R50/53 Clutch release bearing ?
Old Mar 22, 2026 | 02:55 PM
Tombstone's Avatar
Tombstone
Which clutch release bearing is best: Sachs or Exedy for single mass conversion on R53 Jcw ? Got a deal on Valeo setup clutch,pressure plate , & flywheel ; need release bearing & flywheel bolts .
Old Mar 22, 2026 | 04:01 PM
noodlesandsam's Avatar
noodlesandsam
Sachs, NSK, *** for bearings - never heard of Exedy
Old Mar 22, 2026 | 04:06 PM
Tombstone's Avatar
Tombstone
Sachs it is ; now all I need is the 8- flywheel bolts any suggestions? Thanks
Old Mar 22, 2026 | 04:14 PM
noodlesandsam
OE Mini - that breaks free, and you have a real mess.
Old Mar 23, 2026 | 08:48 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
i went with the Exedy SMF kit back before the insane price hike
was swayed in favor of it over the Valeo by @pnwr53s & his report/reviews
flywheel slightly lighter than Valeo
good pic of the Exedy throwout bearing in this post;
https://www.northamericanmotoring.co...ml#post4351932
i think most of them are of the same type,
that chintzy plastic
this is the absolute best solution for our crappy throwouts that i've seen,
from RMW
https://store-revolutionmini-com.3dc...ing_p_271.html
Old Mar 23, 2026 | 09:53 AM
Tombstone's Avatar
Tombstone
So how do you like the Exedy release bearing now that it’s installed in your Mini ?
Old Mar 24, 2026 | 08:31 PM
Tombstone's Avatar
Tombstone
Still no luck in finding a supplier for single mass flywheel bolts , checked with Valeo, Exedy & Sachs with no luck ?
Old Mar 25, 2026 | 04:40 AM
Kibbis's Avatar
Kibbis
Detroit Tuning lists arp bolts that should work with a single mass flywheel. They are a bit pricey, but I ordered some as I'm also doing the Valeo kit.
Edit: Link - https://detroittuned.com/arp-flywhee...g7MIr5FF17hZIA
Summit racing had them a little bit cheaper.
2nd edit: If you reach out to Valeo support, they should be able to tell you the bolt size. I think it's an m10-1pitch but I never got confirmation if it's 20-24 in length. If you do find some in that size range, just make sure you get the right hardness. 10.9 or higher.
Old Mar 25, 2026 | 12:49 PM
Oldboy Speedwell
no complaints
does what it's supposed to do
just worried about lifespan longevity & wish that we had an upgraded aftermarket option
something similar to this one by OS Giken:
the Exedy one is pretty much a facsimile of the OE unit
but hey, my OE unit lasted up until 160,000 miles!
so partially my fault for not addressing it sooner
when it gave up the ghost, pretty much had just disintegrated:
luckily it didn't explode,
there's a couple of reports here on NAM of such . . .
. . . & one instance where shrapnel at velocity smashed through the bell-housing !!!
https://www.northamericanmotoring.co...-gone-ied.html
Old Mar 25, 2026 | 03:00 PM
LukasH's Avatar
LukasH
Jep mine has exploded in 2021 and punched a hole in the bell housing. Luckily I found a guy being able to weld it for just $50.
Old Mar 26, 2026 | 09:19 AM
Tombstone's Avatar
Tombstone
Originally Posted by Oldboy Speedwell
no complaints
Curious if you had to replace the release bearing guide tube ? Thanks
Old Mar 26, 2026 | 09:32 AM
Oldboy Speedwell
i did, yes.
had already bought the new part so installed it even tho the old one still looked okay.
Old Mar 26, 2026 | 10:16 AM
Tombstone's Avatar
Tombstone
i did, yes.
Cheap insurance, thanks…
Old Mar 26, 2026 | 11:53 AM
noodlesandsam
Realoem has the flywheel bolt as M10 x 48 - sounds like 48mm to me
Old Mar 26, 2026 | 12:31 PM
Tombstone's Avatar
Tombstone
I looked this up on RealOem , your right about 48 mm but, appears to be for twin mass flywheels.
Old Mar 26, 2026 | 04:06 PM
Oldboy Speedwell
Turner lists the Valeo bolt specs
looks almost the same as this Febi bolt:
which is essentially a VW part # N90206103
blue threadlock instead of red though
unsure of thread pitch though so that may throw a curveball
hope this might help
Old Mar 26, 2026 | 04:45 PM
Tombstone's Avatar
Tombstone
. Appreciate your assistance on these bolts , let me do some further research to verify . Thanks again…
Old May 12, 2026 | 07:24 PM
Tombstone's Avatar
Tombstone
Flywheel Bolts R50 R52 Cooper NON SFlywheel Bolts R50 R52 Cooper NON S
R50FlywheelBolts
Brand: MINI - OEM
WayMotor Works informed me that these factory bolts will work on R53 MCS, for the single mass flywheel…
SeansARobot
R55 :: Clubman Talk (2008+)
Sep 22, 2024 12:28 PM
gbfan10
Sep 5, 2019 12:34 PM
DJDUPONT
Sep 11, 2011 10:05 PM
firenewt
Apr 11, 2011 10:22 AM
S Curvz
Mar 1, 2006 10:46 AM
