. That air filter was on the car for prolly 2-3 years prior to this incident and I never sprayed it with any kind of oil. Also, the MAF sensor was brand new in March or April when I got the new motor built. At that time, I purchased every sensor new that controls the engine. Now it seems that I'm having issues with all the new sensors and slowly but surely I'm resorting back to all my old original sensors. The very same sensors that have about 174,000 miles on them.
Old Jul 14, 2015 | 07:01 AM
  #507
minivinnie92
That's just crazy I doubt it's the oil I've cleaned and 're oiled my air filter several times in past 2 years never an issue I actually just cleaned my maf just to make sure
Old Jul 17, 2015 | 04:00 PM
  #508
SPRINTCARS's Avatar
SPRINTCARS
13.466 ET
104.67 MPH
Map B
With methanol.
Old Jul 17, 2015 | 04:01 PM
  #509
SPRINTCARS's Avatar
SPRINTCARS
Originally Posted by SPRINTCARS
13.466 ET
104.67 MPH
Map B
With methanol.
With no updates or fine tuning yet.
Basically out of the box tune.
Old Jul 17, 2015 | 04:32 PM
  #510
Gearheadaddy's Avatar
Gearheadaddy
Possibilities
I've been a Gearhead for a while...since the late 60's...These ecu's "learn" things and adjust to all kinds of different variables. I have a 2010 Mayfair S with a dealer installed JCW Tuning Kit. Not only did the car run better after the Tuning Kit install but the Mini technition/installer has worked on Minis for years and is one of the best around So Cal. The software at the time of install was not to his liking so it was sent back a few times until he/we were satisfied. A few weeks ago the timing chain apparently went bad and was replaced. My issue was the car seemed like the timing was off and began a herky jerky run upon uphill runs. After all was done (TC set replaced, valve cover too because the valving inside wasn't operating correctly) the car wasn't right. Boost off, timing off. All this with NO CEL EVER SEEN before or after. I brought it in and requested the ecu to be reset. Presto! Runs like it should, boost back, timing good, lots of HP....My advice: RESET THE ECU...Tranny shift points too. Evidently the ecu "learned and compensated" for bad parts!...Reset that ecu...
Old Jul 17, 2015 | 04:58 PM
  #511
cerenkov's Avatar
cerenkov
Nice. Do you think it's capable of running in the 12's? Being front wheel drive it's probably going to be severely limited by lack of traction and not power.
Old Jul 17, 2015 | 05:10 PM
  #512
SPRINTCARS's Avatar
SPRINTCARS
Idk. After a few updates. I think it might be close. If the tuner was hear at the track with me and tuned it that way, yea, I think so.
Old Jul 17, 2015 | 05:15 PM
  #513
SPRINTCARS's Avatar
SPRINTCARS
That's a past problem. We're fixed and doing data logs now
Old Jul 17, 2015 | 07:34 PM
  #514
minivinnie92
What track did you go to atco?
Old Jul 18, 2015 | 06:17 AM
  #515
SPRINTCARS's Avatar
SPRINTCARS
Cecil county
Old Jul 18, 2015 | 07:17 AM
  #516
SPRINTCARS's Avatar
SPRINTCARS
Wonder how well a halo system would work. Spraying it with co2
Old Jul 18, 2015 | 08:22 PM
  #517
Indimanic's Avatar
Indimanic
When replacing MAF, the adaptation factors should be reset. Perhaps MAPS too. This will cause some issues, perhaps not to the extent mentioned here. This must be done with a suitable scanner either factory or a full Auologic unit.
We all know oil on a MAF is bad. Running the same oiled filter for 2 years and ?? miles without cleaning cannot be good at all especially with oiled filters which are not a good option anyway.
Old Jul 20, 2015 | 12:09 AM
  #518
Systemlord's Avatar
Systemlord
What about this, could this solve your boost issues? Link
Old Jul 20, 2015 | 12:24 PM
  #519
SPRINTCARS's Avatar
SPRINTCARS
The boost issue is solved folks. Already had it to the local track as well. Waiting on ecu updates from doing data logs now.
Old Jul 20, 2015 | 12:26 PM
  #520
SPRINTCARS's Avatar
SPRINTCARS
What would be really nice is if a company would come up with some software so the shift points could be adjusted at wide open throttle for the automatic cars.
Old Jul 20, 2015 | 12:29 PM
  #521
cerenkov's Avatar
cerenkov
Do you not have "manual" mode?
Old Jul 20, 2015 | 02:08 PM
  #522
SPRINTCARS's Avatar
SPRINTCARS
Yes, manual mode doesn't mean the car is then full manual shifting. It will shift on its own if it senses it's at its max rpm for the trans.
Old Jul 20, 2015 | 04:14 PM
  #523
minivinnie92
I'm going to have to meet you at the track one day and see that beast run
Old Jul 20, 2015 | 04:25 PM
  #524
Systemlord's Avatar
Systemlord
This is excellent news, can't wait to see your boost and logging data. Sorry for my bad memory but what was the compression ratio you went with? 9.5:1 ratio?
Old Jul 20, 2015 | 04:54 PM
  #525
SPRINTCARS's Avatar
SPRINTCARS
Yes, pistons are 9.5:1. Final is between 8.78:1-9.0:1
