R50/53 What is this light bulb called?
Old Mar 11, 2014 | 09:51 AM
carlucci1106's Avatar
carlucci1106
Hi,
New to the forum, but have browsed a bit in the past. A dealer I was getting work done with frequents here and recommended.
Anyhow, I bought a used 2002 Mini, actually a Canadian model that was part of the first run of 500 in North America, I believe.
Between the headlights and fogs are the set of lights that include the directionals. There is another bulb in there that is just white light pointing square at you, whereas the directional itself is askew and orange.
What is this white bulb referred to as? And where do I go to get a replacement?
Old Mar 11, 2014 | 10:29 AM
rkw's Avatar
rkw
It is typically called a "running light". It turns on at the first click of the light switch, and stays on with the headlights.
It is a small wedge bulb commonly known in North America as 194. It is also known as T10. It is a common bulb available in car parts stores and even in some hardware stores.
http://www.oreillyauto.com/site/c/de...1577&ppt=C0010
Old Mar 11, 2014 | 10:35 AM
a2oc's Avatar
a2oc
I believe they are called side lights or parking lights. On the R56, they use w5w bulbs, not sure if they are the same on the gen 1. you can get those from auto parts store or even Walmart.
Old Mar 11, 2014 | 10:42 AM
jamez's Avatar
jamez
It's an excellent questions - and one that I've been trying to figure out myself (I couldn't find a proper listing in the manual)
Anyone have a lead on one that matches the Xenon colour?
Old Mar 11, 2014 | 10:43 AM
+1 T10 base or 194 wedge bulb 5 watt .
http://www.ecstuning.com/Search/SiteSearch/63217160797/
If you want to change it out to Ziza LEDs we have them here, no bulb out code or anything. They match the stock xenon headlight colors.
Click here for Ziza Leds front marker lights.
"Canadian model that was part of the first run of 500 in North America, I believe"
That's really cool. Talked about' it here.
https://www.northamericanmotoring.co...-too-loud.html
Old Mar 11, 2014 | 10:44 AM
a2oc's Avatar
a2oc
I am using PIAA xtreme white and they are quite blueish white, but they cost like $10 a pair in amazon
Old Mar 11, 2014 | 10:48 AM
jamez's Avatar
jamez
ECS again for the win! Thank you very much - they bug the hell out of me.
Old Mar 11, 2014 | 11:00 AM
Welcome.
Alkaidovich
Jan 30, 2021 01:35 AM
I_drive_slow
Aug 18, 2015 10:47 AM
AZN Optics
Aug 16, 2015 11:52 PM
