R56 ra2fanatic's R56S build
Old Mar 8, 2014 | 02:37 PM
  #326
TazMinianDevil's Avatar
TazMinianDevil
What's your current intake of choice? I've been running DOS for awhile but now think about try NMs 360 design.
Old Mar 8, 2014 | 03:32 PM
  #327
BattleTuning's Avatar
BattleTuning
Everyone has their preference of intakes, so we let that be up to the user to decide which is better for them.
Old Mar 8, 2014 | 04:25 PM
  #328
george_talbot's Avatar
george_talbot
Originally Posted by ra2fanatic
Ah....very nice. Which LSD are you going with? How will the helix clutch kit compare to stock? I haven't decided what route to go with on the clutch. LSD, I'll likely go with the Quaife later this year.
I believe the helix 4 paddle clutch and lightweight flywheel will be a lot more aggressive than stock but its become a track car so thats not an issue. The clutch is rated to quite a bit more torque than I have so it should be up to the task of dealing with the power unlike the stock clutch which is made from cheese.
I will be ordering a plated diff from a UK company called "Gripper". They customise the settings to what kind of setup you want are a lot more effective than a quaife. However, they do need to be serviced and are not as road friendly when configured for the track.
Old Mar 8, 2014 | 06:37 PM
  #329
ra2fanatic's Avatar
ra2fanatic
Ah okay.
Old Mar 9, 2014 | 10:52 PM
  #330
ra2fanatic's Avatar
ra2fanatic
Intercooler arrives tomorrow!
BUT....because Sneed hasn't updated me on my oil cooler I can't complete the build until that is in....I still have no clue if it shipped or not. Or if it was even in stock! So a bit disappointed that I haven't been updated on the shipping..
Old Mar 10, 2014 | 04:08 AM
  #331
TazMinianDevil
Intercooler arrives tomorrow! BUT....because Sneed hasn't updated me on my oil cooler I can't complete the build until that is in....I still have no clue if it shipped or not. Or if it was even in stock! So a bit disappointed that I haven't been updated on the shipping..
Double check all fittings, even the metal U pipe connection for the coolant that is preinstalled. Mine had a leak due to the pipe flares not seating completely. Also I had to install the cooler fairly high on the AC condenser to get clearance. Lastly the JCW required some trimming to get hoses routed due to brake cooling ducts.
Old Mar 10, 2014 | 06:16 AM
  #332
Grizld700's Avatar
Grizld700
Originally Posted by BattleTuning
The differences between a facelifted model compared to the "pre" is core thickness. So a '07 can fit a competition or facelifted version and only thing would need addressing is trimming a bit of the grill.
All mounting points are the same, so that will not vary.
Also, don't think you're settling on this core, it's a well crafted in-house design that has gone through plenty of R&D for it's design.
So to trim, are we talking a quick run of the dremmel? Such as the Forge FMIC? And by grille are you just talking the lower black portion? No actual bumper cover trimming?
Old Mar 10, 2014 | 06:42 AM
  #333
ra2fanatic's Avatar
ra2fanatic
I figure the trimming was going to be the case since Sneed routed it through the JCW brake duct area. Which U pipe are you referring to?
The weird thing is, when I installed the Forge FMIC, I never trimmmed anything even when they provided the extra grill that had the inside all shaved. I'm expecting this to be the same, but I guess we'll see !!!
Old Mar 10, 2014 | 07:11 AM
  #334
TazMinianDevil
When looking at the plate that bolts to the block, there is a u-shaped loop that's for the coolant section above where you install the oil lines. I just tightened down the fittings, but it was still leaking past where the pipe inserts into the fittings. It actually required removing the u-pipe and bending the pipe a bit to make everything line up right.
Old Mar 10, 2014 | 07:17 AM
  #335
Grizld700's Avatar
Grizld700
...The weird thing is, when I installed the Forge FMIC, I never trimmmed anything even when they provided the extra grill that had the inside all shaved. I'm expecting this to be the same, but I guess we'll see !!!
