R50/53 new motor mount
Old Nov 19, 2013 | 07:39 AM
bcgreen's Avatar
bcgreen
new motor mount
I just installed a new after market motor mount on the passenger side and went to start the engine this morning and found the engine noisy. The drivers side is still the original Mini motor mount. I didn't change the driver's side because it wasn't leaking.
What do you think is the reason the engine is now noisy. I didn't drive it, I just started it and immediately shut it down so I could double check the engine compartment, just in case I left anything in the engine compartment. Everything looked fine.
Any ideas?
Old Nov 19, 2013 | 07:44 AM
irkath's Avatar
irkath
is it a polyurethane mount?
solid mounts mean more vibration from what I read.
Old Nov 19, 2013 | 07:48 AM
bcgreen's Avatar
bcgreen
I am not sure. I got it from Way Motor Works.
http://billswebspace.com/MCSPulleyMountTensioner.htm
Old Nov 19, 2013 | 09:57 AM
GregO's Avatar
GregO
motor mount
Yah, that's one brand of a more dense aftermarket mount that will cause more noise&vibration. Just make sure all bolts are torqued and you will be good to go. If you can't tolerate it, you'll need to consider switching back to an oem or oem-equivalent mount.
Greg
Old Nov 19, 2013 | 09:58 AM
bcgreen's Avatar
bcgreen
Thanks, good to know.
Old Nov 19, 2013 | 10:29 AM
BillJackson's Avatar
BillJackson
A motor mount is two metal brackets. One bolts to the engine and the other to the frame of the vehicle. They have bushings in-between the brackets to prevent metal-on-metal wear. If the bushing is bad, it can squeak or if it's worn out completely, you can have metal-on-metal noise.
Old Nov 19, 2013 | 11:50 AM
ED955S's Avatar
ED955S
use for 3-4 weeks and it will settle down a bit.
I love mine.
Old Nov 19, 2013 | 11:58 AM
bcgreen's Avatar
bcgreen
I love mine.
I hope that happens for me as well.
Old Nov 19, 2013 | 12:16 PM
rckrzy1's Avatar
rckrzy1
I kept breaking my trans mount in my 6 speed Trans am, bought a poly trans mount, lasted 1 week till the vibes drove me nuts, removed and found stronger rubber mount. Poly is just too rigid for motor or trans mounts, suspension parts yes, but driveline, not in my cars.
Old Nov 19, 2013 | 01:17 PM
bcgreen's Avatar
bcgreen
So if I decide I can't live with it, what substitute is there, for a better ride, less vibration, and less noise, that is more like OEM, but will last longer?
Old Nov 19, 2013 | 01:37 PM
kemopots's Avatar
kemopots
bcgreen, which year MCS do you have. The mount that you installed is a TSW motor mount and they produced 2 different styles based on the model year of your mini. Also, did you adjust the length of the dogbone on the mount and reinstall the lower mount bolt?
Old Nov 19, 2013 | 01:58 PM
bcgreen's Avatar
bcgreen
2004. I requested one for my car, and I didn't know there was another option from the vendor. The invoice says WMW motor mount - late '04 to '06.
I didn't adjust the length. I see you can adjust it, but which way do I adjust it and what can I expect from the adj.?
I installed the new lower mount bolt - Torx
Old Nov 19, 2013 | 02:39 PM
PrplPplEtr's Avatar
PrplPplEtr
try the VibraTechnics mount.
DixonL2
Apr 13, 2021 08:05 AM
yukinoinu
Sep 1, 2015 09:28 AM
yukinoinu
Aug 29, 2015 01:17 PM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
