R50/53 R56 front brakes on a r53 and wheels?
Old Aug 27, 2021 | 02:34 PM
alconk's Avatar
alconk
This past winter I bought new 15” wheels with Blizzak tires then in the spring when I took them off to put the 17” back on I also upgraded to the R56 front brakes. Will the 15” wheels fit over them?
Old Aug 27, 2021 | 10:11 PM
RB-MINI's Avatar
RB-MINI
They might fit over R56 brakes (280mm rotors plus bigger pads vs 276mm R53 rotors), but probably not over R56 S brakes (same R56 caliper and pads but with 294mm rotors). It could also depend on the specific wheels you are trying to fit or the placement of the wheel weights as the shape/profile of the barrels vary in design.
Which brakes did you put on, R56 S or Regular?
Old Aug 27, 2021 | 10:44 PM
Noonzio's Avatar
Noonzio
They will not fit over R56 S brakes
Old Aug 28, 2021 | 08:58 AM
alconk's Avatar
alconk
I told them “S” but they looked the same size as the 53 rotors?
Old Aug 28, 2021 | 01:08 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
16” rims are tight over the R56 S brakes, I can’t imagine trying to clear with 15” wheels….
Old Aug 28, 2021 | 05:09 PM
Da_Ghost's Avatar
Da_Ghost
X-lites are one of the rare oem 16" that fits over the R56 brakes, pretty sure 15 won't clear.
Old Aug 29, 2021 | 07:54 AM
alconk's Avatar
alconk
Guess I’ll switch the brakes back before winter then.
Old Sep 1, 2021 | 11:06 PM
thmpr464's Avatar
thmpr464
My 16" OEM barely fits - 2 -3 mm gap.
Old Sep 2, 2021 | 03:54 AM
nd-photo.nl's Avatar
nd-photo.nl
The 16" R87 winter wheel also barely fits over R53 JCW brakes
Old Sep 2, 2021 | 05:10 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
my 15in rpf1's I had and my ebay rims I have now both fit onto my buddies r56 S . My buddies running xlites 15s and they clear his r56 S rotors buuuuuut I think he did grind his front calipers down ever so slightly but I will 2x check with him.
ille grab pics soon as he's home later or if his cars out.
Old Sep 2, 2021 | 05:17 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I've seen SOME 15" rims fit over R56 brakes, but it takes some work. You either have to grind the caliper, or run massive spacers.
X-lites are 16". I have a set used previously for winter duty, and they are close to the calipers - maybe 5mm clearance.
Old Sep 2, 2021 | 05:19 AM
MiniManAdam
Community Builder
o I'm sorry your rite . Buuuuut he runs a winter tires 15 that's an oem mini rim too and it fits also buuuuut like you said on those, his calipers clearanced them selves by grinding out abit of the rim.
Old Sep 2, 2021 | 07:20 AM
Jason Cornelius's Avatar
Jason Cornelius
I have seen a set of 15x8’s on a 11 R56s, he ran 5mm spacer on all 4 corners.
He was melting his wheel weights off, so he aluminum taped them to help. Just something to watch for.
Old Sep 2, 2021 | 08:07 AM
Jason Cornelius
Old Sep 2, 2021 | 11:37 AM
Minibeagle's Avatar
Minibeagle
Choices are limited on 15 inch aftermarket wheels that will clear the R56 S front brake calipers. I did quite a bit of research before finding stuff that would work for me.
I have two different sets of 15x8 for my 2006 JCW which runs R56 S front brake calipers. No rubbing anywhere on either set under heavy suspension loads.
15x8 949 Racing 6UL with 225/45R15 tires - needs 5mm spacer in the rear to clear lower strut bolt on the trailing arm. I run a 5mm spacers in front too although they're not needed.
I also have a set of Konig Dekagrams. I run 15x9 in the front with 245/40R15 tires with 13 mm spacer to clear the Koni strut. I run 15x8 with 225/45R15 and 5mm in the back to clear lower strut bolt on the trailing arm
Emile van der molen
Jun 7, 2019 07:56 PM
schreiber117
Suspension
Oct 21, 2013 02:24 PM
WorksMiniS
Tires, Wheels, & Brakes
32
Sep 22, 2010 07:32 AM
sac02
Suspension
Jul 26, 2010 07:00 AM
minintrigue
Sep 11, 2008 10:58 AM
