R50/53 Outrageous
Old Jul 16, 2013 | 06:04 AM
tmors424's Avatar
tmors424
Outrageous
Does anybody find it outrageous that a motor mount can cost $330? I personally think this is the ultimate scam. How can anyone justify paying that for a motor mount? I am completely baffled by this...
Old Jul 16, 2013 | 06:22 AM
Braminator's Avatar
Braminator
Let me take a guess at this and say you went to the stealership? You can find them online all day long for a lot less. What year and model do you have?
Old Jul 16, 2013 | 06:37 AM
I can help you find the part and give you some options I was going to ask the same thing about the year and model , but bram beat me to it.
Old Jul 16, 2013 | 06:46 AM
GreekDrifter91's Avatar
GreekDrifter91
05 MCS, its in his sig
Old Jul 16, 2013 | 06:56 AM
Braminator's Avatar
Braminator
I never like to assume.
Old Jul 16, 2013 | 06:57 AM
Thanks Greek, I guess I was memorized by the sig stubby antenna ball and did not see it.
#3 The one above is for the 12/2003+ Part number 22116778610
http://www.ecstuning.com/Search/22116778610/
#7 is the lower engine mount, You might want to check that also if its separated from the rubber on the larger section.
Lower Engine Rubber Mount Part number 22116756406
http://www.ecstuning.com/Search/SiteSearch/22116756406/ES41645/
On the transmission side there is #1 mount which there is a part number for the automatic and manual transmission version for the Cooper S.
Transmission Support Bracket / Mount Manual transmission Part number 22316754422
http://www.ecstuning.com/Search/SiteSearch/22316754422/
Transmission Support Bracket / Mount - Auto transmission.
http://www.ecstuning.com/Search/SiteSearch/22326768207/
Thanks and hope that helps now.
Old Jul 16, 2013 | 07:27 AM
JoeGravelle's Avatar
JoeGravelle
$330 for an engine mount... yes a bit outrageous.
Try paying $120 for a tiny engine shock for a Mercedes Diesel engine... two per engine. That's ridiculous.
Thankfully the MINI mount has aftermarket versions
Old Jul 16, 2013 | 08:59 AM
thulchatt's Avatar
thulchatt
Yup, that is way too high.
Check with the vendors on this site, you have one on this thread you can trust, for better parts at lower prices.
Also, get to know RockAuto.com.
Old Jul 16, 2013 | 11:01 AM
Helix13mini's Avatar
Helix13mini
^This. Like, say, us!
Old Jul 16, 2013 | 05:11 PM
Da_Ghost's Avatar
Da_Ghost
If it's the upper one, it's filled with hydraulic fluid, so it's not like most motor mounts, where it's just ''rubber''. Apart from stock, there's a couple aftermarkets ones if you don't mind the extra bit of vibrations.
Old Jul 17, 2013 | 06:31 AM
Also the upper mount 22116778610 will tend to leak the black fluid and can be seen on the inside rail, and sometimes on the back side , if not seen from the front, that is the visual way to see its bad.
Old Jul 17, 2013 | 07:33 AM
ZippyNH's Avatar
ZippyNH
Just had a new OEM one installed last week....I was feeling lazy...
was UNDER $200 installed....took about 20 minutes...no appointment needed at my favorite independent shop that does MINI work....
You can buy non-OEM ones for less and DIY it....but a 2 year warranty on a MINI branded part that seems to last about 30,000 miles MIGHT mean I get a second one for free.....
Old Jul 21, 2013 | 08:52 AM
tmors424's Avatar
tmors424
Sorry for the delayed response folks, been having computer issues. The mount I was referring to is the Vibre-Techincs. I am on my 3rd OEM mount from Mini and is leaking again. I didn't want to go with a solid mount because of the NHV. I saw this one and thought it might be a good alternative until I saw the price. Has anyone told that company you can buy a big screen TV for that price? http://new.minimania.com/part/NME470...-MINI-COOPER-S I wander how many they have actually sold? That's ridiculous...
Old Jul 21, 2013 | 09:22 AM
Braminator's Avatar
Braminator
They always seem to be expensive on any of their parts that's why you need to shop around. Colin green sells them to a lot of members. Contact him.
Old Jul 21, 2013 | 09:32 AM
JoeGravelle
"You've got to pay to play"
Old Jul 21, 2013 | 09:58 AM
Minian's Avatar
Minian
+1
Yes, it's very pricey, but it works. Remember you're looking at a high-end solution to a problematic part for a premium car.
Old Jul 21, 2013 | 11:31 AM
rkw's Avatar
rkw
They have been much discussed on NAM and getting popular: https://www.northamericanmotoring.co...atechnics.html. Considering that you've already gone through 3 OEM mounts, maybe it isn't quite so ridiculous after all.
They are just starting to pick up vendors in the U.S. (previously only available direct from the UK). OutMotoring also carries it now: http://www.outmotoring.com/vibra-tec...ount-road.html
Old Jul 21, 2013 | 05:55 PM
tmors424's Avatar
tmors424
[QUOTE=rkw;3778050]They have been much discussed on NAM and getting popular: https://www.northamericanmotoring.co...atechnics.html. Considering that you've already gone through 3 OEM mounts, maybe it isn't quite so ridiculous after all.
You have a point- Thanks for the info. Wow you can go into information overload with that thread! I still cant believe that price but, I may have to bite the bullet. Just pi$$es me off that its just one more thing I have to spend money on with this car . Gen 1 refreshed R53. Its been a good car so far. I've had it since new. It will be 9 years old next week with 59K miles. I guess its going to need stuff as it gets older (kinda like me, lol). I just had to change out the control arm bushings with urethane ones a couple months ago. I also have the low speed fan issue, oil pan leak, and sender leak problems to deal with. Better than a car payment though
beasleyboy
Sep 24, 2015 09:22 AM
bhardy
Dec 1, 2007 04:55 AM
plkdb
Classic Mini Talk
20
Nov 12, 2007 03:12 PM
002
Oct 30, 2007 05:51 AM
Yucca Patrol
Dec 2, 2002 07:41 PM
