R50/53 Christmas on my dashboard
Old Jun 19, 2006 | 06:14 PM
Hammer's Avatar
Hammer
So I'm driving home, going with the flow at a modest 50 mph, when all of a sudden it's Christmas on my dashboard - the flat tire monitor, DSC and ABS lights all come on. Anyone ever have this happen? What's the dealy-o?
Old Jun 19, 2006 | 06:23 PM
Motor On's Avatar
Motor On
Well I've had the 2 Airbag lights, Tire press sensor the ASC light, the SES light cruise control and highbeam lights on all at once (and the brake light came on when I parked in the garage.
I had a flat, O2 sensor issue, faulty airbag weight srnsor, shut off my ASC (habbit). I'd check the pressures and make sure you have tight connections under the bonnet, then give the dealer a call and get an appointment and let'em know whats up. As long as nothing is flashing you should have rougly 50 miles to get there. Do you have any driving symptoms or just lights?
Old Jun 19, 2006 | 06:26 PM
thefuturequeenofnebraska's Avatar
Try checking your tire sensors... When I broke mine I had a similar problem....
Good luck!
Old Jun 19, 2006 | 06:53 PM
Red's Avatar
Red
It was the left front sensor that gave me Christmas in May. It was the last straw, trading my 03 MCS for an 06 MCS.
My 66 MCS had far less electrical troubles. Something to be said for simplicity and Lucas electrics.
Good luck!
regards,
Red
Old Jun 19, 2006 | 07:29 PM
Hammer's Avatar
Hammer
No driving issues, no other symptoms at all. I checked the air pressures, they are all fine. Guess I'll be visiting the dealer.
Old Jun 19, 2006 | 08:56 PM
BoCRon's Avatar
BoCRon
Don't know if mine was the same issue, check the following threads.
https://www.northamericanmotoring.co...ad.php?t=56726
https://www.northamericanmotoring.co...ad.php?t=63348
Annette
Old Jun 20, 2006 | 05:48 AM
Hammer's Avatar
Hammer
I called my MA this morning (he's awesome) and told him the story, "sounds like you've got a bad wheel speed sensor" was the first thing out of his mouth. Bad news is, I can't get in until next Tuesday. I told him I am AX this weekend, would it be a problem (he sometimes comes out and AX with us, and it has NEVER been an issue with getting warranty work done - I told you he was awesome), he says no problem, but the ABS and DSC may not work correctly. I always turn DSC off anyway, no ABS will be a learning experience!
Old Jun 20, 2006 | 07:49 AM
BoCRon's Avatar
BoCRon
As posted in my second thread, I did my entire 2nd day at Driving School with no ABS. I actually preferred it and wish there was a way to switch it off at will like the DSC!
Annette
Old Jun 20, 2006 | 09:54 PM
addamaniac's Avatar
addamaniac
nice thread title. You had my imagination thinking somethin else...
like a nativity scene or somethin...
Old Jun 27, 2006 | 06:32 AM
Hammer's Avatar
Hammer
OK, just got back from the dealer (they always have great coffee there) anyway, the right front wheel sensor was cut clean in half. There was evidence of some rubbing on the sensor wire, but the wire itself - which is a pretty heavy gauge - was cut clean in two. They showed me where the cut was in relation to where it was mounted and we cannot figure out how it happened. The nearest moving part is the serpentine belt, but it's a good 3-4 inches away and if there was that much play in the belt I would be having all sorts of problems.
Anyone else with a similar situation? Is it foul play? Is my cover as a deep, deep, deep undercover agent blown and they are on to me?
Old Jun 27, 2006 | 08:42 PM
Red's Avatar
Red
OK. I said it was the left wheel sensor in a previous post. It was on mine. They said it was faulty, but it happened a week after they did a state inspection and rotated the tires. I am convinced the dealer inadvertenly messed with something. Did you notice the flat tire light come on a bit before the full blown "Christmas Effect"?
Good luck!
regards,
Red
Filmy
15
Jun 6, 2023 06:27 AM
Moshu-Clubman
R55 :: Clubman Talk (2008+)
Jul 13, 2016 08:54 AM
simron
Sep 23, 2015 10:02 PM
misterbl
Sep 16, 2015 11:22 AM
stellaherself
Sep 16, 2015 06:56 AM
