R50/53 on the side of the road again...
Old Nov 18, 2013 | 04:11 PM
lgncarter07's Avatar
lgncarter07
Number three!
In the middle of bumper to bumper traffic, and my clutch pedal just good to the floor and stays there.
Pushed it of to the side of the road and look under the car and My clutch actuator that bolts to the side of the Trans is Blown.
Are they expensive/hard to reprime?
Old Nov 18, 2013 | 04:32 PM
minibx's Avatar
minibx
Sorry to hear that,what car do you have? I'm guessing an R53 right? The clutch slave is about 30.00 to 60.00 depending on where you get it. Bleeding its a bit hard if not done right .
Old Nov 18, 2013 | 06:17 PM
ACallahan's Avatar
ACallahan
Yep what he said. They can be tricky to bleed.
If you go to the Mot oring alliance site DIY section for R53 there is a nice DIY write up
Old Nov 18, 2013 | 06:50 PM
lgncarter07
yea, ive had the car a month and already replaced the fuel tank (my fault) and swapped a burnt out clutch. thank god the slave is atleast easy to get to.
are the any easy way to bleed the slave without buying a power bleeder?
lgncarter07
and its a 2002 mini cooper s,not sure what code that is.
Old Nov 18, 2013 | 07:09 PM
minibx's Avatar
minibx
That's an R53, get the 30.00 slave from ECS or another MINI shop, the brand is FTE is the same as the MINI branded, make your own tool to compress the slave, when you change it be careful not to loose the connector that goes from the feeding pipe in to the salve cylinder, when you take it off it could stay inside the cylinder and you have to carefully fish it out do not discharge the old one until you are sure of this.
I did it with a bleeder there are different methods around the web but trust me the bleeder is worth every penny and it will save you a headache specially with the MINI.
Old Nov 19, 2013 | 04:51 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Sorry to hear this! Good news is that it is not difficult to replace and bleeding is straightforward and yes, as mentioned above, a power bleeder is very helpful.
For a DIY on this procedure, click Clutch Master & Slave Cylinder Replacement. We offer the OE supplier FTE brand you will find further info for here.
If you are familiar with Motive Power Bleeders, they are excellent in these situations: Motive Products on Pelican
Keep us posted as to your fix and get back the road again if you haven't already!
Mark/Pelican Parts
888.280.7799 | 6am - 5pm PST
cm.d
Aug 19, 2015 08:51 AM
Emnotek
Aug 13, 2015 05:47 PM
Aug 12, 2015 01:24 PM
