R50/53 Gap in lower motor mount?
Old Aug 29, 2015 | 06:59 PM
yukinoinu's Avatar
yukinoinu
So I have an issue in my car where if I floor it and don't ease into it (torque application) there is a jerk and with that jerk (that's completely normal) there is a kind of bang/pop it isn't like a bang sound though it is more of something solid just smacked another solid thing, so Looking under the car right now I see that my lower motor mount, the connection to the body has about a 1/8" gap between the rubber and the mount, should that be there or not? I think no but please help with suggestions.
Old Aug 30, 2015 | 12:15 PM
Spencer Roper's Avatar
Spencer Roper
If you could get a picture it might help!
Old Aug 30, 2015 | 01:06 PM
yukinoinu's Avatar
yukinoinu
Can't take a pic at the moment, but so on the connection (smaller side bolted to the frame) there is a gap on both sides, the mount is sideways inside the C joint. there is about a 1/8" gap on both sides. I cannot tighten it at all, but then again I cannot loosen it either xD tried some PB blaster and still couldn't (guess I am weak lol).
Old Aug 30, 2015 | 01:28 PM
Da_Ghost's Avatar
Da_Ghost
Does it looks like this or there's rubber missing somewhere on yours?
Old Aug 30, 2015 | 02:33 PM
Spencer Roper
Those bolts are in there real good as I remember...and since it sounds like the factory installed motor mount....time doesn't help them become any easier to break loose.
From your description I'd say it's the motor mount. The torque transfer clunk is something I've heard with failed motor mounts.
However I can't tell you for sure without a picture. The gap as you describe sounds as if the rubber mount has broken and now there is a gap where the rubber bushing is pressed in and the bushing itself?
Old Sep 1, 2015 | 09:24 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
From the sounds of it, it may be the mount as suggested. One of the most common parts to deteriorate on the MINI are the engine mounts. The rubber that is contained within the mounts becomes old and brittle, and doesn't perform a good job of isolating the drivetrain from the rest of the chassis. We have a DIY for the replacement here, which provides some good images so maybe take a look and see what yours looks like in comparison. Mounts here if needed.
888.280.7799 | 6am - 5pm PST
Old Sep 1, 2015 | 09:28 AM
+ check for gap or separation of the rubber in the middle or cracking in the middle of the rubber part.
https://www.northamericanmotoring.co...any-ideas.html
http://www.ecstuning.com/Search/SiteSearch/22116756406/
And here:
https://www.northamericanmotoring.co...lying-gas.html
thanks
DixonL2
Apr 13, 2021 08:05 AM
silence2-38554
Nov 12, 2015 09:39 AM
tr3y003
Oct 22, 2015 10:48 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
