R56 My full engine built will be here.
Old May 28, 2015 | 06:46 AM
  #401
Steven_RW's Avatar
Steven_RW
Originally Posted by oldbrokenwind
When choosing new pistons for my rebuild, I went against all recommendations and stayed with 10.5:1 and 77mm --- cylinder walls weren't deformed or scored. Knowing 30PSI was the target boost, I just wasn't comfortable reading about lowering the CR. Maybe when playing with 7+ liter engines, this philosophy is good, I don't believe it necessarily applies to our 1.6L engine. Maybe there's some other advantage I'm not aware of?
Also, my CP / Carrillo pistons have the same configuration dome as the OEM pistons.
And for results, I can't imagine lowering the CR would produce more than my current 312WHP & 321 ft.lbs torque. Maybe, but I'm happy with what I've got!
In most applications lowering the compression ratio protects against Detonation. The JCW as 10.0:1 and the peugoet RCZ-R has 9.2:1 based on 270 bhp. There is some logic that as the BHP per CC goes up or better the cylinder pressure goes up, that unless you have special fuel, the chances are you are better off and safer with lower comp.
Mine detted at 265 bhp on 10.5:1 on the best fuel I can buy in the UK gas stations.
So we need less compression for safety :-)
Appreciate you feel you have the experience here and I wish mine hadn't needed rebuilt either!! :-)
Steven RW
Old May 28, 2015 | 05:35 PM
  #402
ridinDirty's Avatar
ridinDirty
I would tap your oil fill cap and mount a gauge to see what kind of vacuum you get. I was reading online and most where saying anything pass 12-14"hg you can suck oil off the wrist pins etc. 18" seams like a far out there number .... Hell I would be happy with 6 +"hg
Thanks for posting your build, the good ,the bad and the ugly......
Old Jun 9, 2015 | 06:23 PM
  #403
SPRINTCARS's Avatar
SPRINTCARS
It's back on the road. 200 miles down. Hopefully 1,000's to go.
Gonna start some data logging again. Hooked up the factory PCV system. I'm gonna choose to just keep it clean until I get the seperate vacuum system on it. I don't like not having vacuum on the crankcase with low tension rings.
Another note, HEY NAM, DONT YOU THINK ITS ABOUT TIME TO GET THE APP FIXED ?!?! It's been quite awhile and it's starting to getting annoying. Hard to keep up with people that we've all had conversations with. Harder to help folks as well.
New thread soon to be made with dyno results, parts list and cost. Motor on people.
Old Jun 9, 2015 | 07:18 PM
  #404
cerenkov's Avatar
cerenkov
Great news!
As for the app download the new app from the App Store. Is it called Garage Talk.
Old Jun 9, 2015 | 07:30 PM
  #405
SPRINTCARS's Avatar
SPRINTCARS
Cool. Now I can join in a lot easier. That's was easy
Old Jun 9, 2015 | 07:38 PM
  #406
minivinnie92's Avatar
minivinnie92
ya I thought the same thing until I downloaded the new app damn technology
Old Jun 10, 2015 | 07:03 AM
  #407
Great new, thanks for the update
This is a great thread.
Old Jun 10, 2015 | 02:11 PM
  #408
Gearheadaddy's Avatar
Gearheadaddy
NAM App
NAM may have to completely rewrite their app for our new operating system for it to work again. (Lollipop 5.0 and 5.0.1 and 5.0.2)
Old Jun 10, 2015 | 09:10 PM
  #409
ridinDirty's Avatar
ridinDirty
sweet deal Jeff.
I know you want to put your foot in it but be patient grasshopper.... .......lol
Old Jun 22, 2015 | 04:36 PM
  #410
SPRINTCARS's Avatar
SPRINTCARS
As I sit here in the hospital getting a knee replacement, the girl has the little monster. It's set to map A for her. Atleast I know it'll get some good slow break in time now.
When I get moving I'll post some nice info.
Motor on people. And for your tuning needs,
ðŸ‘GO MANIC OR GO HOME !!ðŸ‘😎
Old Jun 22, 2015 | 06:46 PM
  #411
minivinnie92
if I remember we are both in Jersey 😃 I would be more than willing to come down there and help a fellow Nam member in his time of need and drive that beast for you lol!
Old Jun 22, 2015 | 11:41 PM
  #412
scubbysnacks's Avatar
scubbysnacks
That knee must of been the cause for early retirement from that career in UFC cage fighting
Remember you only needed one functioning leg to drive an auto.good luck with the operation
Old Jun 29, 2015 | 03:47 PM
  #413
SPRINTCARS's Avatar
SPRINTCARS
Thanks scubby. I'm out and home now. It's tough going. When I can I get back to the car. Tried data logging. That's a waste of damn time. Changed the pressure converter valve. Put new vacuum lines on. Checked, doubled check, tried a different configuration. Checked the converter valve even changed incase there was a pin he I didn't see. Map A. Boost won't go over 15. Shift to next gear drops to 10. Won't go above it. So I tried map C. Same deals but goes to 20 max. Shift to 3rd. So much for boost. Won't go above 12 psi. Only thing I didn't do was put the catch back on. It's got the factory pcv system right now cause I want vacuum on the rings and crankcase when boost is not applied. Maybe the valve cover can't handle what I got going on. But I'm sure I'm not the only one running this kind of boost. I'm about tired of screwing with this damn car.
