R50/53 255s, Is it possible
is it possible, on a 06 s. To put 16x8 255s on a mini? What type of clearance issues would there be and what kind of work would need to be done to make this work?
does anyone know?
does anyone know?
Thank you for the reply.
I am still learning what the terms are and what thing mean. please excuse my ignorance. What do you mean by " not fit under the arches" ?
I mean its not going to fit on the car at all. I run 255s on a set of 17x9s on our STI. For giggles one day I placed a one of them in the MINIs wheel well and even all the way up against the fender liner it stuck out like crazy.
thank you for letting me kno about the 255s. I appreciate it.
Research what you buy on Tire rack. They have many surveys where professionals rate the tires for dry/wet/snow grip as well as cornering/braking and noise performance.
In fact, make it even easier on yourself and give the folks there a call. They have great knowledgeable representatives there who can help ensure that you are using the proper tire for your region (weather/temperature) and driving style.
Upgrading the tires will help more than simply increasing the width. Remember too, when you start changing your tire width you affect handling and cornering. Also, when you change your suspension set-up (lowering springs) you also change your alignment geometry which again will negatively impact traction until you readjust everything.
This. Alex @ TireRack is NAM's resident tire guru, give him a call or email (alex at tire rack dot com.)
I believe 215's are as wide as you can go and still be able to tuck inside without touching the inner portion of the wheel arches, maybe a 225 with some careful measuring and a custom offset. Anything wider would only be possible with suspention mods so that the spring travel wouldn't allow the tire to tuck, or wide arches and some body mods.
Screw it..I'm filing a claim through PayPal. Let's see what they say.
my body guy charged me 120$ to straiten these out so theyd fit. He spent over 4 hours JUST so they line up correctly onto the car.. total bs was totally not what was purchased and they changed their ad days after I messaged them..
I'm tired thess companies ripping people off
Boosted_Mini
Tires, Wheels, & Brakes
Jun 27, 2011 03:50 PM