Yes! It looks like we will soon find out! Be sure to let me/us know!
Old Mar 10, 2014 | 07:46 AM
  #336
ra2fanatic's Avatar
ra2fanatic
Leakdown tests will determine if anything else needs tightening.
Old Mar 10, 2014 | 08:21 AM
  #337
TazMinianDevil
One advantage of having access to a commercial shop and professional mechanics Also saves your hands from becoming bloody hamburger like mine. How the hell all that plastic can be so sharp?!
My brother and I are a little more old school in our DIY approach. First included instructions, followed by internet search, then Haynes/Bently manuals. If that all fails, then the hammers come out
Our only concession to high tech at this point is the MaxJax lift and a dedicated garage iPad.
Old Mar 10, 2014 | 08:30 AM
  #338
RJT's Avatar
RJT
Looks like the build is coming along nicely ra2fanatic..say hello to Ivan from Strasse Sport, a talented technician and a all around good guy, I highly recommend his work...looking forward to a ride when completed!
Old Mar 10, 2014 | 09:16 AM
  #339
ra2fanatic's Avatar
ra2fanatic
I work with nitrile gloves and switch between those and my mechanix gloves which allow me to reach deeper in the engine w/o getting burned or cut up too badly.
Didn't even have to put it into service mode.
I told Ivan about your 242 and he was like "holy ***** that's good!"
Old Mar 10, 2014 | 10:39 AM
  #340
RJT's Avatar
RJT
Feels even stronger now with the revised Stage 3 Tune from Battle/DNA! Yours is going to be a beast, looking forward to your Stage 4 custom and what Battle and DNA can do to pull out all the extra HP and TQ your mini will be making after this round of mods..
Old Mar 10, 2014 | 11:40 AM
  #341
BattleTuning
Just an FYI, Stage 4 will take a minimum of 4wks to code....
Old Mar 10, 2014 | 01:11 PM
  #342
dez's Avatar
dez
Old Mar 10, 2014 | 03:23 PM
  #343
redparchel's Avatar
redparchel
^^^ THIS!
also
Old Mar 10, 2014 | 03:54 PM
  #344
ra2fanatic's Avatar
ra2fanatic
Spoke to Sneed, oil cooler will be here Thursday. I guess that's when everything should be done and I can be back on the road in the MINI. Miss hearing the exhaust fire up....
Old Mar 11, 2014 | 12:33 AM
  #345
Chattmanlan's Avatar
Chattmanlan
great work&worthy expense! i have a 12 r56 MCS and want to upgrade the front brake. i have been checked some websites but only found ST40 BBK which part No is 83.159.4300.XX.
but i want it to be upgraded to trophy BBK.
what should i do?
am i supposed to just instead the ST40 caplipers of the STR ones?
Old Mar 11, 2014 | 01:06 AM
  #346
Agbullet25's Avatar
Agbullet25
Looking forward to your documentation and review of the Wagner Intercooler.
Old Mar 11, 2014 | 02:09 AM
  #347
Systemlord's Avatar
Systemlord
It must be a monumental task not counting tweaking it once your happy with the end result!
Old Mar 11, 2014 | 08:59 AM
  #348
brightside's Avatar
brightside
Really interested to see where you put your oil cooler. I have a JCW kit so line routing was difficult but accomplished without cutting. I put some of the heat sleeving on the line to avoid chaffing of lines as there is contact with the body. Everything is tight though so there isn't much moving around.
I do believe my oil cooler drains when the engine is off and when i first start the car it makes an odd noise as if its trying to fill and pressurize the cooler every time i start the car. My cooler is mounted behind the grill so it is above the oil level of the engine.
Old Mar 11, 2014 | 09:16 AM
  #349
Bster13's Avatar
Bster13
What mods would stage 4 entail?
Old Mar 11, 2014 | 10:03 AM
  #350
ra2fanatic's Avatar
ra2fanatic
This just arrived....