Old Jun 29, 2015 | 05:18 PM
  #414
scubbysnacks
Weird from your previous post sounded like it was boosting fine what's changed? I don't think its your valve cover remember ever ones got to use it because it the only on available. Maybe Manic has some ideas on what might be causing it.
Obviously the car feels down on power(no false boost reading) and if you were getting a code that's the first thing you would have mentioned almost sounds like the ECU is limiting boost or some things happen to the turbo.
Old Jun 29, 2015 | 05:23 PM
  #415
ra2fanatic's Avatar
ra2fanatic
Geez, sorry to hear about the boosting issue. I think that's a reason why I haven't bothered and likely won't bother to rebuild the bottom end of my MINI. I think that time has passed for me. I like what it is now on my Stage4 tune, which I just drive in Stage3 now anyways because it's plenty of power/usage for me.
If I need power, I have a 425hp M3 now, so I've got that covered!
Old Jun 29, 2015 | 05:40 PM
  #416
SPRINTCARS's Avatar
SPRINTCARS
Yea, I don't what happen dude. Fixed a few things. It was fine. I've got a few tests to do and change a few hoses around. I took the catch can off and ran stock pcv system. Cause I wanted vacuum in the bottom end at idle. It didn't have that in the beginning. Keep in mind, when it jumps from vacuum to boost, it spikes like super fast. Than diaphragm in the valve cover might not be able to take that kind of abuse.
My vacuum lines starting at the pump are as follows, Pump to vacuum canister
Vacuum canister to the pressure converter.
Big port on the pressure converter to the wastegate.
Old Jun 29, 2015 | 05:41 PM
  #417
oldbrokenwind's Avatar
oldbrokenwind
I had a similar boost problem last month in Vegas --- well over 100deg F. Ran fine while cool, and only intermittently wouldn't boost over 10psi or so. Got back home to temps in the 90's and haven't had a problem yet. My max boost is set to 30psi, but it's configured so the PCV never sees positive pressure. Anyhow, could your problem be ambient air temperature related?
Old Jun 29, 2015 | 05:54 PM
  #418
SPRINTCARS's Avatar
SPRINTCARS
The ambient air pressure sensor ?
Had a surge that went from 20psi to 10 psi. Only see that on the interstate tho
Old Jun 29, 2015 | 06:09 PM
  #419
oldbrokenwind
I'm not inferring a faulty sensor, just the possibility that hot ambient air is causing the aftermarket tune to react badly. In my case, it may also be a faulty external BOV or wastegate diaphragm --- something reacting to excessive ambient heat. Hasn't happened since I left the heat.
Old Jun 29, 2015 | 06:21 PM
  #420
SPRINTCARS's Avatar
SPRINTCARS
Ooohhhh. I see, nahhhh. I don't think it's ambient air temp. Hasn't been that hot in the philly/south jersey area yet. And it's done this samething on the way home from work. Which is late night. It didn't discriminate what the temp was.
Old Jun 29, 2015 | 08:32 PM
  #421
SPRINTCARS's Avatar
SPRINTCARS
Well not of that worked. I'm done dealing with it. It runs and won't blow up. Screw it. When I feel like dealing with it I'll be back. But after all that's happened, my patience have ran out.
Oh and I forgot, all the boost tube clamps are tight.
Old Jun 29, 2015 | 11:38 PM
  #422
scubbysnacks
I understand what oldbrokenwind is saying. When you data log also log iat your sensor might be bad giving you a high reading and the ECU is reducing the Max boost.
Old Jun 30, 2015 | 12:05 AM
  #423
SPRINTCARS's Avatar
SPRINTCARS
I'll look into when feel like working on it again I'm really tired of dealing with it. I seriously appreciate to the help tho. I'll definitely keep reading suggestions. IAT sensor is in the plastic tube on passenger side right ?
Old Jun 30, 2015 | 02:30 AM
  #424
cerenkov's Avatar
cerenkov
I believe that the outside temperature that is displayed in the tachometer display comes from the same IAT sensor. So if that is reading correctly then the car is reading the correct IAT.
It's got to be in the the vacuum system. Are you using the stock diverter valve? I'd think that would cause a CEL though.
Old Jun 30, 2015 | 03:17 AM
  #425
scubbysnacks
Damn Cerenkov you crazy the tach reading comes from a sensor near the front bumper.
Yes Mr Sprintcars the sensor on the hard pipe next to the valve cover is the iat sensor
