R50/53 Anyone admit to installing eBay fixed camber plates?
Old Apr 5, 2026 | 04:41 PM
Here2Go's Avatar
Here2Go
NAM Community Team
I know it may seem like a daring question to admit to but...
I'm preparing to revamp my Coilovers with new springs and upper bushings, etc. For the front suspension (going through all the trouble) Although I dont track - I would prefer to upgrade to fixed camber plates as opposed to the stock rubber variant.
I've read that most contributers here have gone with IE camber plates. However, with all the additional parts: springs, outer balljoints, roll center adjusters etc, my budget can't really sustain the cost.
I see quite a few generic camber plates offered on eBay.
Given the price range below $300, I might assume Chineseum.
Has anyone have/had bought, installed and had any experience with a set of eBay camber plates?
Thanks.
Old Apr 5, 2026 | 06:14 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Well fortunately I came across a far better option for the quality and price as opposed to the eBay offerings on WayMotorWorks site.
However I'm a little confused since he states that:"These are not intended for lowering springs, use of lowering springs will result in your camber being more than -1.25 deg."
I would assume that the statement above would/might also apply to/my (Bilstein) adjustable coil overs as well?
I am lowered but I'm not too crazy about having that much camber either.
'wondering if the roll center adjusters might reduce that much camber?
Any thoughts or feedback appreciated.
Old Apr 5, 2026 | 07:32 PM
noodlesandsam's Avatar
noodlesandsam
Way knows a lot. You can call to discuss. That is how I would start.
Old Apr 5, 2026 | 09:10 PM
ghostwrench's Avatar
ghostwrench
Roll center adjusters won't affect camber. They just put the lower control arm at a better angle (more flat) than the upward angle they may be at when the car is lowered.
Old Apr 5, 2026 | 09:16 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Hey @ghostwrench , Thanks for the clarification.
I was hoping you'd chime in. We have similar setups with the Bilstein B14 and moving a bit close to yours.
Old Apr 6, 2026 | 04:08 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Those plates listed on WMW look just like the IE fixed plates
https://www.iemotorsport.com/product...i-r50-r52-r53/
My guess is that those are the same parts.
I don’t know why they wouldn’t work with lowering springs. MacPhearsen strut suspensions gain very little camber from suspension compression. As long as you get the toe alignment adjusted into spec, you’ll have no issues running those.
Also, running as much as -2° front camber is not a problem for street driven Mini. When I had Megan coil overs on my Clubman, I ran -2° at all four corners for about 6 years before replacing with the Bilsteins.
Old Apr 6, 2026 | 07:16 AM
GLEX's Avatar
GLEX
I know you asked about fixed camber plates, but I considered the reasonably-priced Project Silver adjustable camber plates until reading reviews that were mediocre at best. Eventually I went with genuine MINI strut mounts, but will pay the premium for Vorshlag camber plates next go-around. Anyway, food for thought, as it might be worth just keeping it stock until you can get high quality camber plates.
Old Apr 6, 2026 | 07:18 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Personally, I wouldn't hesitate to get the IE fixed plates over pillow-ball style adjustable plates. You'll thank the car gods for having rubber in those mounts...
Old Apr 6, 2026 | 12:37 PM
Here2Go's Avatar
Here2Go
NAM Community Team
@njaremka - Thanks for that. You've consistently tried to answer my suspension questions and provided me with much "food for thought" - greatly appreciated!
I've since wondered if these camber plates: fixed or adjustable; add to additional road harshness?
And are they more durable long lasting as opposed to (say), Genuine Mini upper strut mount bushings/bearings??
Simply - do they outlast the standard rubber / bearing style?
Thanks.
Old Apr 6, 2026 | 12:47 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Thanks.
I do what I can to pass on any knowledge I might have.
From my understanding, the IE camber plates used OEM Z4 rubber isolation bearing mounts with custom top bolt plates. They will likely last just as long as any other OEM rubber bushing part. If you can confirm with them where the rubber piece comes from, you would at least have a maintenance path.
Old Apr 6, 2026 | 01:00 PM
Here2Go's Avatar
Here2Go
NAM Community Team
^^^Perfect answer^^^ for me.
Whilst comparing images of both the IE fixed and typical style upper strut bearings - I see in both, rubber and bearings. Which made me think that the main visual difference was that the IE fixed had a "pre-set" - degree combined with (e.g: ) Cravenspeed under plates...(?).
Which I find Interesting to me.
Thanks.
ATXZJ
Suspension
Jul 19, 2011 08:35 PM
KrautHammer
Suspension
18
Jun 26, 2009 05:34 AM
MadUsa1
Suspension
Feb 6, 2008 05:54 PM
Chilipeppa03
Suspension
Dec 6, 2007 07:59 PM
john576
Suspension
Jun 12, 2006 11:23 PM
