Drivetrain Which clutch release bearing?
Old Apr 11, 2011 | 08:58 AM
firenewt's Avatar
firenewt
I am pulling the trans to fix an install problem with my ACT clutch kit. I have a choice of the revised Mini clutch bearing or the ACT bearing. Any idea which I should use?
Kevin
Old Apr 11, 2011 | 09:04 AM
Vollgas's Avatar
Vollgas
Since you are putting in ACT clutch & pressure plate I would suggest using the ACT throw out bearing.
I believe the ACT bearing is a metal one.
The OEM is plastic.
What flywheel are you using?
Old Apr 11, 2011 | 09:20 AM
firenewt's Avatar
firenewt
I am using the ACT Streetlite flywheel - steel version.
Kevin
Old Apr 11, 2011 | 09:23 AM
Vollgas's Avatar
Vollgas
Good choice.
Go with the entire ACT system.
Old Apr 11, 2011 | 10:22 AM
firenewt's Avatar
firenewt
Originally Posted by Vollgas
Good choice.
Thanks Vollgas, that's what I'll do.
Kevin
QuickCooper
Dec 29, 2016 06:46 PM
Khai
Feb 10, 2016 07:43 PM
Sep 16, 2015 06:22 AM
Sep 16, 2015 06:18 AM
Sep 3, 2015 02:06 PM
