Will these fit.. or what is it going to take to make it fit?
I am looking at this wheel:
Specs are:
16x9.0 F / 16x9.0 R
4x100/114.3
ET15 F / ET15 R
or
16x7.5 F / 16x7.5 R
4x100/114.3
ET30 F / ET30 R
I personally want the x9.. but I am wondering if that offset and size is going to fit the mini without modification..
Specs are:
16x9.0 F / 16x9.0 R
4x100/114.3
ET15 F / ET15 R
or
16x7.5 F / 16x7.5 R
4x100/114.3
ET30 F / ET30 R
that would either take a significant lift, or a sawzall
the combination of 9" width and significantly less offset (+48 is stock) will mean that the outer edge of the wheel and tire will interfere with the fenders
http://www.1010tires.com/wheeloffsetcalculator.asp
the proposed 9" rim with 15 mm offset will push the outer surface of the tire a full 55mm further from the centerline, which converts to over 2"
that dog won't hunt I'm afraid
cheers,
Charlie
Ps: http://www.metric-conversions.org/le...-to-inches.htm
cheers,
Charlie
the 9's will poke quite a bit. going to need to be really lowered and cambered to fit them
the others will fit easy and be right at or 1/4" past the arches... no biggie there
i think this is 9" wide et 20... 'yours' will stick out a little more
read this thread:
https://www.northamericanmotoring.co...in-bronze.html
read this thread:
My setup is a et 25 in the rear and yes 9" wide.
read this thread:
read this thread:
blackie
Jan 18, 2017 09:56 PM
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 12, 2015 01:24 PM
